Posted: Tue Aug 07, 2018 1:46 pm Post subject: Oreillys Alternator PNW |
I am in Oregon and am thinking of buying an alternator from O'reilly's. Just looking for recent feed back as to the quality of the rebuilds they sell. The parts man at the local O'Reillys says their unit is a 55 amp internally regulated unit. Any reason to be buying anything larger? Have lived quite happily with the stock 38 amp generator, so I wouldn't think I would need anything bigger.
Will the stock generator pulley swap over to the alternator without problems? Or should I be buying something else?
Thanks |
Brian Samba Moderator
Posted: Tue Aug 07, 2018 1:50 pm Post subject: Re: Oreillys Alternator PNW |
A 38 amp pulley would not work on the alternator, nor will the fan spacer for the 38. Also, have had second hand experience with the O'reilly builds and am not a fan of them. The duralast ones from Autozone are a bit better.
38 amp is fine for a daily driver with a decent sound system. Any larger is just whatever really, unless you have 8 aux halogen head lights.
I'd 100% stick with 38 amp generators. I've had one in the same time period that I had 3 alternators. I have some complete 38 amp kits if you need one. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Starbucket Samba Member
Posted: Tue Aug 07, 2018 2:40 pm Post subject: Re: Oreillys Alternator PNW |
As above plus you will need alt. stand and a new fuel pump for alt. as they are angled. NAPA rebuilds are good w/lifetime replacement. |
Posted: Tue Aug 07, 2018 5:08 pm Post subject: Re: Oreillys Alternator PNW |
To throw in another question here, what is the advantage one way or the other of Bosch units verses Motorola units? |
bluebus86 Banned
Posted: Tue Aug 07, 2018 5:15 pm Post subject: Re: Oreillys Alternator PNW |
Starbucket wrote: |
Also a different length pump pushrod is required.
Bug On. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Tue Aug 07, 2018 7:31 pm Post subject: Re: Oreillys Alternator PNW |
Why even bother going alt?
The Herrera Brothers can rebuild your Bosch generator locally.
http://www.iandgautoelectric.com/
From the feedback that I have read they are some of the best around.
It never hurts to call them and see if they can handle your rebuild.
Surely this is a better choice than settling for a AutoZone unknown component.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Aug 07, 2018 9:01 pm Post subject: Re: Oreillys Alternator PNW |
Bosch v Motorola, do they have Motorolas in stock? I haven't seen one in a long time. Beware of the bosch names
AL82 is the alternator
AL82N is a new bosch, made in mexico
AL82NC is a new alternator made in china. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
mark tucker Samba Member
Posted: Wed Aug 08, 2018 1:50 pm Post subject: Re: Oreillys Alternator PNW |
get the new china unit it's cheeper and better and last longer too |
vwoldbug Samba Member
Posted: Wed Aug 08, 2018 4:59 pm Post subject: Re: Oreillys Alternator PNW |
If you have time to wait I would get your generator repaired and look for spare and get it rebuilt also . Maybe get a spare voltage regulator . Wern't the 38 amp generators on 1971 buses . |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Wed Aug 08, 2018 5:04 pm Post subject: Re: Oreillys Alternator PNW |
Get the original generator rebuilt, then install a new solid state voltage regulator. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Thu Aug 09, 2018 12:41 pm Post subject: Re: Oreillys Alternator PNW |
vwoldbug wrote: |
68-70 buses. Special model bugs got them, can't confirm which ones though.
Q-Dog wrote: |
Get the original generator rebuilt, then install a new solid state voltage regulator. |
Unfortunately no one makes 38 SS regulators. You can use a 30 amp regulator with a 38 amp generator, but really no point in having a 38a gen after that. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Thu Aug 09, 2018 3:23 pm Post subject: Re: Oreillys Alternator PNW |
Well it looks like new Bosch 30amp generators are available. Thoughts on the quality of a new Bosch?
Anyone know how to tell if a regulator is 30 amp or 38 amp? I would call the regulator I have semi electronic, it has the two coils and points but has some electronic stuff in there as well that seems to shuts down the field current when the unit senses that the brushes are worn. |
wmp100 Samba Member
Posted: Thu Aug 09, 2018 3:36 pm Post subject: Re: Oreillys Alternator PNW |
I got a 55 amp alternator from Oreilly's a couple years ago and it still works great. I got a lifetime warranty with it too so if it ever blows I can get a new one. Think I paid like 60 bucks for the unit and the warranty. Not a bad deal if you ask me. _________________ 1971 Standard Beetle Daily Driver |
Posted: Thu Aug 09, 2018 4:33 pm Post subject: Re: Oreillys Alternator PNW |
Look on the side, this is a 38 amp. You more than likely have a 30 amp one
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Mon Aug 20, 2018 1:22 pm Post subject: Re: Oreillys Alternator PNW |
I ended up just buying a new Bosch generator and regulator. Didn't see much negative about them in a search, so hopefully they will be as good as the originals. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26320 Location: Douglas, WY
Posted: Mon Aug 20, 2018 2:31 pm Post subject: Re: Oreillys Alternator PNW |
Brian wrote: |
vwoldbug wrote: |
Q-Dog wrote: |
Unfortunately no one makes 38 SS regulators. You can use a 30 amp regulator with a 38 amp generator, but really no point in having a 38a gen after that. |
Well, the Bosch 9190040099E SSR doesn't even have a listed amperage output on them (the 9190040099U SSR does say 30A though)
It was actually for 1969 that the 38 amp generator appeared on bus models.
And German made Bugs never used the GR17. Some of the GR26 generators list 38A on them but considering their tiny size compared to the GR17 I always kind of doubted that was really their capacity.
Anyhow, even back when I had an amp on the stereo in my Baja Bug, I never had a problem with the stock 30 amp generator not being able to keep up. That was in the era before the better, modern solid state regulators. _________________ Andy T.
