djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2172 Location: Graz, Austria, Europe
advCo Samba Member
Joined: May 27, 2017 Posts: 373 Location: Houston, TX
Posted: Fri Aug 17, 2018 8:10 am Post subject: Re: A barndoor chassis buried in my garden |
Wow, that is too cool!! _________________ "He pulled the mirrors off his Cadillac ‘cause he doesn’t like it looking like he looks back"
'68/'70 Ghia Coupe Project
'70 Westy Project - Champagne I Wannabe
A bunch of vintage Japanese motorcycles
"Much ingenuity with a little money is vastly more profitable and amusing than much money without ingenuity." -A. Bennett |
Hellberg Samba Member
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Sun Dec 23, 2018 3:23 pm Post subject: Re: A barndoor chassis buried in my garden |
Merry Christmas to you - good choice of presents 😊 |
nzvwfan Samba Member
Joined: January 07, 2006 Posts: 145 Location: New Zealand
Posted: Wed Dec 26, 2018 12:53 am Post subject: Re: A barndoor chassis buried in my garden |
Is that a 35 Ford ? |
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 878 Location: Cornwall, UK
Posted: Wed Dec 26, 2018 11:47 am Post subject: Re: A barndoor chassis buried in my garden |
I’m still not convinced about these ‘bent’ bump stops on the chassis tube ends. I’ve spent some time since the old thread about them crawling around any low mileage OG bus I could and they are pretty much all bent. It takes some serious stress to bend them too. I still recon they could be bent to follow the twist in the spring plates. Or perhaps something at the factory in the way the buses or chassis are transported around. _________________ 1951 Samba 20-017894
1952 Samba 20-028952 |
Posted: Wed Dec 26, 2018 3:20 pm Post subject: Re: A barndoor chassis buried in my garden |
I was sharing your opinion for a long time, but I have seen plenty of BD chassis and they were all bent more on the driver's side, indicating more load on that side, especially in a panel van with cargo doors on the other side. everytime they would pile in the load, they would probably put it against the closed opposite side with the solid panel. putting even more load to the driver's side.
it was the same with this chassis. nearly no (if hardly any) bend on the passenger side and all twisted on the driver's. you could also see the ridge where the spring plates worked there way into the metal on the upper stop, until the stop was finally so much bent, that the spring plate would even go further up. So yes, I am 99% sure that they came straight from factory.
It was easy to realign them. I welded a piece of maybe 2ft ( 60cm) of40x40x2 mm(1-1/2") square tubing that you can see in the pics and cold formed it back without any heat. that steel is very ductile and I believe these pieces were either forged or must have been cast from steel alloy otherwise. I only needed the big sledgehammers to hammer the flange back to flat, which was warped because of the bend.
If you look closely at the design of the whole assembly from the rear , you will see that the 'stop' bung is actually a part that protrudes from the solid cast/forged metal. so the spring plate force is applied offset to the stop/torsion bar housing which causes the whole upper part to bend. If you look at the whole thing from said direction it is very easy to understand why and how that assembly was prone to damage. On a Barndoor we also have the shock absorber bolt holes, which further weakens the design.
later buses have much heavier ribs and overall design in that area. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Wed Dec 26, 2018 3:33 pm Post subject: Re: A barndoor chassis buried in my garden |
come to think of it. fat chicks (even Wolfsburgs) have the the spring plates further out to the wheels, which decreases the weight load put on them by axle load force. those are a few inches further out and concerning with the short measurement from spring plate/rear axle mount to the transmission case joint (axle boot cover center) this probably decreased the leverage and impact force to the stop at least by 20% or so I reckon. possibly another reason for that change.
(I hate to use the term improvement, because all was going downhill from March '55 ). _________________ Hotrods, Fords, Veedubs and Triumph Twins !
bally Samba Member
Posted: Sun Jan 06, 2019 11:48 pm Post subject: Re: A barndoor chassis buried in my garden |
Neat repair! |
D-train Samba Member
Posted: Wed Jan 23, 2019 2:42 am Post subject: Re: A barndoor chassis buried in my garden |
Big job. Well done for taking it on. What’s the end game? 23? 15? _________________ shiny paint doesnt make it worth any more |
blink Samba Member
Joined: September 07, 2011 Posts: 90 Location: Australia
Posted: Wed Jan 23, 2019 3:08 am Post subject: Re: A barndoor chassis buried in my garden |
This is amazing. Keep up the good work!!! |
Posted: Wed Jan 23, 2019 4:47 am Post subject: Re: A barndoor chassis buried in my garden |
Thanx guys ! yes, aiming at a coachbuild DLX with 27 windows. it will be a very open version, so this is why I need every little portion of chassis rigidity that I can get. from my calculations it will be about 40 kgs heavier than stock, but should have at least twice the torsional strength of the og chassis.
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Wed Jan 23, 2019 6:23 am Post subject: Re: A barndoor chassis buried in my garden |
Lowdown Dirty Rat wrote: |
I’m still not convinced about these ‘bent’ bump stops on the chassis tube ends. I’ve spent some time since the old thread about them crawling around any low mileage OG bus I could and they are pretty much all bent. It takes some serious stress to bend them too. I still recon they could be bent to follow the twist in the spring plates. Or perhaps something at the factory in the way the buses or chassis are transported around. |
Mine aren't bent at all _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
Scotty Samba Member
Posted: Wed Jan 23, 2019 6:26 am Post subject: Re: A barndoor chassis buried in my garden |
djfordmanjack wrote: |
I really look forward to seeing what you end up making, it sounds great! _________________
EverettB wrote: |
