freakybug_99 Samba Member
Joined: September 17, 2003 Posts: 5 Location: Dover, DE
Posted: Mon Aug 13, 2018 2:15 pm Post subject: Rim width |
Can I run a 15x6 cookie cutter rim on my lowered frontend without rubbing. It's lowered but not slammed. I run stock height spindles. Pic is how the car sits. I want to change my disc's over to the Porsche pattern.
Eskamobob1 Samba Member
Joined: August 08, 2016 Posts: 541 Location: South OC SoCal
Posted: Mon Aug 13, 2018 3:04 pm Post subject: Re: Rim width |
freakybug_99 wrote: |
Is it a super or a standard? Supers can run 15x7 on all 4 corners with early 944NA brakes. As for standard beetle, I am actualy having trouble finding out the exact same info. IIRC all cookie cutters are ET53.2,so that will help, but I believe you will still need some minor spacers for the rear. As for the front, I realy dont know. Sorry I cant help more, but I am excited to hear the answers _________________ '74 - front disks/lots more work to do |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Mon Aug 13, 2018 3:24 pm Post subject: Re: Rim width |
Eskamobob1 wrote: |
Is it a super or a standard? |
Sure looks like a Standard to me. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Aug 13, 2018 3:33 pm Post subject: Re: Rim width |
Glenn wrote: |
Eskamobob1 wrote: |
Sure looks like a Standard to me. |
Just wanted to make sure it wasnt a 71 super as if it is he has no worries, but if it isnt idk if they will fit or not. _________________ '74 - front disks/lots more work to do |
Posted: Tue Aug 14, 2018 6:01 am Post subject: Re: Rim width |
It's a 77 Standard. Thanks for the info. I'll keep you posted on what I find out. |
Posted: Tue Aug 14, 2018 9:34 am Post subject: Re: Rim width |
You may try looking up vdubengineering and trying to contact lanner. He has a lot of experience with fitting early (ET32.2) and late (ET 53.2) offset porsche wheels on bug, so while he may not be able to help on all wheels, he should be able to help with porsche wheels and let you know exactly what kind of spacers you will need.
Also, FWIW, 5.5" wheels fit on a 2.5" drop with no rubbing on a standard beam with 72 ghia (2 pin) disk conversion. Honestly, you realy dont need any wider than that. That is even the width that the classic race team runs on their ghias and supers.
EDIT: Just reread your post, yah, try contacting lanner. He will be able to help you out. _________________ '74 - front disks/lots more work to do
Posted: Tue Aug 14, 2018 9:42 am Post subject: Re: Rim width |
Gotcha, Thanks again. |
