Timing Chain
Forum Index -> Eurovan Share: Facebook Twitter
Hawkridesdirt
Hawkridesdirt is offline
PostPosted: Wed Jun 20, 2018 9:25 am    Post subject: Re: Timing Chain Reply with quote
What is a reasonable cost to have the timing chain replaced on a 2003 Eurovan?
I just got a $6000 estimate... that seems pretty extreme to me.
Thanks
Toby Hawk
04 Land Rover D2 SE7
03 EV MV
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Wed Jun 20, 2018 9:38 am    Post subject: Re: Timing Chain Reply with quote
I think you can get a new engine + installation for that ridiculous price. It's a big job, but not that big.
I think the shop is telling you they don't want to work on your van.
Casey--
'01 Weekender --> full camper
y u rune klassik?
Hawkridesdirt
PostPosted: Wed Jun 20, 2018 10:54 am    Post subject: Re: Timing Chain Reply with quote
Thanks Z, me too.
I’ll keep checking around. I really don’t want to sell or trade it in...
LongmontLou
LongmontLou is offline
PostPosted: Wed Jun 20, 2018 2:47 pm    Post subject: Re: Timing Chain Reply with quote
Thanks
Toby Hawk
03 EV MV
Mine was $3,000 about 2 years ago.
Zeitgeist 13
PostPosted: Mon Jul 02, 2018 10:22 am    Post subject: Re: Timing Chain Reply with quote
I'm getting ready to dive into my timing chains and swap out the trans. Where's the place with the best deal on the TC kits these days? I see that ECS has several kits, but are there other places to go?
Casey--
y u rune klassik?
Abscate
Abscate is offline
PostPosted: Mon Jul 02, 2018 1:05 pm    Post subject: Re: Timing Chain Reply with quote
16 hours times your local labor rate plus $1000 in parts
Tax and shop,supplies, additional
Casey...FCP has parts listed separately
.ssS!
Zeitgeist 13
PostPosted: Mon Aug 13, 2018 11:42 am    Post subject: Re: Timing Chain Reply with quote
Ok, I've heard the arguments for pulling the whole drivetrain to do the chains, but could I save time/effort by just pulling the transmission? I've got the front end pulled and have started unplugging the harness, but the more I look at the A/C and PS components, it just seems like a real hassle to work around them without tweaking something or opening up the A/C.
Casey--
y u rune klassik?
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Tue Aug 14, 2018 8:11 am    Post subject: Re: Timing Chain Reply with quote
It sounds counterintuitive but I found it easier to remove the engine & leave the transmission in place. You can unbolt the flex plate & there is enough room to slip the engine out. I even left the A/C system sealed & just moved the condenser & compressor out of the way.
Zeitgeist 13
PostPosted: Tue Aug 14, 2018 8:30 am    Post subject: Re: Timing Chain Reply with quote
I guess I'll just keep going and pull everything. I'm also swapping the transmission for another. I'm having a hard time locally locating an M14 triple square tool for the CV joints. The bolts supplied with the new boot kits are M12
Casey--
y u rune klassik?
Joshwa
Joshwa is offline
PostPosted: Tue Aug 14, 2018 8:56 am    Post subject: Re: Timing Chain Reply with quote
M14? Must have large heads. I’ve only seen m10 triple square for the cv flange bolts. I’ve got a couple m10 triple square sockets if you want to borrow.
93 Weekender TDI conversion (AHU)
93 MV TDI conversion (1Z)
Weekender rear cot
Late model cabin air filter on 93
Euro spec bumper install on 93
Zeitgeist 13
PostPosted: Tue Aug 14, 2018 10:13 am    Post subject: Re: Timing Chain Reply with quote
I have a whole bunch of triple square tools, but I've never encountered this size before. The CVs are huge
Casey--
y u rune klassik?
CdnVWJunkie Premium Member
CdnVWJunkie is offline
PostPosted: Tue Aug 14, 2018 1:22 pm    Post subject: Re: Timing Chain Reply with quote
I know Lisle makes a reasonably priced triple square tool kit. Not sure if this brand is available in the US or not.
Zeitgeist 13
PostPosted: Tue Aug 14, 2018 2:33 pm    Post subject: Re: Timing Chain Reply with quote
Sears and others used to carry a full complement of Lisle tools, but sadly, no longer. I spent the better part of today driving around looking for this tool at all the usual suspects, but it turns out that AutoZone was the only place that had one.
If you have a late model EV do yourself a favor and buy a M14 XZN (triple square) socket. But then again, if the CVs have already been replaced, then you may just have M12s in there. screwy
Casey--
y u rune klassik?
xavior12
xavior12 is offline
PostPosted: Tue Aug 14, 2018 9:02 pm    Post subject: Re: Timing Chain Reply with quote
No kidding here, just this week I had a 24V van's CV bolt strip out. Went to the local supplier and found out that the early 12V CV bolts are the smaller M12 XZN triple square fastener. So the early vans had smaller CV bolts at the flange and late model vans had the larger CV flange bolts. Also, the lower ball joint on a 24V van is the same size fastener as the CV bolts. Thats if they've never been changed.
Hope this helps.
Zeitgeist 13
PostPosted: Wed Aug 15, 2018 1:41 pm    Post subject: Re: Timing Chain Reply with quote
It turns out the vendor sent me the wrong inner CV boot kits. Those M14 heads are attached to larger shafts as well. I'm guessing the 24v engines all got the larger CVs. I also snapped off two of the exhaust flange bolts, so I've got that going for me.
Casey--
y u rune klassik?
Zeitgeist 13
PostPosted: Wed Aug 15, 2018 6:42 pm    Post subject: Re: Timing Chain Reply with quote
What's the trick to getting the downpipe separated from the exhaust manifold? I have everything else separated, but I can't get that downpipe to Leggo my Eggo.
Casey--
y u rune klassik?
TDCTDI
TDCTDI is offline
PostPosted: Thu Aug 16, 2018 9:55 am    Post subject: Re: Timing Chain Reply with quote
Heat! Get a torch, you'll need at least MAPP gas if oxy/acetylene isn't available & heat up the nuts until they glow red/orange, then you might get them to release without shearing the studs.
Zeitgeist 13
PostPosted: Thu Aug 16, 2018 10:06 am    Post subject: Re: Timing Chain Reply with quote
The nuts are all removed, but I can't get the engine up and forward enough to let the downpipe drop away from the exhaust studs. The downpipe is resting on the subframe, so there's nowhere for it to drop any further. Can the drivetrain be removed with the engine/trans mounts installed, or do I need to remove them beforehand? I'm currently lifting from the trans mount.
Casey--
y u rune klassik?
TDCTDI
TDCTDI is offline
PostPosted: Thu Aug 16, 2018 11:40 am    Post subject: Re: Timing Chain Reply with quote
If I remember correctly, I usually unbolted the manifolds from the head.
Zeitgeist 13
PostPosted: Thu Aug 16, 2018 11:45 am    Post subject: Re: Timing Chain Reply with quote
Ugh...I'm gonna try to unbolt the rear of the downpipe first, before tackling the manifolds. This would be so much easier if they had just used bolts instead of studs in the manifold. I've already lost two days on dealing with dumbass stuff. The clock is ticking and I need this done asap. We're heading to B.C. in less than two weeks.
Casey--
y u rune klassik?
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 5 of 6
