The Stupid Question Thread
Page: Previous  1, 2, 3 ... 379, 380, 381 ... 513, 514, 515  Next
smitty1976bus
smitty1976bus is offline
PostPosted: Tue Aug 21, 2018 8:10 am    Post subject: Re: The Stupid Question Thread Reply with quote
Stupid Question... Anyone know the weight capacity on the fiberglass pop top from a 1978 VW Westy? How much can I pile on top of it, before it's too much? (Putting solar panels on it, say 100 lbs'sh) Plan on making brackets, and drilling into the frame of the pop top...
smitty1976bus
PostPosted: Tue Aug 21, 2018 7:13 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Please disregard my question. Just going to do the non-stupid thing and put on lighter solar panels so I don't have to worry about it. Found some light, under 10 lbs, and flexible panels Smile
notchboy
notchboy is offline
PostPosted: Tue Aug 21, 2018 8:22 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Search solar panels here on the samba - you would have seen what others have done.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
kavyp
kavyp is offline
PostPosted: Wed Aug 22, 2018 2:00 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I am moving into an older home with an attached garage below it. Unfortunately the bus is too tall to get in, but would fit once inside of the garage. I don't think that letting out the air is going to get me enough room. I am wondering if I would be able to remove the wheels and put the drum brakes on a wheel dolly like that linked below and push it in?
https://www.harborfreight.com/2-piece-1500-lb-capacity-vehicle-dollies-67338.html
Thank you!
dolamike
dolamike is offline
PostPosted: Wed Aug 22, 2018 8:01 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Does anyone know the technical name for this spade connector that snaps into the brake light switch plastic connector? Any idea on where to get them?
Thanks!
71 Bay Window Bus
85 Westfalia
Fish
Fish is offline
PostPosted: Wed Aug 22, 2018 8:03 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thank you!
Sounds like that will work, but I hope your bus isn't a daily driver?
Prosit!
# 303 and #156
ivwshane
ivwshane is offline
PostPosted: Wed Aug 22, 2018 8:18 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks!
It goes by many names.
Right angle spade connector
https://www.belmetric.com/noninsulated-connectors-...-5381.html
Right angle L type crimp connector
https://www.amazon.com/6-3mm-Right-Angle-Terminal-...gle+l+type
Flag spade connector
https://www.amazon.com/Hilitchi-Insulated-Disconne...Src=detail
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
dolamike
dolamike is offline
PostPosted: Wed Aug 22, 2018 8:34 pm    Post subject: Re: The Stupid Question Thread Reply with quote
It looks like the original ones have a small tab on them that allows them to snap into the plastic connector... just thinking it might be a special type of flag connector...?
71 Bay Window Bus
85 Westfalia
notchboy
notchboy is offline
PostPosted: Wed Aug 22, 2018 10:18 pm    Post subject: Re: The Stupid Question Thread Reply with quote
It does for just that reason. That first one listed may have the tang to push out to do so. Hard to tell.
1964 1500 S
Spike0180
Spike0180 is offline
PostPosted: Thu Aug 23, 2018 6:01 am    Post subject: Re: The Stupid Question Thread Reply with quote
Thank you!
As long as it is off the backing plates and the drum is secured to the hub like there is a wheel attached. Making not sit on the backing plate might put you hanging off the edge of that dolly though, which might flip the dolly. So it's a toss up really. (sorry, probably not the definitive answer you were looking for)
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
dolamike
dolamike is offline
PostPosted: Thu Aug 23, 2018 8:40 am    Post subject: Re: The Stupid Question Thread Reply with quote
Ratwell has a good write up on electrical connectors if anyone is looking for this information.
The flag connectors that snap into the plastic connectors are called "FASTIN-FASTON" by AMP. Ratwell recommends https://www.digikey.com/ as a supplier.
http://www.ratwell.com/technical/Terminals.html
71 Bay Window Bus
85 Westfalia
The Dubbernaut
The Dubbernaut is offline
PostPosted: Thu Aug 23, 2018 10:06 am    Post subject: Re: The Stupid Question Thread Reply with quote
Will the 1972 center seat fit in my 1976? I tried searching but couldnt come up with anything. I figured I'm asking something with an obvious answer Rolling Eyes or I've missed the "all encompassing seat thread cross reference chart." lol
Found someone with NOS 1972 Center seats and the detailed photos look like they are in incredible condition. Removed in 1973 and stored in his basement until a week ago. $725 each
2012 Tiguan 4motion
2 Corrado's
3 Beetle's
76 Bus
2 Baja's
66 Pigalle Squareback
80 Rabbit
80 Rabbit Pickup
and still collecting!
busdaddy
busdaddy is offline
PostPosted: Thu Aug 23, 2018 12:18 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Wow, that's rater optomistic Shocked
The middle seat will fit fine, the rear uses a different mount for the backrest and will require some creativity on your part to adapt.
Слава Україні!
Volswagon
Volswagon is offline
PostPosted: Thu Aug 23, 2018 4:58 pm    Post subject: Re: The Stupid Question Thread Reply with quote
That's how I got my 3/4 center seat, I'm still searching for that foot vent I got with it. I've squirreled it away somewhere.
They were buried in the garage when they sold their family Bus, they told the guy to come back for it after they cleaned up. He never did. Their mechanic mentioned it to me, called them up, said come and get it. No cost!!!
I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight=
ivwshane
ivwshane is offline
PostPosted: Thu Aug 30, 2018 10:53 am    Post subject: Re: The Stupid Question Thread Reply with quote
Do flywheel shims need to be oiled or greased when they are installed?
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
busdaddy
busdaddy is offline
PostPosted: Thu Aug 30, 2018 11:30 am    Post subject: Re: The Stupid Question Thread Reply with quote
Yes, they are a bearing just like any other on the crankshaft.
Слава Україні!
ivwshane
ivwshane is offline
PostPosted: Thu Aug 30, 2018 11:59 am    Post subject: Re: The Stupid Question Thread Reply with quote
So use grease on them then?
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
busdaddy
busdaddy is offline
PostPosted: Thu Aug 30, 2018 1:05 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Sure, or oil or assembly lube.
Слава Україні!
ivwshane
ivwshane is offline
PostPosted: Thu Aug 30, 2018 7:42 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Exactly where does the felt ring go? I don't see any recess for it to sit in. Does the bolt plate hold it in?
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
SamboSamba22
SamboSamba22 is offline
PostPosted: Thu Aug 30, 2018 8:02 pm    Post subject: Re: The Stupid Question Thread Reply with quote
1.8 Type 4 Cylinder Head set I picked up this past weekend for $40.
These are indeed 1.8’s, correct? 41x34 valve, or so I roughly mic’d.
Part #021101371J
Part #021101371S
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
Page 380 of 515
