jpaull Samba Member
Joined: February 22, 2005 Posts: 3459 Location: Paradise, Ca
Posted: Thu Aug 16, 2018 10:48 pm Post subject: Upgraded ignition Spark Comparison + Plasma/PCD info |
If you ever wondered what the actual difference looks like, here it is.
Video link:
https://www.youtube.com/watch?v=IaLQpwMqqX0
1. In the video, first you see Bosch blue, Taylor Spiro Pro wires, resister rotor, and resister plugs on points system.
2. Then you see same system, just changing to non-resister plugs.
3. Next, you see a non resister plug fired by MSD Blaster SS, Solid core wires, non resister rotor on mag pickup distributor.
4. Next, you see the bosch blue/resister setup trying to jump a gap. Picture below:
5. Finally, you see the MSD BlasterSS, Solid core wires, Non resister rotor/mag pickup system jumping a gap. Picture below:
mark tucker Samba Member
Posted: Fri Aug 17, 2018 1:05 am Post subject: Re: Bosch Blue vs MSD Spark Comparison (video included) |
omg this cant be true!!!! your doing some kind of foto shop thingy!!! no way the msd coil can beat the borsche blew coil!!! it cant happpen!!! it just cant !!! so...can we just paint the msd coil and add a borsh sticker so how much power did your dyno show bewteen the two? |
Krochus Samba Member
Joined: January 01, 2017 Posts: 892 Location: NW Arkansas
Posted: Fri Aug 17, 2018 4:50 am Post subject: Re: Bosch Blue vs MSD Spark Comparison (video included) |
It’s not that simple. You just can’t change the primary resistance of a coil that much without making accommodations inside the module or points to support it.
I would like to see this compared to a more modern COP and wasted spark coil |
jpaull Samba Member
Posted: Fri Aug 17, 2018 5:38 am Post subject: Re: Bosch Blue vs MSD Spark Comparison (video included) |
mark tucker wrote: |
I edited the title, cause its not really a coil vs coil test, im showing what the difference in a upgraded ignition can make.
The point is to show a difference that people can see. And your thinking about the Blaster2(canister). I used the BlasterSS(square coil)which is a totally different coil that is more powerful.
jpaull Samba Member
Posted: Fri Aug 17, 2018 5:43 am Post subject: Re: Bosch Blue vs MSD Spark Comparison (video included) |
Krochus wrote: |
Of course. Im showing the difference that can be acheived from a upgraded ignition system. People talk all day about one or the other, but how many people show a example? |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1170 Location: San Angelo, Texas
Posted: Fri Aug 17, 2018 6:22 am Post subject: Re: Upgraded ignition Spark Comparison (video included) |
Back when MSD first originated a performance speed shop here had an MSD advertising display which allowed users to transition in and out of an MSD 6A box in a visual way. The results were visually and audibly dramatic. And it sold me on the technology and it has always worked for me.
We ran a variety of engines, some on methanol and one on a 25% nitro-methanol mix, which is harder to light than race gas, and never had a problem. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Aug 17, 2018 6:48 am Post subject: Re: Upgraded ignition Spark Comparison (video included) |
I don't think anyone will deny that updating ignition is a good thing, however getting components that play nicely together and reliably seems to be issue/challenge....
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Aug 17, 2018 8:14 am Post subject: Re: Upgraded ignition Spark Comparison (video included) |
Never had any issues with my HEI setup, until the 3yr old coil failed a couple of weeks ago, I put the 40yr old coil back in and it has been fine since then. And just bought a 65,000V coil on ebay... |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3283 Location: Rapid City, SD
Posted: Fri Aug 17, 2018 9:35 am Post subject: Re: Upgraded ignition Spark Comparison (video included) |
Good work.
It would also be neat to see a packaged ready to go high power set-up like the CB Magnaspark.
Next up..... dyno testing of each!!
Brian |
jpaull Samba Member
Posted: Fri Aug 17, 2018 10:07 am Post subject: Re: Upgraded ignition Spark Comparison (video included) |
Brian_e wrote: |
Good work.
Brian |
I have a complete magnaspark distributor kit also, yes that will be next😁😁😁 |
Posted: Fri Aug 17, 2018 10:28 am Post subject: Re: Upgraded ignition Spark Comparison (video included) |
I was messen with ya and all the gotta have the blue coil guys...and for the guys that have to have the good old orange spark!!! |
Maddward Samba Member
Joined: July 18, 2010 Posts: 206 Location: Orange County, CA
jpaull Samba Member
Posted: Fri Aug 17, 2018 11:34 am Post subject: Re: Upgraded ignition Spark Comparison (video included) |
Maddward wrote: |
Great visual! Thanks jpaull |
Glad it helps! |
norris Samba Member
Posted: Fri Aug 17, 2018 3:27 pm Post subject: Re: Upgraded ignition Spark Comparison (video included) |
Very cool....thanks Jeff.....now I must buy a Blaster....not!(yet anyway) |
Posted: Fri Aug 17, 2018 4:02 pm Post subject: Re: Upgraded ignition Spark Comparison (video included) |
Dale M. wrote: |
Dale |
Exactly. This is after all the coil the OP CANNOT run on his car.
You can go get a coil for $8 at the salvage yard that will put out nearly as much spark. The tricky part is getting to use it without being stranded |
jpaull Samba Member
Posted: Fri Aug 17, 2018 4:21 pm Post subject: Re: Upgraded ignition Spark Comparison (video included) |
Krochus wrote: |
Dale M. wrote: |
Dale |
Not true. I can run that coil with my magnaspark distributor, my msd distributor with msd box, or my 009 with msd box. |
jpaull Samba Member
Posted: Fri Aug 17, 2018 4:49 pm Post subject: Re: Upgraded ignition Spark Comparison (video included) |
norris wrote: |
You might check with Fred, I bet the winterburn can fire the Blaster or other high power coil just fine. |
norris Samba Member
Posted: Fri Aug 17, 2018 5:59 pm Post subject: Re: Upgraded ignition Spark Comparison (video included) |
I'll do that....mostly out of curiosity. No question that the spark is a LOT HOTTER |
Emeraldlion Samba Member
Joined: April 13, 2005 Posts: 743 Location: Texarkana, TX
Posted: Fri Aug 17, 2018 7:51 pm Post subject: Re: Upgraded ignition Spark Comparison (video included) |
Let us know what you find Norris. Haven't wired up my winter burn yet, but would love to run a high power coil with my 010, or blue screamer and winter burn unit on my 2276 |
norris Samba Member
Posted: Fri Aug 17, 2018 8:17 pm Post subject: Re: Upgraded ignition Spark Comparison (video included) |
Just emailed Fred. I'm thinking he'll tell me a hotter coil than my Bosch would be redundant with his CDI.....we'll see soon |
