Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Mon Aug 20, 2018 1:52 pm Post subject: Re: My first engine removal........questions |
A GOOD QUALITY dial caliper or even a vernier caliper will measure the deck height for less $$, and the caliper will be more handy in the future. Do not get the cheap digital calipers, they are junk. _________________ In Stereo, Where Available! |
crankbait09 Samba Member
Joined: October 10, 2016 Posts: 1299 Location: Cincinnati, Ohio
Posted: Tue Aug 21, 2018 11:07 am Post subject: Re: My first engine removal........questions, and lessons learned |
crankbait09 wrote: |
why is there not a gasket between the head and the jugs?
But there is one between the engine case, and the jugs |
Eric explained this, but I also found a quick video on it as well
https://www.youtube.com/watch?v=Zv7JFGUNOcI&t=269s _________________ 1963 Ragtop |
Posted: Tue Aug 21, 2018 4:11 pm Post subject: Re: My first engine removal........questions |
Have you tried a WWW search for such?? Add "VW" and a space before the part number with no spaces in it. Leave out the letter designation at the end. _________________ In Stereo, Where Available! |
Posted: Tue Aug 21, 2018 4:12 pm Post subject: Re: My first engine removal........questions |
Eric&Barb wrote: |
Have you tried a WWW search for such?? Add "VW" and a space before the part number with no spaces in it. Leave out the letter designation at the end. |
I have since removed that post. I did that as well and found a set of 4 of them on ebay. I'm set. _________________ 1963 Ragtop |
Posted: Thu Aug 23, 2018 5:02 pm Post subject: Re: My first engine removal........questions |
slowly proceeding....
Tonight I started with cylinder 3 and 4. Removed both, labeled them accordingly so I knew where they belong. Lapped both cylinders. Now the cylinders are ready for the sealant. Before I start that, I came back inside to create a "order of assembly" checklist by watching the bug me video, as well as using the muir book. So I will head back out tomorrow night with my checklist and hopefully have 3/4 head back in place.
I used an old alternator bracket to use as a ring compressor. Little bending here and there and cutting to make the right diameter and I was set. It works really well, but you definitely have to take your time when tapping the cylinder over the rings. I tried it to see how hard it would be. The next attempt will be when the sealant is on the cylinder. The sealant instructions say to way one hour before torquing in to place. I hope I can get both cylinders in place, and head in place once that 1 hour time comes along. Does anyone know how much longer past the one hour I can go before I have to redo the seal? So I will do this tomorrow night.
As for the air deflectors that go on the head. I have two, one is more curved than the other. Does it matter which head gets the more curved deflector? Here is a picture of the deflectors I have. Hopefully you can see the dramatic difference in curvage. (Is curvage even a word? )
Posted: Thu Aug 23, 2018 6:52 pm Post subject: Re: My first engine removal........questions |
Those in head deflectors need to be flat, except for the "legs" that lock into the head fins.
Posted: Thu Aug 23, 2018 7:09 pm Post subject: Re: My first engine removal........questions |
What causes them to curl? Heat/age? _________________ 1963 Ragtop |
Posted: Thu Aug 23, 2018 8:17 pm Post subject: Re: My first engine removal........questions |
What causes them to curl? Heat/age? |
Probably someones extraction method requires improvement. _________________ In Stereo, Where Available! |
Posted: Fri Aug 24, 2018 6:16 am Post subject: Re: My first engine removal........questions |
hammer back flat and we should be good to go. right? _________________ 1963 Ragtop |
Posted: Fri Aug 24, 2018 7:16 am Post subject: Re: My first engine removal........questions |
hammer back flat and we should be good to go. right? |
Yes, but go easy, and not deform them more. _________________ In Stereo, Where Available! |
Posted: Fri Aug 24, 2018 2:11 pm Post subject: Re: My first engine removal........questions |
can these little deflectors go on at any time, or should they go on before sliding head in to place? _________________ 1963 Ragtop |
Posted: Fri Aug 24, 2018 2:18 pm Post subject: Re: My first engine removal........questions |
can these little deflectors go on at any time, or should they go on before sliding head in to place? |
As long as you can get to the underside of the heads, you can install them. _________________ In Stereo, Where Available! |
Posted: Fri Aug 24, 2018 2:29 pm Post subject: Re: My first engine removal........questions |
Ya I believe I can. the engine is still on the stand. I will have the larger deflectors in place as I slide everything in to place once the sealer is on. I'll do the little ones after. _________________ 1963 Ragtop |
Rome Samba Member
Joined: June 02, 2004 Posts: 9603 Location: Pearl River, NY
Posted: Fri Aug 24, 2018 2:56 pm Post subject: Re: My first engine removal........questions |
For the deflector tin going on the right head, make sure you position the tin correctly so that the rod for the thermostat can pass through the cutout. If you install it the wrong way, the rod will never line up with the thermostat down below!
Here's a shot for reference from the gallery. Note the thermostat rod coming out of the cutout. |
Posted: Sun Aug 26, 2018 12:03 pm Post subject: Re: My first engine removal........questions |
when watching the bug me videos, I notice the guy puts permatex on certain gaskets, but not all. When he installs the fuel pump, he leaves permatex off. Is there any harm by using it in this location? _________________ 1963 Ragtop |
Posted: Sun Aug 26, 2018 12:22 pm Post subject: Re: My first engine removal........questions |
when watching the bug me videos, I notice the guy puts permatex on certain gaskets, but not all. When he installs the fuel pump, he leaves permatex off. Is there any harm by using it in this location? |
Just not needed there and if you have to pull the pump it is glued to the gasket. _________________ In Stereo, Where Available! |
Posted: Sun Aug 26, 2018 3:34 pm Post subject: Re: My first engine removal........questions |
moving on.....
I'm finding now that I am reassembling the engine, I have a random mix of washers, and parts of the like that were installed from the PO's. NOw that I am trying to make it right. Here are my questions.
1. Fuel pump - found diagrams that show that it gets installed with M8 SPRING WASHERS, followed by the M8 nuts. Can anyone confirm that spring washer I mentioned?
2. Distributor Bracket - I have the bracket and the nut to secure it in place. Should there be a washer in between the bracket and the nut?
3. Oil Cooler - I have looked at a number of diagrams, and videos and I am getting a few conflicting directions fin regards to the cooler that I actually have. In the picture below, You'll see the oil cooler/the base it will sit on. The base has since been cleaned. The base is just for reference. I think I have determined which seals I should be using. My concern is in regards to the "Washers" that go underneath the cooler. Can someone please confirm that I do need these washers under the cooler? When I look at the oil cooler diagram (shown below), you will see that the parts/pieces that are needed are very minimal.
Posted: Sun Aug 26, 2018 4:48 pm Post subject: Re: My first engine removal........questions |
1. Yes.
2. Yes, prefer the non-split washers for both.
3. No, washers between the cooler and case. Unless you are running a 10 to 8 mm passage cooler to engine passages or visa versa, that require the tapered adapter seals. _________________ In Stereo, Where Available! |
Posted: Sun Aug 26, 2018 4:56 pm Post subject: Re: My first engine removal........questions |
Here is a copy in the Waybackmachine internet archive of the oldvolkshome web site that is now gone (RIP Jim):
https://web.archive.org/web/20180207150445/http://oldvolkshome.com/
Do take the time to read thru the links on that page. Last one is most pertinent for you at this time. _________________ In Stereo, Where Available! |
in the oil cooler diagram, washer #4. what kind of washer is that? I assume this is the washer that goes in between the nut, and the case _________________ 1963 Ragtop |
