"Blue" '72 Square build from a newbie.
Page: Previous  1, 2, 3 ... 18, 19, 20
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Jun 06, 2018 1:32 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
The FI isn't crap, but lots of mechanics are scared of FI. Your piston rings & valves are crap, so pull the engine & rebuild it.
http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch
Bobnotch is offline
PostPosted: Thu Jun 07, 2018 9:53 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Yup, rebuild the engine first, then put the FI on it and see how it runs. Then IF you decide it's too much trouble go carbs.
Bob 65 Notch S with Sunroof
mark tucker wrote:
dont the youthinasisa make all our vw stuff? Shocked
Tram wrote:
KollynnBlackpaw
KollynnBlackpaw is offline
PostPosted: Thu Jun 07, 2018 5:10 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
It'll be done very soon. The bus is getting it's motor rebuilt right now and the Square is the next to go. Wanted to do it myself but had the chance to have a good friend do it very well - and in such a emergency situation I had to go for him doing it right the first time. I'll be learning to build on my 40hps with him, though! We also found out one of the blocks I got was a 36 - score!
To top it off I'm picking up a couple motors this weekend and one happens to be a little bit built - 1641 with a turbo kit, high rev springs, 44 side draft, and a few other things. I'll have to learn a lot about that and figure out what to actually do with it.
1972 Square driver, 1968 Panel Bus, 1964 Tree-bug
Mike Fisher
PostPosted: Thu Jun 07, 2018 5:55 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
The 44 side draft would be sweet on Blue? Cool
KollynnBlackpaw
PostPosted: Wed Jul 04, 2018 12:31 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Right! Taken time away to fix Frau and now that she's (well, mostly) running again, Blue will be up next. I'll be sending him off to a friend's place to get looked at. I'm hoping it's rings,pistons,cylinders, and not the FI. When the FI DOES crap out, I'll not bother and put it to carb, but until then it stays! Razz
I miss my Blue!
Mike Fisher
PostPosted: Wed Jul 04, 2018 1:24 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Blue runs with FI even though its engine has lousy compression etc. Put the FI back on a freshly rebuilt engine & it will run better than aftermarket carburetor/carburetors.
KollynnBlackpaw
PostPosted: Tue Aug 07, 2018 4:34 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Alrighty - the bus is a pain and the throwout bearing has gone out now that I've got it running again. Instead of working on it more, this week I'll grab up a battery (probably) and we'll get working on him again. I've just agreed to sell my 64 bug to a friend for 800$, and am coming across another auto square in really awesome condition. I'll keep y'all updated.
... Anyone want a cursed 68 Bus?...
KollynnBlackpaw
PostPosted: Thu Aug 09, 2018 1:02 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Can anyone tell me what parts are 71 only?
Also - throwout bearing int he bus is out, that's gotta be fixed first, THEN Blue comes back for work. Gahh. I want to work on him, but I need the bus to just be working so I can drive again.
Mike Fisher
PostPosted: Thu Aug 09, 2018 9:44 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
At least you sold the '64 bug so you can Concentrate on your '68 bus before you get too wrapped up in the '72 square! Twisted Evil The '71 ignition switch is one year only. You gonna buy a '71 FI/AT square now?
Bobnotch
Bobnotch is offline
PostPosted: Thu Aug 09, 2018 1:44 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
You might want to take a look in the FAQ at the top of the forum page. I believe there's a list of 71 only parts.
Tram wrote:
KollynnBlackpaw
PostPosted: Thu Aug 09, 2018 6:57 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Actually, yes, I am! I was very excited about the Automatic in it! I'm buying it from a very nice gentleman in Sherwood, up here. I'll have to come show you once it's running around! As far as what I and my motor builder could tell, it's just not getting fuel right now. Should be right as rain with a good system cleanout and a look at the wiring and injectors. It's a very clean car! The pans are mint looking, all 3 seats lock and unlock smoothly, the stance is perfect, it's already been sound padded, new carpet kit included with all the glue parts already done, even the dash pad is only slightly cracked, not torn or anything. I'm very, very excited!!
The only issue with it is the title is missing, but there's a paper trail so hopefully things go well.
Last edited by KollynnBlackpaw on Thu Aug 09, 2018 7:19 pm; edited 1 time in total
KollynnBlackpaw
PostPosted: Thu Aug 09, 2018 6:59 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Thank you! I'll look over there.
Mike Fisher
PostPosted: Fri Aug 10, 2018 3:28 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
The '71 sounds solid & complete, so probably a good buy for a fair price. I believe you can get a Mechanic's Lien to get a Title for it in Oregon.
KollynnBlackpaw
PostPosted: Fri Aug 10, 2018 10:35 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Thanks, mike! Anything you recommend looking at as far as the AT goes? Obviously fluid and testing it once we get it fixed, but anything else I should make sure is OK?
I'll throw a couple pics up here soon.
Edit: Here's the ones from CL.
I really do love the stance and look of it. Going to keep the blue fender! He mentioned he has the bumpers, the carpet kit for the interior, and more blue parts. The ODO also shows 97k, which I think could be true. It's a pretty nice square and it's unlikely to me that it's an almost 200K car and still has the FI and AT.
Page 20 of 20
