81 Diesel Rabbit Timing Belt
Forum Index -> Water-cooled VW Share: Facebook Twitter
Studiotwosession
Studiotwosession is offline
PostPosted: Wed Aug 15, 2018 3:08 pm    Post subject: 81 Diesel Rabbit Timing Belt Reply with quote
A 1981 diesel Rabbit, not running, has come into my life. I am told it needs a new timing belt. I was also told many engines, when they need a timing belt, need other work because when the belt goes it causes other damage. However, a friend of mine said he was told with these particular cars (or engines) that is not true. Does anyone know, one way or the other, which is true with these vehicles. Thanks in advance.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Wed Aug 15, 2018 5:33 pm    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
Welcome to The Samba!
Diesels will most definitely bend the valves. There is absolutely no room for a valve when the piston is at TDC. They are also known to break the camshaft or punch holes through the pistons.
When you remove the cylinder head DO NOT throw away the head gasket, you will need it to determine which head gasket to use, they are different thicknesses depending on how high above the deck height of the block the piston protrudes.
Butcher
Butcher is offline
PostPosted: Wed Aug 15, 2018 6:27 pm    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
Spoken from the master. Heed his advice.
I do not think any diesel from any manufacturer will not be damaged when the belt or chain breaks. There is just no extra room in the combustion chamber.
Studiotwosession
PostPosted: Thu Aug 16, 2018 7:03 am    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
Many thanks and thanks for the welcome. There are at least 7 VWs (six were air cooled) in my past and its great to be an owner of one again. Given the facts of these engines, anyone dare to put a ballpark price on the engine work needed to get her running again? Thanks again.
TDCTDI
TDCTDI is offline
PostPosted: Thu Aug 16, 2018 8:12 am    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
$150-$3,000. No one can tell until it's disassembled & inspected, where you're located, parts availability, or who's doing the work.
Studiotwosession
PostPosted: Thu Aug 16, 2018 2:41 pm    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
Thanks!
sgnimj96
sgnimj96 is offline
PostPosted: Thu Aug 16, 2018 11:49 pm    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
any of the piston crowns that show marks of the valves hitting should have those valves replaced - even if they're not bent.
Previously hit valves have the occasional reputation of breaking after a few thousand miles.
ARP head studs are totally worth it if it's got the 11mm head bolts.
forum for IDI engines
http://vwdiesel.net/forum/index.php?PHPSESSID=2c147e25efd7d10ba0195c774b43b6de&board=6.0
TDCTDI
TDCTDI is offline
PostPosted: Fri Aug 17, 2018 4:47 am    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
I suggest against the use of the head studs. These are great for engines that are torn down after every season of racing but the problem with them is that they are not stretch bolts. The aluminum cylinder heads expand & contract & good bit as they’re heat cycled, this will lead to failed or leaking head gaskets. I got to replace quite a few head gaskets on various VW engine configurations because all the kids wanted the latest/greatest head studs. So, unless you plan on retorqueing the heads every 5-10,000 miles, I’d stay with the factory head bolts.
Studiotwosession
PostPosted: Fri Aug 17, 2018 7:05 am    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
Many thanks. Meanwhile, anyone know a source for parts like grilles? Also need things like the part that keeps the rear hatch up when one opens it?
TDCTDI
TDCTDI is offline
PostPosted: Fri Aug 17, 2018 7:08 am    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
Start here...
https://www.thesamba.com/vw/forum/viewtopic.php?t=490494
Studiotwosession
PostPosted: Fri Aug 17, 2018 1:59 pm    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
Thanks!
Studiotwosession
PostPosted: Sat Aug 18, 2018 6:28 am    Post subject: Re: 81 Diesel Rabbit Timing Belt Reply with quote
This is a really cool site, by the way. Makes me want to go out and buy a few more vintage v dubs!
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
