color of 67 intake manifold
Ghettoman
Ghettoman is offline
PostPosted: Tue Aug 14, 2018 2:21 pm    Post subject: color of 67 intake manifold Reply with quote
What is the correct color of the intake manifolds for 67 bug. I have a silver one somebody painted but I know this is not right. Also does it have to be heat paint also?
67 Sunroof
67 Sunroof is offline
PostPosted: Wed Aug 15, 2018 6:06 am    Post subject: Re: color of 67 intake manifold Reply with quote
I don’t know what to tell you. It’s silver but not sure the exact color.
I would use an engine paint because it gets hot in there-just to be safe.
And, oh yeh, it’ll smoke a bit when you start the motor up. The high temp paint always does that for a few minutes.
Now if there’s flames you have a problem!
bnam
bnam is offline
PostPosted: Wed Aug 15, 2018 6:52 am    Post subject: Re: color of 67 intake manifold Reply with quote
I think it is a grey -- at least the original later manifold on my car had remains of that. I've used a Duplicor DE16 paint which is a high temp Ford Engine Grey and was close enough for me.
Click to view image
1952 Citroen TA 11BL
diablosandwich
diablosandwich is offline
PostPosted: Wed Aug 15, 2018 10:18 am    Post subject: Re: color of 67 intake manifold Reply with quote
I did the same as bnam. Hi temp Ford Grey. Here is one I painted grey.
https://www.thesamba.com/vw/classifieds/detail.php?id=2190952
Casey
1966 Java Greens
cyclehobby
cyclehobby is offline
PostPosted: Wed Aug 15, 2018 10:21 am    Post subject: Re: color of 67 intake manifold Reply with quote
I think it was a gray also, but I painted mine with simple Rustoleum and it's held up fine.
1967 Beetle
Northern NJ
bluebus86
Banned
bluebus86 is offline
PostPosted: Wed Aug 15, 2018 1:51 pm    Post subject: Re: color of 67 intake manifold Reply with quote
My very stock, very low mile, original 66 with 1300 motor Bug has a grey manifold. My 61 original owner family Bug that has been mine since 1978 also had a grey manifold on its 1200 motor. (since replaced with a 1600 dp motor from a 73, of which its manifold is grey, showing no signs of repaint.)
My 67 1500 cc motor has a grey manifold, It does not appear to have been repainted. I just went outside and checked its color. I believe it is stock color.
Near as I can tell by observation for what it is worth, originally a grey manifold color was used on my 61, 66, 67 and 73 motors.
I use a high heat paint to reduce risk of paint fail near the head, heat riser tubes, regular paint I found can discolor or fail from this heat over time. A good chemical resistant paint is also important. Fuel leaks or spills when servicing the carb, engine cleaners, carb cleaner, oil, and that occasional spray used for manifold leak testing.
I leave the inside bare, no paint, factory style. when you store manifolds, spray in oil to prevent rust. dont run an internally rusty manifold if it is risk of flaking, rust may shed and cause engine wear. I have cleaned them up with use of a media blaster when badly rusted.
Bug On, Correctly Painted!
PS I describe the grey as medium, maybe a a tab bit darker than battleship grey . It is not a light grey, and it is not extremely dark either. For what ever my crummy description is worth.
67 Florida Deluxe
Samba Purist
67 Florida Deluxe is offline
PostPosted: Wed Aug 15, 2018 5:15 pm    Post subject: Re: color of 67 intake manifold Reply with quote
Medium flat grey
-Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental
bnam
bnam is offline
PostPosted: Wed Aug 15, 2018 5:35 pm    Post subject: Re: color of 67 intake manifold Reply with quote
Click to view image
notsnarb
notsnarb is offline
PostPosted: Thu Aug 16, 2018 8:09 pm    Post subject: Re: color of 67 intake manifold Reply with quote
'67 is the same as here:
https://www.thesamba.com/vw/classifieds/detail.php?id=2196810
67 Florida Deluxe
Samba Purist
PostPosted: Thu Aug 16, 2018 8:41 pm    Post subject: Re: color of 67 intake manifold Reply with quote
As long as the intake manifold paint is in the middle grey range, no biggie. '67 purists are more concerned about the correctness of other bits, if that's your concern or goal to be spot on correct in a '67 restoration. Typically, it's EVERYWHERE else a so-called "restoration" falls apart Laughing
