smitty1976bus Samba Member
Joined: January 21, 2013 Posts: 369 Location: Cape Cod
Posted: Tue Aug 21, 2018 8:10 am Post subject: Re: The Stupid Question Thread |
Stupid Question... Anyone know the weight capacity on the fiberglass pop top from a 1978 VW Westy? How much can I pile on top of it, before it's too much? (Putting solar panels on it, say 100 lbs'sh) Plan on making brackets, and drilling into the frame of the pop top... |
Posted: Tue Aug 21, 2018 7:13 pm Post subject: Re: The Stupid Question Thread |
Please disregard my question. Just going to do the non-stupid thing and put on lighter solar panels so I don't have to worry about it. Found some light, under 10 lbs, and flexible panels |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22450 Location: Escondido CA
Posted: Tue Aug 21, 2018 8:22 pm Post subject: Re: The Stupid Question Thread |
Search solar panels here on the samba - you would have seen what others have done. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
kavyp Samba Member
Joined: September 26, 2017 Posts: 5 Location: St.Louis, MO
Posted: Wed Aug 22, 2018 2:00 pm Post subject: Re: The Stupid Question Thread |
I am moving into an older home with an attached garage below it. Unfortunately the bus is too tall to get in, but would fit once inside of the garage. I don't think that letting out the air is going to get me enough room. I am wondering if I would be able to remove the wheels and put the drum brakes on a wheel dolly like that linked below and push it in?
https://www.harborfreight.com/2-piece-1500-lb-capacity-vehicle-dollies-67338.html
Thank you! |
dolamike Samba Member
Joined: June 25, 2017 Posts: 72 Location: San Francisco
Posted: Wed Aug 22, 2018 8:01 pm Post subject: Re: The Stupid Question Thread |
Does anyone know the technical name for this spade connector that snaps into the brake light switch plastic connector? Any idea on where to get them?
Thanks! _________________ 71 Bay Window Bus
85 Westfalia |
Fish Samba Member
Joined: December 05, 2000 Posts: 5559 Location: OB. It's beside the point.
Posted: Wed Aug 22, 2018 8:03 pm Post subject: Re: The Stupid Question Thread |
kavyp wrote: |
Thank you! |
Sounds like that will work, but I hope your bus isn't a daily driver? _________________ Prosit!
# 303 and #156
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Wed Aug 22, 2018 8:34 pm Post subject: Re: The Stupid Question Thread |
It looks like the original ones have a small tab on them that allows them to snap into the plastic connector... just thinking it might be a special type of flag connector...? _________________ 71 Bay Window Bus
85 Westfalia |
Posted: Wed Aug 22, 2018 10:18 pm Post subject: Re: The Stupid Question Thread |
dolamike wrote: |
It looks like the original ones have a small tab on them that allows them to snap into the plastic connector... just thinking it might be a special type of flag connector...? |
It does for just that reason. That first one listed may have the tang to push out to do so. Hard to tell. _________________
t3kg wrote: |
1964 1500 S
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Thu Aug 23, 2018 6:01 am Post subject: Re: The Stupid Question Thread |
kavyp wrote: |
Thank you! |
As long as it is off the backing plates and the drum is secured to the hub like there is a wheel attached. Making not sit on the backing plate might put you hanging off the edge of that dolly though, which might flip the dolly. So it's a toss up really. (sorry, probably not the definitive answer you were looking for) _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Thu Aug 23, 2018 8:40 am Post subject: Re: The Stupid Question Thread |
Ratwell has a good write up on electrical connectors if anyone is looking for this information.
The flag connectors that snap into the plastic connectors are called "FASTIN-FASTON" by AMP. Ratwell recommends https://www.digikey.com/ as a supplier.
http://www.ratwell.com/technical/Terminals.html _________________ 71 Bay Window Bus
85 Westfalia |
The Dubbernaut Samba Member
Joined: June 01, 2011 Posts: 163 Location: Kennewick, Wa
Posted: Thu Aug 23, 2018 10:06 am Post subject: Re: The Stupid Question Thread |
Will the 1972 center seat fit in my 1976? I tried searching but couldnt come up with anything. I figured I'm asking something with an obvious answer or I've missed the "all encompassing seat thread cross reference chart." lol
Found someone with NOS 1972 Center seats and the detailed photos look like they are in incredible condition. Removed in 1973 and stored in his basement until a week ago. $725 each _________________ 2012 Tiguan 4motion
2 Corrado's
3 Beetle's
76 Bus
2 Baja's
66 Pigalle Squareback
80 Rabbit
80 Rabbit Pickup
and still collecting! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Aug 23, 2018 12:18 pm Post subject: Re: The Stupid Question Thread |
The Dubbernaut wrote: |
Found someone with NOS 1972 Center seats and the detailed photos look like they are in incredible condition. Removed in 1973 and stored in his basement until a week ago. $725 each |
Wow, that's rater optomistic
The middle seat will fit fine, the rear uses a different mount for the backrest and will require some creativity on your part to adapt. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Thu Aug 23, 2018 4:58 pm Post subject: Re: The Stupid Question Thread |
That's how I got my 3/4 center seat, I'm still searching for that foot vent I got with it. I've squirreled it away somewhere.
They were buried in the garage when they sold their family Bus, they told the guy to come back for it after they cleaned up. He never did. Their mechanic mentioned it to me, called them up, said come and get it. No cost!!! _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
Posted: Thu Aug 30, 2018 10:53 am Post subject: Re: The Stupid Question Thread |
Do flywheel shims need to be oiled or greased when they are installed? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Thu Aug 30, 2018 11:30 am Post subject: Re: The Stupid Question Thread |
ivwshane wrote: |
Do flywheel shims need to be oiled or greased when they are installed? |
Yes, they are a bearing just like any other on the crankshaft. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Aug 30, 2018 11:59 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
ivwshane wrote: |
Yes, they are a bearing just like any other on the crankshaft. |
So use grease on them then? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Thu Aug 30, 2018 1:05 pm Post subject: Re: The Stupid Question Thread |
ivwshane wrote: |
busdaddy wrote: |
ivwshane wrote: |
So use grease on them then? |
Sure, or oil or assembly lube. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Aug 30, 2018 7:42 pm Post subject: Re: The Stupid Question Thread |
Exactly where does the felt ring go? I don't see any recess for it to sit in. Does the bolt plate hold it in? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
