Francoc Samba Member
Posted: Fri Aug 10, 2018 10:03 am Post subject: Adjusting rear camber by twisting the diagonal arm |
The Bentley manual says “minor camber changes can be effected by loosening the four bolts that bind the bearing housing, spring plate, and diagonal arm together, then rotating the diagonal arm one way or the other with a pipe wrench. The range of adjustment by this method is quite small...”
Question #1: does anybody know which direction of rotation of the diagonal arm increases the camber (that is, makes it more positive)?
Question #2: how small is “quite small”? What are we talking about, like a fraction of a degree?
Thanks is advance. |
Posted: Fri Aug 10, 2018 12:30 pm Post subject: Re: Adjusting rear camber by twisting the diagonal arm |
I have done it and maybe gotten about a degree of correction. Sorry don't remember which way to twist it. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Fri Aug 10, 2018 1:24 pm Post subject: Re: Adjusting rear camber by twisting the diagonal arm |
I need to do this as my right rear camber is off. I may have caused this when I raised the rear end a couple years back. I don't drive it much so I'm in no hurry. Please let me know how this works out for you. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Fri Aug 10, 2018 1:28 pm Post subject: Re: Adjusting rear camber by twisting the diagonal arm |
Robbie just did this to his bus. And Colin is familiar with it as well. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 537 Location: Talbott, TN
Posted: Fri Aug 10, 2018 1:36 pm Post subject: Re: Adjusting rear camber by twisting the diagonal arm |
Loosen the 4 bolts and put the pipe wrench on the top of the flat stamped steel outer trailing arm that attaches to torsion bar) and push down to make camber more positive; You may also have to simultaneously tap the wheel hub with a hammer to move it down, relative to the flat trailing arm. The slots in the flat outer trailing arm don't allow much up and down (vertical) movement (maybe a few mm max, which is only about 1 degree at the wheel), but the slots allow a lot of side to side (horizontal) movement, 10+ mm and this affects the toe in. Before you start making any movements, take a cold chisel and mark the current position of the wheel hub to the flat trailing arm in both the vertical and horizontal directions, so that as you change one direction, you can make sure the other remains the same.
If you need more than a degree or 2 camber adjustment, you probably need to change your inner and outer trailing arm bushings, but you could also open up the size of the trailing arm slots with a Dremel tool to allow more vertical movement. Metal does fatigue, and considering the rear suspension has held the weight of your bus for 40 years, the camber may have naturally become more negative over the years than VW had envisioned allowing adjustment for.... |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3850 Location: San Jose, CA
Posted: Fri Aug 10, 2018 1:43 pm Post subject: Re: Adjusting rear camber by twisting the diagonal arm |
Said another way, viewing the Bus from behind: twist the right-side arm clockwise, the left-side (driver's side) arm counter-clockwise, RELATIVE TO THE REAR-END VIEW of the Bus. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Fri Aug 10, 2018 8:31 pm Post subject: Re: Adjusting rear camber by twisting the diagonal arm |
So you do this adjustment with the wheels on the ground? |
