ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Fri Aug 24, 2018 2:50 pm Post subject: 1946 front access? |
... saw this in a gallery and want to know if the access on the top of the tunnel, over the pedal mechanism was a stock - from the factory access in 1946?
And if so, When was it discontinued?
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
fazeka Samba Member
Posted: Fri Aug 24, 2018 11:52 pm Post subject: Re: 1946 front access? |
The hole on the right side of the tunnel... assuming it is for a pedal cluster? If so, didn't think they made RHD in '46? |
originalo Samba Member
Joined: February 14, 2007 Posts: 358 Location: Germany
Posted: Sat Aug 25, 2018 2:21 am Post subject: Re: 1946 front access? |
The access cover on the tunnel is not factory. You find those homemade openings often on bugs, they allow f. ex. to change the clutch wire without having to disassemble the pedal cluster.
Evidently there were RHD bugs in 1946 already. Attached fotos of such a car, believed to be built in February 1946, that a friend of mine photographed some years ago in an Australian museum.
Here´s the story of this CCG bug as exposed in that museum:
Posted: Sat Aug 25, 2018 10:21 am Post subject: Re: 1946 front access? |
[quote="originalo"]The access cover on the tunnel is not factory. You find those homemade openings often on bugs, they allow f. ex. to change the clutch wire without having to disassemble the pedal cluster.
yes, I like working in that area without removing the pedal assembly - I always refer it as the access VW forgot to make,.
1960 single cab
'87 Toyota MR2
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Sat Aug 25, 2018 3:30 pm Post subject: Re: 1946 front access? |
The picture that you have is our '46. The front of the tunnel was badly butchered when the restoration began. Some previous owner had simply hacked a hole!
The restorer asked if I wanted it restored to factory or have a reinforced surround welded below a cleaned up hole and a flush fitted almost hidden access plate fitted, it is retained by countersunk set screws. My choice was the latter having experience of changing a clutch cable on these cars in the past.
The result is access available to the cable area and with the tunnel as strong as the original. _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
KTPhil Samba Member
Posted: Sat Aug 25, 2018 4:29 pm Post subject: Re: 1946 front access? |
rod_vw wrote: |
The result is access available to the cable area and with the tunnel as strong as the original. |
This part is critical. |
Posted: Sun Aug 26, 2018 5:14 pm Post subject: Re: 1946 front access? |
rod_vw wrote: |
that access was well thought out, with a real craftsmanship-like installation...looks factory, to me... your body guy is awesome... is the access VW forgot to include. _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
splitjunkie Samba Member
Posted: Sun Aug 26, 2018 5:16 pm Post subject: Re: 1946 front access? |
originalo wrote: |
The beetle was designed with the details to build them left or right handed from the very beginning. I don't know if they were thinking of being able to export the cars or if the nazi's plans to take over the world had something to do with it.
A '46 dash
_________________ Chris
rod_vw Samba Member
Posted: Mon Aug 27, 2018 12:39 am Post subject: Re: 1946 front access? |
ZENVWDRIVER wrote: |
rod_vw wrote: |
that access was well thought out, with a real craftsmanship-like installation...looks factory, to me... your body guy is awesome... is the access VW forgot to include. |
My body man is Steve Hook of Hooky's Panel Shop ( http://www.hookyspanelshop.com/ ) , one of the best in the UK. _________________ Rod,
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Mon Aug 27, 2018 12:57 am Post subject: Re: 1946 front access? |
rod_vw wrote: |
Would you mind taking the plate off and posting some detailed pics of the reinforcements done? _________________ F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023 |
rod_vw Samba Member
Posted: Mon Aug 27, 2018 2:38 am Post subject: Re: 1946 front access? |
Here you go...
Don't take any notice of the left floor plate, its presence is a long story. Both floors were eventually replaced like this with new floors supplied by Kdf Osnice ( https://en.kdf.cz/inpage/catalogue-kdf-82/ ) suitably created by Ivo for a saloon.
And now the car is on the road...
Posted: Mon Aug 27, 2018 8:20 am Post subject: Re: 1946 front access? |
.. thank you Rod - that is a beautiful '46 - that access is a well executed upgrade - a great part of VW history. _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
René R. Samba Member
Joined: July 06, 2015 Posts: 1712 Location: No. Calif.
Posted: Mon Aug 27, 2018 8:27 am Post subject: Re: 1946 front access? |
What a beautiful car! Wow. _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
