Ausdingo Samba Member
Posted: Tue Aug 21, 2018 11:39 am Post subject: Alternator torquing fan nut |
Hi All
Just put on a alternator conversion on my 70 bus. Would like to torque rear fan nut to 45 pounds, but how do I hold the front pulley nut to stop it from spinning. I thought of a wrench, but that would only get to tight, and will need to un do again. Any help is appreciated.
Thank you |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51131 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Aug 21, 2018 12:03 pm Post subject: Re: Alternator torquing fan nut |
A strap type oil filter wrench works good for that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
Posted: Tue Aug 21, 2018 12:44 pm Post subject: Re: Alternator torquing fan nut |
Holding the pulley nut will NOT get it too tight. It will be tightened to exactly the same torque as the fan nut, which
is what is specified.
If you don't care for doing it that way, you can take off the rear pulley half and hold the shaft via a wrench on the flats of
the front pulley half hub. _________________ '67 bug: seized by the authorities
Posted: Tue Aug 21, 2018 7:49 pm Post subject: Re: Alternator torquing fan nut |
Thanks both if you. Really appreciate your help.
Regards |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Tue Aug 21, 2018 9:10 pm Post subject: Re: Alternator torquing fan nut |
I just use an impact _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Tue Aug 21, 2018 9:57 pm Post subject: Re: Alternator torquing fan nut |
aeromech wrote: |
I just use an impact |
I used an impact gun to get it off but I figured I would need to tighten it with the correct torque settings to put it back on. On you saying that is not the case? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Aug 22, 2018 5:00 am Post subject: Re: Alternator torquing fan nut |
aeromech wrote: |
x2 _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Wed Aug 22, 2018 5:38 am Post subject: Re: Alternator torquing fan nut |
If doing it in the car, you can lock the nut of the fan with a socket and bar and then torque the nut on the pulley end, thereby getting the correct torque on both nuts.
You can also just hold the shaft by using a large flat blade screw driver in the cutouts in the forward belt pulley half, jamming it against the head of one of the through bolts on the alternator, as per the Bentley. |
