AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 294 Location: Saskatoon, Sk Canada
Posted: Tue Aug 14, 2018 7:12 pm Post subject: Dragging brakes. |
I just installed a new brake booster and master cyl into a 74 westy and am suffering non releasing brake occasionally. It finally happened nere a jack and I found front and rear locked up. I checked the free play{good) then loosed the 13mm holding the M/cyl and the brakes freed up with just a couple of twists. Is it possible the rod in the booster is too long? The brake are to dam good _________________ 2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552 |
busdaddy Samba Member
Posted: Tue Aug 14, 2018 7:17 pm Post subject: Re: Dragging brakes. |
There are usually shim washers under the pressed in tip of the booster rod, some MC's require removing one or all. Worst case scenario shorten the rod slightly with a file or add some thick gaskets between the MC and booster. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Tue Aug 14, 2018 7:37 pm Post subject: Re: Dragging brakes. |
also some 1971 and later models have an adjustment on the rod that pushes from the pedal. Changing the master can require a check there. See Bentley Master Cylinder where it explains how to adjust the servo and master to work together. pages 5 and 6 in my Bentley Brakes and Wheels. Those systems are adjusted at the clevis because the pushrod is a solid part. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Tue Aug 14, 2018 7:38 pm Post subject: Re: Dragging brakes. |
If you just installed a new aftermarket booster you probably didn’t adjust the rod _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Aug 14, 2018 9:27 pm Post subject: Re: Dragging brakes. |
If you used one of the new Airtec servos like I did, I measured how much the rod protruded from the face of the servo on the original and then adjusted the one on the Airtec to match it. Mine has worked well for a year now. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
