Early type 3 engine cylinder and cylinderhead identification
tanhis
tanhis is offline
PostPosted: Thu Aug 09, 2018 10:17 pm    Post subject: Early type 3 engine cylinder and cylinderhead identification Reply with quote
So I bought an early '62 t34 it had an engine but no cylinders or cylinder heads.
Now I am trying to locate cylinders/liners and heads but as far as I know these are special for early models until 65745 engine number.
So few questions.
-What is the bore for cylinder opening in the head.
-Bore for the cylinder in the crank case (this I could measure from my own but the block is in storage)
And what else is different in the early engine compared to the later model.
I have found out that the oil cooler and the mount is different but are there any other major differences that is not interchangeable from later 1500 engines.
-58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton
Multi69s
Multi69s is offline
PostPosted: Fri Aug 10, 2018 1:45 am    Post subject: Re: Early type 3 engine cylinder and cylinderhead identification Reply with quote
I can't answer any of your questions. However, you never know what the PO did to the engine, so you need to dig it out of storage, and measure the cylinder spigots. It would also be helpful to throw up a couple of pics as well. That way the gurus that know the older T3s can send you down the right path.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
ataraxia
ataraxia is offline
PostPosted: Fri Aug 10, 2018 6:49 am    Post subject: Re: Early type 3 engine cylinder and cylinderhead identification Reply with quote
Two threads you'll want to read to get you started:
https://www.thesamba.com/vw/forum/viewtopic.php?t=704460
https://www.thesamba.com/vw/forum/viewtopic.php?t=683612
