Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Wed Aug 15, 2018 10:46 am Post subject: Re: Do I need to use a thermostat? |
Glenn wrote: |
A painted line will work also. |
True, but you might not be able to see the line you painted. With the cut in the end, you can reach the end a feel it's position. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Wed Aug 15, 2018 11:00 am Post subject: Re: Do I need to use a thermostat? |
I found a scrap piece of plastic that I wedge into the "screw slot" I cut. It acts as a flag to show the position easily.
I imagine one could use a suitable bent pocket clip from a pen or mechanical pencil to grip the end and show movement more easily. Whatever works!
I check it on tune-up day when I first start the car. As it gets older, I may make a habit of checking for "open" at each gas stop. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Wed Aug 15, 2018 11:01 am Post subject: Re: Do I need to use a thermostat? |
Bobnotch wrote: |
Glenn wrote: |
True, but you might not be able to see the line you painted. With the cut in the end, you can reach the end a feel it's position. |
Ah... digital indicator rather than analog _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Aug 15, 2018 11:17 am Post subject: Re: Do I need to use a thermostat? |
Glenn wrote: |
Bobnotch wrote: |
Glenn wrote: |
Ah... digital indicator rather than analog |
Hey, whatever works. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Randall Samba Member
Joined: October 03, 2004 Posts: 1403 Location: Orange County, Alta California, El Norte
Posted: Sat Sep 01, 2018 1:26 pm Post subject: Re: Do I need to use a thermostat? |
Tram wrote: |
The aircooled thermostat performs the same function as a watercooled thermostat- to get the engine temp up to spec quickly for most efficient running and fuel burning, adding life to the engine by preventing the build up of harmful byproducts.
Only a fool would leave it off. |
That's why the Doobie Brothers sang,
♫ "But what a fool believes he sees
No wise man has the power to reason away
What seems to be" ♫
My '63 Notch didn't come with a thermostat from the factory. When I switched to 12 volts I bought a 12 volt fan housing (silver color) because the 12 volt generator, which rests on the housing, is a different diameter than the 6 volt generator. However, the 12 volt fan housing wasn't a correct fit with the early tin it slides into. That means for the flaps to be fully open when the engine is warm, at start-up the flaps aren't fully closed. It isn't close to being closed. So I don't know if my engine is getting much benefit from this set-up. And I can't fit late tin because the body inside the engine compartment would interfere. |
OGSquare Samba Member
Joined: March 18, 2008 Posts: 244 Location: N. Georgia
Posted: Sun Nov 18, 2018 9:09 pm Post subject: Re: Do I need to use a thermostat? |
KTPhil wrote: |
My '71 fastback is garaged in a SoCal valley. When I rebuilt the motor I put the thermostat back in. Even with the warm garage, I noticed quicker warm-ups and earlier steady idle. I figure the smoother running meant it was reaching equilibrium faster, and the result would be less carbon buildup over time.
Also, the heater warmed up within about 2 minutes, instead of 5! |
2nd point doesn't make sense. Air to interior is determined by combustion temps. Those temps don't change whether the flaps are open or closed. _________________ Early 71 Stock Squareback
Early 65 Stock Doublecab
63 Stock Beetle |
gt1953 Samba Member
Posted: Mon Nov 19, 2018 7:08 am Post subject: Re: Do I need to use a thermostat? |
Now that is has turned cold here in the high country. So glad when the engine was down this summer repaired the T-stat flaps assembly. Warms up fairly quick. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Mon Nov 19, 2018 7:36 am Post subject: Re: Do I need to use a thermostat? |
OGSquare wrote: |
KTPhil wrote: |
2nd point doesn't make sense. Air to interior is determined by combustion temps. Those temps don't change whether the flaps are open or closed. |
When the thermostat flaps are closed (cold engine) The majority of fan air goes through the heater boxes into the car instead of onto the motor.
1. The motor warms faster, because less air is cooling it.
2. More heat from the exchangers is coming into the cabin, because more air is moving that way. _________________ Bus Motor Build
What’s That Noise?!? |
gregson1 Samba Member
Posted: Thu Nov 22, 2018 9:21 am Post subject: Re: Do I need to use a thermostat? |
I tore down an original mid-'63 engine years ago and learned a little about the earlier engines in the process. I didn't find a thermostat or any provisions for one. No flaps, no shaft for the flaps...nothing. The fan shroud doesn't even have the boss for the flap shaft bearings. The flaps didn't start until the '64 model year (August '63). The Workshop manuals discuss the parts needed to retrofit the thermostat to earlier engines.
It seems that the engineers originally thought they could get away without putting the thermostat/flaps on the Type 3 engine. Fairly early on VW apparently found that it was better to have them in place on a stock mass produced engine that would potentially experience every climate under the sun. Here in Denver, I'm going to run the thermostat/flaps on my Type 3 engine. My opinion is that if I lived in more consistently warmer climates, I might even consider them optional.
I don't currently run the thermostat/flaps in my wife's Type 14 and it does take about 10 to 15 minutes for things to warm up well. I worked with a Fluke 62 MAX IR gun last summer to find the various temperatures around the engine where it started running well--and where it started behaving badly, even when shut off (fuel percolation issue). I feel I have enough evidence to determine that the thermostat/flaps are going back onto the Type 14 this Winter. In conjunction with temperatures, the AF meter I hooked up also proved to me why I need the later style Ghia decklid for better cooling and carb breathing at high speed--which are considerations at the other end of the spectrum from the thermostat/flaps. Plan to go through the same drill with the Type 34. I'll at least have a benchmark across the spectrum to help determine what is 'normal' for my cars.
NOTE TO TRAM: Maybe you already know this--but I didn't. The #2 Main bearing in that original '63 engine was NOT steel backed. I guess the steel backed #2 didn't start until the 'K' engines in Aug '65? |
