didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sun Feb 17, 2013 7:31 pm Post subject: |
MURZI wrote: |
I used an airplane filler....because the car would fly..... PUNKS
CLEAN AND SIMPLE
... and the new owner probably enjoys it.
WHERE'S the NEXT buggy at, Murzi?
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Feb 17, 2013 10:02 pm Post subject: |
didget69 wrote: |
MURZI wrote: |
CLEAN AND SIMPLE
bryan |
That lid will fly all right.......off.....
You forgot to bolt it down.... _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Mon Feb 18, 2013 8:20 am Post subject: |
- it's an easy opening filler cap. _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
herkster Samba Member
Joined: February 14, 2013 Posts: 428 Location: Boca Raton, FL
Posted: Mon Feb 18, 2013 10:19 am Post subject: |
nice withthe aircraft cap...where did you get it and what about the filler that connects? |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Mon Feb 18, 2013 10:32 am Post subject: |
Here's a source of some neat stuff...
http://www.batinc.net/mocal-central.htm _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Goshen Samba Member
Joined: April 03, 2012 Posts: 833 Location: Miami. FL & Cartagena
20watts Samba Member
Joined: October 20, 2016 Posts: 1 Location: New Orleans
Posted: Thu Oct 20, 2016 8:05 am Post subject: looking for a fuel Door |
clonebug I am looking for a fuel Door just like the one you are showing do you know where i can find one at
clonebug wrote: |
Move your filler and shorten it to be lower than the hood.
Then pick up one of the many styles of flip lids that are available. Get one that you like.
Cut a hole in the hood above your relocated fillers and mount the flip lid above it.
It makes it easy as pie to remove your hood and you never have to worry about leaks or poor flow to the tank with one of those boat fillers.
Not to mention the PITA to try to get the hose loose when you need to remove the hood.
My hood and dash are separate and all I have to do is pull two bolts out by the windshield, flip open the fuel door so I can use it as a hand hold and then pull the hood off for complete access to my tank and wiring.
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Oct 20, 2016 8:32 am Post subject: Re: Fuel filler and cap for front of buggy |
The one Clonebug has is by AMP RESEARCH. Mine is also by AMP RESEARCH... Mine is for "M" class Mercedes...
There is 100 or more on sale via internet ... Check out bling sections at local auto parts, NAPA, O'Rilleys, Auto Zone and so on.... PU truck one seem to be best as the are better designed to fit flat (or nearly so) surfaces...
Some have real cheap magnetic locks, some are spring loaded to stay open/closed....
wythac Samba Member
Posted: Thu Oct 20, 2016 5:49 pm Post subject: Re: Fuel filler and cap for front of buggy |
Mine was from a early 2000s Ford F-150. Aftermarket purchase from Appletree or one of the other big internet auto parts suppliers like Summit, Jeg's, in chrome, silver, brushed aluminum, black, etc...you get the picture, the only trouble you'll have finding one is deciding which flavor you want.
I'd suggest next time you see one you like on a pickup or SUV at your local gas station ask them the model and year of their rig then see what you can find for that on the web. |
AlieBug Samba Member
Joined: April 20, 2017 Posts: 3 Location: WA, Australia
Posted: Thu Apr 20, 2017 11:04 pm Post subject: Re: Fuel filler and cap for front of buggy |
Quick question, where is your vent line connected?
Cheers,
Aliebug |
Posted: Fri Apr 21, 2017 7:25 am Post subject: Re: Fuel filler and cap for front of buggy |
AlieBug wrote: |
Cheers,
Aliebug |
Mine is just like the one in this pic from earlier in thread...
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Fri Apr 21, 2017 7:44 pm Post subject: Re: Fuel filler and cap for front of buggy |
Placing a vent hose in the filler neck just above the fuel level is a sure way to get a gulp of fuel trapped in the hose which while cornering or braking. The fuel vapor pressure will then puke it out.
The best place for a vent is as high as practical above the fuel where its least likely to get liquid fuel in it. These flip top fillers should be connected to the top of a filler neck which is welded on the top rear of the tank. The cap is mounted on top of the hood and is self vented(basically as high as practical above the fuel).
Posted: Fri Apr 21, 2017 8:59 pm Post subject: Re: Fuel filler and cap for front of buggy |
BL3Manx wrote: |
My filler tube goes one inch into the tank. I cut some slots into the tube where it goes into the tank so I don't lose any capacity but it does keep fuel from sloshing up into the filler.
I have had no issues with fuel coming out of the vent and I have put 50,000 plus miles on the buggy since I built it.
The vent just goes down below the pan an inch and is there in case of a spill.
It's never happened but is there in case of spillage. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Fri Apr 21, 2017 10:34 pm Post subject: Re: Fuel filler and cap for front of buggy |
At Manx Club meets, they encourage participants to fill their tanks before starting on a back country off road run. Its not uncommon at the first rest stop, which is often just on the side of a steep trail, to see a couple buggies just pissing fuel on the ground out their vent lines |
wythac Samba Member
Posted: Sat Apr 22, 2017 7:45 am Post subject: Re: Fuel filler and cap for front of buggy |
A vented cap is sufficient on my car. I've seen some vent lines, here somewhere, that have a few upward coiling loops before continuing out and down from where they come off the tank. I would guess that this would reduce some of the siphoning potential. |
Posted: Sat Apr 22, 2017 3:22 pm Post subject: Re: Fuel filler and cap for front of buggy |
In order for fuel to be siphoned out you would need a line inside down into the fuel. Mine is the stock vent line that VW put on this 1967 tank. It goes straight into the filler about an inch with no bend.
If buggies are leaking fuel at the first stop it would,...could be caused by several issues... in no particular order.
1. Poor design on the builders part.
2. vent too close to the fuel.
3. first stop too early in the ride........an average buggy should get 20-30 mpg. If the first stop is 10-20 miles away from fill up and fuel still leaks out then look back to number one issue.....
As i said.....no issues with my vent system but I rarely go off road. If I did I would park with the vent on the high side...... _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
EVfun Samba Member
Posted: Sat Aug 18, 2018 12:51 pm Post subject: Re: Fuel filler and cap for front of buggy |
This seems to be the best thread I've found for information about "gas door" or "fuel door" installs on Buggies. I like what Clonebug did and plan the same idea on my Mini-T, only out back in the "Bed" to access a Speedway T-bucket gas aluminum gas tank. Speedway didn't have any gas doors I liked. I found some over at Summit, but little description. Sparco, Classic Performance, AMP Research.
I was wondering what other have used, brands and models and where you found them for sale. What size is the cover? What is available seems to be constantly changing. I would like a quality product large enough for me to reach and remove the gas cap, but not larger than necessary. The AMP Research one for the Jeep is tempting but I haven't found size info and I really wish a polished version was available. Thanks! _________________
Wildthings wrote: |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Sat Aug 18, 2018 4:45 pm Post subject: Re: Fuel filler and cap for front of buggy |
EVfun wrote: |
... I was wondering what other have used, brands and models and where you found ... |
I pick'd a flip cap off from a Triumph TR4 in a salvage yard, cut down the VW filler tube, and connected the cap to tank with 2" hose.
They are still available new, for example:
https://www.sportsandclassics.com/parts/triumph/tr...flip-type/ |
EVfun Samba Member
Posted: Sat Aug 18, 2018 6:53 pm Post subject: Re: Fuel filler and cap for front of buggy |
MrGoodtunes wrote: |
EVfun wrote: |
That plan is common, but want to keep my buggy body easy to separate from the chassis so I want just a door on the body with the cap remaining on the gas tank. Right now the only things holding the body to the chassis are the dozen bolts attaching them, the rag joint of the steering coupler, and some wiring set up as several plugs that can be quickly disconnected.
BTW -- those little mini-vettes are cool. Getting in and out doesn't look fun but there is more to life than comfort! I fell in love with the Mini-T as a child reading the book "Dune Buggies" (by Gary Gladstone) so I sought out of those. They are not very comfortable either, the seats are moved back from the stock position so the room inside is rather cramped for it, but it is the one that hooked me as a child. _________________
Wildthings wrote: |
EVfun Samba Member
Posted: Sun Aug 19, 2018 11:02 am Post subject: Re: Fuel filler and cap for front of buggy |
... as I have continued to search this forum for gas filler door options I found a mention in one thread about using a boat inspection plate. Putting that into google got me a number of options. Most seem to be plastic, but I found some in polished stainless steel. They come in various sizes and the manufacturers actually give dimensions. I think the bright finish is a better match for the more old school look I'm giving my Mini-T and the price is right. Here is what I bought on Amazon. _________________
Wildthings wrote: |
