vw donvieira Samba Member
Joined: May 11, 2004 Posts: 617 Location: stockton, California
Posted: Tue Aug 14, 2018 7:46 pm Post subject: 1971 with no 12v at coil |
So I was driving today on the freeway (Bus has been running beautifully) about 4k rpm and it was like somebody shut the ignition off.
-Fuses all look good.
-Starter turns over
-I do run an elec. fuel pump off the coil (which I need to change to a relay).
-No power to Blk pwr wire at coil
-Any suggestions?
Thank,s
vwdon _________________ "No Give Up" |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Aug 14, 2018 8:52 pm Post subject: Re: 1971 with no 12v at coil |
Either the switch died or the wire from the fuse box to the coil is open somewhere. From the diagram it looks like the ignition switch switches 12v to the fuse panel and the coil power comes off the unfused side. So you could lose the 12v and the fuses could still be good ( like you already know). _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Tue Aug 14, 2018 8:56 pm Post subject: Re: 1971 with no 12v at coil |
Thank you Westy.
-I will check the switch and the wire. It is a long way from front to back in a bus!!
Thanks,
Posted: Tue Aug 14, 2018 9:23 pm Post subject: Re: 1971 with no 12v at coil |
I hope I’m not reading the schematic wrong. Do you have a copy of the ‘71 diagram? _________________ If you haven't bled on them, you haven't worked on them.
Posted: Tue Aug 14, 2018 11:07 pm Post subject: Re: 1971 with no 12v at coil |
Good to go. Fuse #10 had 12v.
-A Look in the engine compartment and I had the blk coil wire that was not hung appropriately far enough, got hot/melted.
-Just repaired.
-Back to the road in my BUS!!!
Thanks a bunch for the help/inspiration.
Posted: Wed Aug 15, 2018 12:37 am Post subject: Re: 1971 with no 12v at coil |
vw donvieira wrote: |
-Just repaired.
vwdon |
Glad to help. Many here have helped me. _________________ If you haven't bled on them, you haven't worked on them.
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Wed Aug 15, 2018 6:21 am Post subject: Re: 1971 with no 12v at coil |
I'm betting on your ignition switch. Several years ago I had a similar problem. Turn key to ON and measure 12V at coil. Crank and 12V goes away. Release key and 12V comes back. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Wed Aug 15, 2018 7:42 am Post subject: Re: 1971 with no 12v at coil |
aeromech wrote: |
I'm betting on your ignition switch. Several years ago I had a similar problem. Turn key to ON and measure 12V at coil. Crank and 12V goes away. Release key and 12V comes back. |
He already repaired it. _________________ If you haven't bled on them, you haven't worked on them.
SGKent Samba Member
Posted: Wed Aug 15, 2018 8:39 am Post subject: Re: 1971 with no 12v at coil |
sounds like the heated manifold melted the wire, and blew a fuse. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
