"What wheels fit?" The ultimate wheel post.
Page: Previous  1, 2, 3 ... 150, 151, 152 ... 172, 173, 174  Next
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat Aug 04, 2018 11:14 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
If you're in the Bay Area, it might make sense to check on these rims. A W123 MB has an offset of ET30 stock, so if these rims fit, they might be a nearly direct swap onto a Vanagon.
https://sfbay.craigslist.org/sby/wto/d/mercedes-monoblocks-for-w123/6656810828.html
Casey--
'01 Weekender --> full camper
y u rune klassik?
Lmvandiepen
Lmvandiepen is offline
PostPosted: Wed Aug 15, 2018 10:10 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Hey all, I have a 86 Syncro Doka. I have some snow wheels mounted with tires that I'm wondering if they will fit?
Wheel size is 17' 5x100 lug, not sure of offset
Meaty snow tires are 235/65/17.
Will I be able to wrangle these onto my rig? I don't want to drag them down there is there isnt a chance they fit, ha.
elizer Premium Member
elizer is offline
PostPosted: Wed Aug 15, 2018 10:33 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Bolt pattern is 5x112. Unless there is something I don't know. There are adapters but then that can cause other fitment issues and just not worth it for wheels.
bajaleo Premium Member
bajaleo is offline
PostPosted: Fri Aug 17, 2018 6:18 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Ask Chris at T3 about these wheels. He's helped numerous people here on thesamba fit different wheels to their vans.
Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered.
pjminn
pjminn is offline
PostPosted: Fri Aug 17, 2018 10:41 am    Post subject: HD STRATUS 16x7 5x112/5x120 et35mm Wheels? Reply with quote
Will these work on 2wd westy?
HD STRATUS Wheels 16x7 5x112 et35mm Hub Bore: 74.1
What modifications are needed?
Thanks
85 Westy: Work in progress
dhaavers
dhaavers is offline
PostPosted: Sat Aug 25, 2018 8:32 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
So I've been looking at something like this for a while:
MIM wheel, 5x112, 7x16, et 35, (centerbore unknown)
Info, please: a) load capacity? ...b) fitment/spacers? ...c) hardware/center caps? ...d) ballpark cost for all these extra bits?
This is first time I've ever looked into wheels seriously, so sorry if I seem clueless/needy... TIA! Cool
- Dave
"The WonderVan"
dhaavers
dhaavers is offline
PostPosted: Sun Aug 26, 2018 5:56 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Bump...Chris, you out there...??? Pray Wink
- Dave
"The WonderVan"
Christopher Schimke
PostPosted: Mon Aug 27, 2018 7:15 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Size wise, if you run a 215 or narrower tire, the wheels should fit without spacers. However, adding spacers to the rear will help improve the appearance a lot.
As for mounting hardware, it's impossible to know for sure. You would need the wheels in had to determine how thick the wheels are through the lug hole area and if they require conical or ball seat lugs.
One concern about those wheels is the diameter of the center bore, especially at the center cap area. The center caps look pretty small so even if the listed center bore diameter was on the large side, the opening where the cap clips in may be too small to allow the front grease caps to pass through. This is all something that you would need to have the wheels in hand to measure and determine.
No idea on their listed load capacity.
Zeitgeist 13
PostPosted: Mon Aug 27, 2018 8:23 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I run those Audi rims on our EV for winter tires. That van is a chunky monkey, so I wouldn't worry about their load capacity. They look great on vans
Casey--
y u rune klassik?
dhaavers
dhaavers is offline
PostPosted: Mon Aug 27, 2018 2:36 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Cool...thanks Chris.
Casey...Since you have them "in hand", any insights re: hardware & centerbore for Vanagon?
If boring is needed, I assume I just get them to my local machine shop along with what, ~$50, $100 bill...???
Just trying to get a feel for all the costs up front...Thanks guys!
- Dave
#wheelvirgin
"The WonderVan"
kitesurfer
kitesurfer is offline
PostPosted: Tue Sep 11, 2018 12:23 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Hi,
What wheel is that ? is it the carot wheel with a black powdercoat ??
thanks
http://nismostuff.blogspot.com/2013/07/found-on-mass-pike-4x4-vw-vanagon.html
levi
levi is offline
PostPosted: Tue Sep 11, 2018 1:09 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I'll say it's an audi 16" with a 45 et
But that's just me guessing at it.
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
Christopher Schimke
PostPosted: Tue Sep 11, 2018 1:56 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
kitesurfer wrote:
Hi,
Those are either the Carrot wheel (which is a cheap off-shore replica of the factory Mercedes wheels of the same design) or the actual factory Mercedes wheels.
kitesurfer
PostPosted: Tue Sep 11, 2018 9:39 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Do you know from what year/model of mercedes ?
visibleink
visibleink is offline
PostPosted: Sun Sep 23, 2018 7:51 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
kitesurfer wrote:
SteveVanB wrote:
Shameless pic whoring of my van. Lovin the new beetle heritage wheels Cool
Are these heritage wheels a direct fit on a Vanagon ?
+1
Are they 17s?
Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
<-- Helga, she slammed her dub in '53 and adjusted valves with her teeth
visibleink
PostPosted: Sun Sep 23, 2018 7:58 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Would these be okay for a 2wd westy?
off of a 1992 300CE. 16 inches x 7.5. 65jx15h2
Would they be up to the weight?
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Sep 24, 2018 7:30 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Hopefully you realize those are 15" wheels, 6.5" wide, like is says on them.
Mark
Jake de Villiers
Jake de Villiers is offline
PostPosted: Mon Sep 24, 2018 7:46 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
As Mark pointed out, those wheels are 6 1/2" x 15"!!
And yes, they'll be fine on your van - I have them on my tin top.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
Zeitgeist 13
PostPosted: Mon Sep 24, 2018 3:00 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Those look better on vans than they do on MBs. From what I recall the factory 124 rims used a lot of offset, so you'll probably need spacers plus the lug bolts/nuts/studs
Casey--
y u rune klassik?
Jake de Villiers
PostPosted: Mon Sep 24, 2018 9:57 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
There are a lot of different fitments with these wheels from the factory. Mine are close enough in ET that no spacers are needed with 205/60R15 tires.
ET is around 22 or 3 IIRC
www.thebassspa.com
Page 151 of 174
