How do you separate the turn signal switch from the wiper switch
74 Thing
74 Thing is offline
PostPosted: Sun Jul 29, 2018 8:53 pm    Post subject: How do you separate the turn signal switch from the wiper switch Reply with quote
How do you separate the turn signal switch from the wiper switch? They come out together as one unit after unscrewing 4 screws and lifting it out. I don't want to break anything prying them apart.
Thanks
JayC
JayC is offline
PostPosted: Mon Jul 30, 2018 9:28 am    Post subject: Re: How do you separate the turn signal switch from the wiper switch Reply with quote
Very very carefully Smile
I think i remember when I did mine that they kind of "snapped" apart. Look around the edges and see if there are 2-3 tabs that hold the plastic parts together if we are talking about the same thing.
jay
carsdlt
carsdlt is offline
PostPosted: Wed Aug 01, 2018 10:08 pm    Post subject: Re: How do you separate the turn signal switch from the wiper switch Reply with quote
IIROC, they are usually sold as a pair. If you're having an issue with one or the other, you might want to replace the whole unit. Usually available in the classified section, Thing and Beetle. Also TTS has them new.
Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own."
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Thu Aug 02, 2018 5:22 am    Post subject: Re: How do you separate the turn signal switch from the wiper switch Reply with quote
yes they just have lock tabs holding them together and no you don't have to replace both at the same time Wink
They do come out of the housing together then seperate
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
74 Thing
74 Thing is offline
PostPosted: Thu Aug 02, 2018 6:46 am    Post subject: Re: How do you separate the turn signal switch from the wiper switch Reply with quote
Thanks for the advise.
I was able to separate them and clean them and the contacts, and the turn signal cancelling mechanism.
The two white wire looms have three male/female interlocking tabs that need to be separated.
After that the two switches can be gently separated. There are male studs on one switch that connect the two so using a screwdriver and gently prying up separated them for me.
