crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Tue Jul 31, 2018 5:43 pm Post subject: Re: What did you do for your Bus today? |
Bought a new pair of Vanco tires for the '66, plus Hub cap clips, since I LOST
:2gunfire: a hub cap...
Plus my Bud John stopped buy w/ his latest Toy, a '79 Elcamino... _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Wed Aug 01, 2018 7:34 pm Post subject: Re: What did you do for your Bus today? |
Finally got the roof and raingutters on the '57 deluxe sorted out
What it used to look like
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
AirBus Samba Member
Joined: February 04, 2008 Posts: 290 Location: Holland
Posted: Thu Aug 02, 2018 4:23 am Post subject: Re: What did you do for your Bus today? |
Drove it to work.. _________________ VW T1 1964 - Mouse Grey - Pearl White
Bagged, Porsche steeringrack/brakes..IRS, T1 1915cc |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Thu Aug 02, 2018 8:08 am Post subject: Re: What did you do for your Bus today? |
thom wrote: |
Thom, it's looking good - how long have you been ticking away at this? _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
thom Samba Member
Posted: Thu Aug 02, 2018 6:18 pm Post subject: Re: What did you do for your Bus today? |
62DoKaGuy wrote: |
thom wrote: |
Thom, it's looking good - how long have you been ticking away at this? |
Getting close to 11 years... _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Posted: Thu Aug 02, 2018 7:13 pm Post subject: Re: What did you do for your Bus today? |
thom wrote: |
62DoKaGuy wrote: |
thom wrote: |
Getting close to 11 years... |
Like cognac, time sweetens the experience. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
4/62 Double Cab
5/61 Panel (sold)
AirBus Samba Member
Posted: Fri Aug 03, 2018 1:03 am Post subject: Re: What did you do for your Bus today? |
AirBus wrote: |
Drove it to work.. |
And Again!
EeVeeWee Samba Member
Joined: April 02, 2015 Posts: 836 Location: Amersfoort, Netherlands
Posted: Fri Aug 03, 2018 3:56 am Post subject: Re: What did you do for your Bus today? |
I changed my nearly new Koni shock absorbers for new shock absorbers with extra springs.
AirBus Samba Member
Posted: Fri Aug 03, 2018 5:16 am Post subject: Re: What did you do for your Bus today? |
Did you try to adjust the koni's ? _________________ VW T1 1964 - Mouse Grey - Pearl White
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri Aug 03, 2018 8:20 am Post subject: Re: What did you do for your Bus today? |
i used to run Konis in my 65 westy with Dormobile roof. So heavier as yours presently.
NEVER felt like i needed to even adjust the Konis. I did run Bilstein gas in the rear for the extra weight on the ass when towing. even off road never had an issue up front.
I think you may have another issue, broken springs in the front beam perhaps? _________________ regards
Uli
Posted: Fri Aug 03, 2018 8:47 am Post subject: Re: What did you do for your Bus today? |
mandraks wrote: |
I think you may have another issue, broken springs in the front beam perhaps? |
No the problema is I wanted a mild lowered bus, a few cm's lower than stock.
I have been advised by the revision company to used dropped spiders and adjustable front beam to put it upwards a bit more. The problem is the adjustment upwards is not enough, so my (high) tires sometimes hit the metal.
With these extra springs, the bus is bit higher (about 2 - 3 cm), so I hope it's better now.
The other option is to change the dropped spindels for stock one, but that is much more work of course.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Fri Aug 03, 2018 11:57 am Post subject: Re: What did you do for your Bus today? |
mandraks wrote: |
NEVER felt like i needed to even adjust the Konis. |
Where is the adjustment or adjuster? |
Posted: Fri Aug 03, 2018 5:54 pm Post subject: Re: What did you do for your Bus today? |
BarryL wrote: |
mandraks wrote: |
go to about 3:30
https://www.youtube.com/watch?time_continue=319&v=ksekDSo3Dbc _________________ regards
Uli
obus Samba Member
Joined: March 08, 2001 Posts: 11071 Location: just off Garden State Parkway Exit 81
Posted: Sun Aug 05, 2018 12:20 pm Post subject: Re: What did you do for your Bus today? |
I did a test ride and also tested the fridge and some camper stuff like table and chairs.
splitty_64 Samba Member
Posted: Fri Aug 10, 2018 8:19 pm Post subject: Re: What did you do for your Bus today? |
put new shocks on yesterday and started on the dual exhaust today by removing the apron and tin. |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Fri Aug 10, 2018 10:49 pm Post subject: Re: What did you do for your Bus today? |
I did the same thing today as the first day the snow was gone, drove it around killing bugs with the nose and windshield! _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Sat Aug 11, 2018 7:19 pm Post subject: Re: What did you do for your Bus today? |
CLR Scrubbing down this Titian Red Standard.
_________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Posted: Sun Aug 12, 2018 1:10 pm Post subject: Re: What did you do for your Bus today? |
Skim wrote: |
mine was so oxidized, it looked like root beer. This looks like a very flippable bus with very little effort. _________________ regards
Uli
Skim Rants Master
Posted: Sun Aug 12, 2018 7:40 pm Post subject: Re: What did you do for your Bus today? |
mandraks wrote: |
Skim wrote: |
mine was so oxidized, it looked like root beer. This looks like a very flippable bus with very little effort. |
It had that brown sheen but eventually it scrubbed off. Red scothbrite pads to the rescue. Not too bad for a days work.
1953 Kabriolet
1954 Sunroof
