How often do you expect to break down? |
Every Trip |
10% |
[ 6 ] |
Every Other Trip |
1% |
[ 1 ] |
Once Per Year |
16% |
[ 9 ] |
Its Rare but S*(^% Happens |
71% |
[ 40 ] |
Total Votes : 56 |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Wed Aug 08, 2018 10:45 am Post subject: Re: How often do you expect to break down? |
skills@eurocarsplus wrote: |
"how often do you expect to break down?"
depends who's bus I'm in |
That's a pretty good one,
And in theory it's true,
But I have seen otherwise.
I'll say,
"Depends which bus I'm in".
I have had aircooled VWs that should have been dead long ago,
Rods rattling lifting over the crest of a hill,
Muffler falling off onto the street,
That just ran and ran and ran 100% every time.
On the other hand,
Some are cursed.
Some have issues that NO mechanic can suss,
And they break down, or have problems, almost every outing.
Even though everything has been gone through..
It just depends which one it is, IME. _________________ Bus Motor Build
What’s That Noise?!? |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed Aug 08, 2018 11:56 am Post subject: Re: How often do you expect to break down? |
Abscate wrote: |
It's
...dont be nervous, don't be flustered, don't be scared....
be preparrrrred.... |
Nice to see another Tom Lehrer fan in the group! _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
danfromsyr Samba Member
Posted: Wed Aug 08, 2018 1:08 pm Post subject: Re: How often do you expect to break down? |
sometimes BEFORE you even turn the key _________________
Abscate wrote: |
Daverham Samba Member
Posted: Wed Aug 08, 2018 2:31 pm Post subject: Re: How often do you expect to break down? |
I got my bus for $500 in 2009. It was rotting in a field, hadn't been started in 4-5 years. Clutch was stuck to the flywheel. Big rat living in the air cleaner. I had it running within a couple days and did a lot of work to it during those first few months. In the early days there (like in the first six months) it broke down:
• Once because the fuel line was clogged (I fixed that with POR-15 and it has not recurred).
• Once because a wire connector on a relay was corroded, crusty and loose (I fixed that and it has not recurred).
• Once the clutch cable broke (slipped off the pedal/hook). I fixed that with a hose clamp roadside and have been driving it like that ever since.
That's it. It hasn't broken down since early 2010. Fix what's wrong with your bus and there's no reason it should break down at all. Short answer: Nowadays (and for quite a while now) I don't expect breakdowns - ever. But yeah, back when I was still reviving it, you didn't know what to expect. But that phase didn't last very long. |
