beetle gearbox in a barndoor => clutch issues
Peter - Belgium
Peter - Belgium is offline
PostPosted: Tue Aug 14, 2018 8:11 am    Post subject: beetle gearbox in a barndoor => clutch issues Reply with quote
Hello all,
anyone had an issue with fully engaging the clutch after installation of a beetle gearbox in a BD? seems like the throw is just not enough?
difference I see is the 90mm clutch-arm on the gearbox while a BD has a shorter one. guess I need to change this out to a 75mm one?
Any other updates anyone else has done to improve this?
Thanks,
Peter
356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight=
Terry Gaudet Premium Member
Terry Gaudet is offline
PostPosted: Sun Aug 19, 2018 3:40 am    Post subject: Re: beetle gearbox in a barndoor => clutch issues Reply with quote
Hi Peter,
Did you install and setup the Bowden tube correctly?
Terry Gaudet
1950 Beetle Standard
1955 Canadian Custom
1956 Kombi w/SO23 kit
1965 Kombi walkthrough
1965 Double Cab
Peter - Belgium
PostPosted: Mon Aug 20, 2018 12:11 am    Post subject: Re: beetle gearbox in a barndoor => clutch issues Reply with quote
Hello Terry,
yes, that one is renewed and has the little sag in the middle as i always do, so should be correctly set?
This evening I can spend some more time... lets see if I can check what else could be up.
Thanks!
Peter
Scotty
Scotty is offline
PostPosted: Mon Aug 20, 2018 5:12 am    Post subject: Re: beetle gearbox in a barndoor => clutch issues Reply with quote
I didn't have any issues with 3 different beetle gearboxes in my bus, I didn't change the arm on any of them
Hellberg
Hellberg is offline
PostPosted: Tue Aug 21, 2018 1:10 pm    Post subject: Re: beetle gearbox in a barndoor => clutch issues Reply with quote
Have not had any problems either Shocked
Type 2 -53 smooth Gate SC (o\!/o) Type 1 -50 |o\ /o| Type 2 -55 Barndoor kombi
...........Driving barndoor to HO 2017............
