notchback25 Samba Member
Posted: Wed Jul 25, 2018 6:06 am Post subject: Shift rod swap early to late |
Is it possible to swap out a 64 and earlier shift rod and install an 65 and later rod in the same pan? I parted out a 65 years ago with the newer style coupler (at the back) and want to use it in a 63 pan. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Jul 26, 2018 2:31 pm Post subject: Re: Shift rod swap early to late |
Yes,, the 65-67 shift rod and coupler will interchange and directly replace the 56-64 rod and coupler.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Thu Jul 26, 2018 3:02 pm Post subject: Re: Shift rod swap early to late |
And, FYI, the shift rod/coupler changed about a quarter of the way into model year 1964.
_________________ Andy T.
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Thu Jul 26, 2018 5:27 pm Post subject: Re: Shift rod swap early to late |
Just did some research in this and don't remember the details. What year did the length change from 44 to 47"? _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Thu Jul 26, 2018 6:46 pm Post subject: Re: Shift rod swap early to late |
kind of the other way around. For 1968 model year they moved the shift lever towards the rear and the shift rod got shorter at that time. _________________ Andy T.
Posted: Fri Jul 27, 2018 6:07 am Post subject: Re: Shift rod swap early to late |
And.. it changed again after 72.. Not sure..why.. maybe for the green house glass Super Beetle implementation.
I don't fool with many past 67.. cause.. for years. I thought VW stopped building cars after that.
68-72 111-711-155F
and
73-79 111-711-155G
" From 1968 to 1972, the shift rod measures 45-1/8 inches long. In 1973, VW moved the shifter position back a small amount and from 1973 to 1979, the shift rods where 43-5/8 inches long overall (41-11/16 inches Center of cup to center of pin hole)".
No one reproduces the 65-67 or the 68-72..
Most "modify" a Universal Buggy/Rail shaft if needed.
In reality... how many really need replacement anyway ... very few..
Posted: Tue Jul 31, 2018 7:21 am Post subject: Re: Shift rod swap early to late |
Thanks for all of the replies. That helps me out! |
