Hiramhaus Samba Member
Posted: Mon Apr 06, 2015 8:51 pm Post subject: |
Got er hooked up, concerned the fuel is too old, the carb needs rebuilt because I got it used (let alone jetted), the brakes need bled as I found when I hit the pedal (hopefully haven't sprung a leak), and currently no power from the ignition.
Starter goes fine, and engine turns over. At least I am circulating oil through the system this way and letting it sit.
My ignition was bad, I replaced it, with a junk one (or blew it out somehow), then replaced it again. Then blew the engine.
Looking to get minimum spark, then I can move on to fuel.
_________________ 1969 Ghia
2016 Audi Q3 |
Posted: Sat Apr 18, 2015 1:50 pm Post subject: |
2016 Audi Q3
Posted: Thu May 07, 2015 7:36 pm Post subject: |
I bet that water felt good.
2016 Audi Q3 |
Posted: Fri May 08, 2015 8:22 pm Post subject: |
The engine is running well and mostly correctly, I think I might have an issue with the fan. It makes a loud whirring or grind noise once in a while.
It also threw some spray from the rear seal...
going to work on housing adjustments
Weber Progressive 32/36 is working pretty well this is what I currently have for jets:
Primary idle jet 40
Secondary Idle Jet 37.5
Primary Main xxx
Secondary Main xxx
Primary Air 145
Secondary Air 140
I think I am due to get some jets:
Primary Idle Jet 45
Secondary Idle Jet 60
Primary Main 125
Secondary Main 190
Primary Air 160
Secondary Air 180 _________________ 1969 Ghia
2016 Audi Q3 |
Posted: Sat Jun 09, 2018 5:37 pm Post subject: Re: 1969 Ghia - Hiramhaus |
After getting the engine going, the starter went out. So I replace it and now I have a voltage leak that is inexplicable.
So... I made the plunge and ordered the complete wiring harness kit.
AND then the brake pedal rusted stiff due to the sunroof (skylight) leaking then pooling by the pedal.
Sooo. I pulled the pedal out and am tearing that apart. I have a question on another thread about that if anyone wants to say anything.
https://www.thesamba.com/vw/forum/viewtopic.php?t=646487&highlight=
Trying to get rolling so I can take it to the upholstery guy and he can redo my three fold. I sewed my own vinyl one and it was not much better than the original.
Pictures of such on my instagram
www.instagram.com/hiramhaus _________________ 1969 Ghia
2016 Audi Q3 |
Posted: Sun Sep 02, 2018 1:02 pm Post subject: Re: 1969 Ghia - Hiramhaus |
I was able to get my pedal assembly back together and painted. I got one of the Airkewled six shooter cable adjusters and am glad I did. The tiny 7mm hex nut on there took me about 4 hours to take off with an open end and box end wrench, and vice grip. I put the spinner on in less than a minute or two.
Now they are back in the car and I have taken it on a tour, it was great, and the brake pedal returns on its own without pulling it up with my foot.
Now back to my electrical leak.
I have a 12v leak at the positive terminal on the battery with the key in the off position. When I test it after pulling one wire at a time off the headlight switch I get 12v with all wires attached. Then 3v with the main red wire from the loom wire pulled, 12v with the switched wire. and another 3v on the other position. _________________ 1969 Ghia
2016 Audi Q3 |
jokswgn Samba Member
Joined: February 04, 2006 Posts: 16 Location: temecula ca
Posted: Sun Sep 09, 2018 10:18 am Post subject: Re: 1969 Ghia - Hiramhaus |
One question where did you get your aluminum dash from? |
Posted: Mon Sep 02, 2019 9:15 pm Post subject: Re: 1969 Ghia - Hiramhaus |
jokswgn wrote: |
Hello from the time machine. It came with the dash installed. JBugs sells them. _________________ 1969 Ghia
2016 Audi Q3 |
Posted: Tue Aug 04, 2020 8:31 pm Post subject: Re: 1969 Ghia - Hiramhaus |
I've been working on cleaning the engine up. I've got a new shroud to install and throttle linkage.
2016 Audi Q3 |
