originalo Samba Member
Joined: February 14, 2007 Posts: 358 Location: Germany
Posted: Wed Jan 04, 2017 9:21 am Post subject: Any infos on this pre 50 split or ?... very early VDO clock? |
I have never seen this kind of clock before. Face design corresponding to 45-49 split or Porsche Gemünd speedo face. Diameter of clock is working for splitbug speedo or clock pod openings. No stamping on rear side.
Any info on this clock or it´s application (pre 50 split? KdF Wagen?? pre 50 Porsche 356??? Coachbuild???) will be greatly apreciated.
mikeandkirsti Samba Member
Posted: Sat Apr 07, 2018 12:50 am Post subject: Re: Any infos on this pre 50 split or ?... very early VDO clock? |
Mercedes 170? |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sat Apr 07, 2018 8:24 am Post subject: Re: Any infos on this pre 50 split or ?... very early VDO clock? |
... pretty face, but if a Mercedes it probably doesn't work _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
bakersam Samba Member
Joined: November 03, 2006 Posts: 119 Location: Washington DC
Posted: Sun Apr 08, 2018 5:57 am Post subject: Re: Any infos on this pre 50 split or ?... very early VDO clock? |
Owned a '50 Mercedes 170-S, and this wasn't the right clock face for that. Don't see any evidence of where the winding mechanism is on this one. Quite likely, it'd have to be on the side for a Bug. If on the bottom of the case then most certainly for someone else that had access from under the dash (i.e. Opel, BMW, Mercedes, Goliath, Hansa, Lloyd, Adler, Triumph, Auto Union, Wanderer, etc.). Looks like it slid into place from the front of the dash, and fastened in place with a bracket over that threaded post on the back. Interesting clock if you owned the right vehicle for it, but its configuration doesn't seem to support the VW theory. |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Mon Aug 20, 2018 12:25 pm Post subject: Re: Any infos on this pre 50 split or ?... very early VDO clock? |
pretty sure I saw one like this back in the eighties and was told it was from a german coach. would have been fitted in a roof mounting so passengers could see it. |
