jimf909 Samba Member
Posted: Sat Jul 28, 2018 10:01 pm Post subject: Re: 2" hitch receiver in front bumper |
Hopebo wrote: |
I am new here and would appreciate some help with this topic. I have a 86 Vanagon and am thinking of adding a cargo deck either to the front or rear mount.
Not thinking of adding a lot of weight to the carrier, maybe cooler, chairs, etc. Just to make more room for my dogs while travelling.
Thought that the rear is already heavy.
ANY advice would be appreciated. Thanks, Hope |
‘86 Vanagon. Is it a tin top or pop-top of some sort?
It sounds like you want to get some gear outside the van? If that’s the case, you can put it on the roof, in front, in back or leave it at home.
Do you have a receiver hitch in the front or rear?
Do you have any roof-top racks?
An ‘86 Vanagon isn’t set-up to carry any gear outside of the van unless it’s a Westy which has the luggage rack in front of the pop-top. Do you have a photo of your bus?
I might start with a roof rack since they can carry more than hitch mounted racks and can easily be sold to non-vanagon owners. A front or rear rack requires a $400 receiver as a starting point unless you can weld or bolt something together. _________________ - Jim
Abscate wrote: |
