Dipstick readings.
Frodge
Frodge is offline
PostPosted: Mon Aug 20, 2018 1:39 pm    Post subject: Dipstick readings. Reply with quote
I have kind of. A weird question. My car after parked overnight will always show right in the top line of the dipstick after the initial wipe. Itís been like this al summer. Itís been a hot and humid summer here in ny. Today was cool. In the 70s, , I came back, hour later, the oil is between the lines. It was at the top line before I left for an 8 mile trip. I came back, and an hour and a half later it is between the lines. I checked under the car and there are no leaks or anything. What is going on? Does the oil get trapped somewhere when it is cooler? It didnít lose 1/2-3/4 quart in 8 miles.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Mon Aug 20, 2018 1:57 pm    Post subject: Re: Dipstick readings. Reply with quote
It could if the engine was failing. Fill it back up and go for the same drive. Recheck the oil. Maybe it is burning it up!
Jimbo
ASE Master Technician
Ricksurfin wrote:
First world fast guy problems. Sheesh. Lol
67rustavenger wrote:
Frodge
Frodge is offline
PostPosted: Mon Aug 20, 2018 1:59 pm    Post subject: Re: Dipstick readings. Reply with quote
Should I tear the engine down?
ricaroo Premium Member
ricaroo is offline
PostPosted: Mon Aug 20, 2018 2:00 pm    Post subject: Re: Dipstick readings. Reply with quote
Read this https://www.thesamba.com/vw/forum/viewtopic.php?t=677094&highlight=dip+stick+readings
Rick
volksbeetle.com
1971 Standard Beetle 2 dr Sedan 1600dp
Frodge
Frodge is offline
PostPosted: Mon Aug 20, 2018 2:21 pm    Post subject: Re: Dipstick readings. Reply with quote
This is a different thing. Iím not talking about pulling it in the morning vs wiping and then pulling a second time. All summer I would come home and the oil seemed at least to be at the top line. Not today. Today was the first day where it wasnít in the 80sor 90s. Even an hour or two later it is not at the top. No leaks or wetness. I donít get it. Iíll check in the morning again.
goober
goober is offline
PostPosted: Mon Aug 20, 2018 2:44 pm    Post subject: Re: Dipstick readings. Reply with quote
Try this.
I wipe the dipstick first. Then with the dipstick all the way down on the tube, I rock the dipstick back and forth 5-6 times before I pull it up and check it.
I do this several times. I have external oil coolers so I run a higher oil level as seen at rest. How you work the dipstick along with temperature and oil viscosity can impact the dipstick reading.
Frodge
Frodge is offline
PostPosted: Mon Aug 20, 2018 3:07 pm    Post subject: Re: Dipstick readings. Reply with quote
Itís been consistent at the top line all summer. I checked before I left today, it was at the top line. Went for 8-10 mike 35 mph ride, came back and it was between the lines. Weird to me. No leaks. Only difference is it wa really cool today.
Q-Dog
Q-Dog is online now
PostPosted: Mon Aug 20, 2018 3:57 pm    Post subject: Re: Dipstick readings. Reply with quote
Be consistent about when you check the oil. Check it before you start it first time each day and add as needed.
And don't worry so much. These cars are not like modern cars ... they do use oil.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
