DanHoug Samba Member
Joined: December 05, 2016 Posts: 4789 Location: Bemidji, MN
Posted: Fri Aug 24, 2018 4:09 pm Post subject: fuel injector comparison |
with my engine rebuild, i had installed 4 new 'disc' injectors from O'Reilly. have ran them for 7,500 miles and swapped them out today with some OEM Bosch ones i rebuilt. short story = the disc type (brand names under GP Sorensen, Tomco, etc) i have do not perform as well as the Bosch.
first, a clear shot of pintle vs disc injectors
now, comparison of nozzle length of the OEM Bosch (on very bottom) vs the GP Sorensen ones i bought. notice the length difference of how far the nozzle projects into the intake manifold.
here's what i noticed, seat-of-the-pants driving but a definite change:
- cold start is same HOWEVER, power to take off from cold start is better. i could feel a bog with the disc type that just was much less with the pintle.
- 1st gear is stronger when cold, no difference when warm. HOWEVER, second, third, and 4th were stronger. i'd describe it as 'zippy-er', quicker to rev. more confidence in 4th during cruising at 60-70mph as it just felt stronger.
- idle is about the same, same roughness/smoothness.
for those that are interested, i rehabbed by injectors by removing the inlet filter, a hot soak in an ultrasonic cleaner for an hour with some purple simple green HD, flushed with a mixture of naptha, gasoline, and 2 stroke oil (i added some chainsaw gas to prevent corrosion after cleaning). could see the spray pattern nicely in my test rig powered by cheapo $24 pump Bosch clone>filter>pressure regulator>container to catch regulator outfall.
[/img] _________________ -dan
www.thefixitworkshop.com |
jlrftype7 Samba Member
Posted: Fri Aug 24, 2018 6:08 pm Post subject: Re: fuel injector comparison |
Does not surprise me one bit. Port injection can greatly be affected by how the spray hits the intake valve. Thanks for posting this as a reference for what Stock looks like compared to Off the Shelf ‘Close Enough ‘ parts replacement. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
