captnslow Samba Member
Joined: September 17, 2012 Posts: 40 Location: Portland OR
Posted: Sat Jun 07, 2014 3:42 pm Post subject: Enkei Compe |
Is anyone running these on a Volkswagen? I can't find any pics :/
Thanks!!
http://www.enkei.com/compe.shtml
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Sun Jun 08, 2014 4:48 pm Post subject: |
That is a really nice looking wheel. The only thing I don't like is the ribbed lip. |
kidosteele Mr. Butthurt
Joined: July 14, 2004 Posts: 116 Location: Saint Petersburg, FL
Posted: Tue Feb 03, 2015 11:45 am Post subject: |
I'd like to see some pics also.... Can't believe nobody is running these.. |
GraysonM Samba Member
Joined: July 17, 2013 Posts: 98 Location: United States
Posted: Fri Feb 06, 2015 12:27 pm Post subject: |
These folks tried them on their ghia, said the offset was no good:
http://shoptalkforums.com/viewtopic.php?f=51&t...e#p1148613
From the thread:
"Man, I was so happy to see those rims, unfortunately a 3.9" backspace on a 5.5" rim works out to ET17, so no joy for 914s, T3s, most supers etc.
(In fact that barely works on std T1s most of the time unless you run skinny tires, I hope they work on your Ghia)" |
Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Posted: Sat Oct 01, 2016 7:43 am Post subject: Re: Enkei Compe |
Bumping this back to the top.
I just ordered a set for my Super Beetle autocross project.
http://www.thesamba.com/vw/forum/viewtopic.php?p=8226726#8226726
I understand that with only an ET of 17mm, these will poke out about 1.5" wider that a stock wheel. I plan on buying wider fiberglass fenders, so they will work for my use.
I'm searched the internet, and I can't find anyone who's installed these on an air cooled VW. I guess I'll be the first to try them out??
elizer Samba Member
Joined: May 02, 2016 Posts: 1464 Location: Northern Virginia
Posted: Tue Oct 04, 2016 7:52 am Post subject: Re: Enkei Compe |
not sure what size you have, but these are 38 offset with 5.5 and seem like they would fit a t3
http://www.ebay.com/itm/191966074658 |
Posted: Wed Sep 12, 2018 9:44 pm Post subject: Re: Enkei Compe |
Here are some pics of my car with Enkie Compe's. Apologies for the rough car.... It was my daily in high school and I haven't gotten to finish the project. I always end up spending more time and money making it faster than I do making it nicer
Oh! To is on a 3.5" ball joint beam and is narrowed 1" each side in the rear. With empi disc brake kit (I think it adds maybe 1/8" offset) I had to "tap" the inner fender to stop the rub. It has literally 1/32" of clearance with a 195/50/15 in the rear.
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Sep 13, 2018 7:20 am Post subject: Re: Enkei Compe |
These 15" & 16" wheels are actually 7" wide & not good on lowered VW's. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
JDMbeetle Samba Member
Posted: Fri Nov 16, 2018 7:06 pm Post subject: Re: Enkei Compe |
this is my 1974 VW beetle with Enkei compe wheels
I chose these wheels because I wanted something different (and higher quality) than the empi gt-8s you see on a lot of cars. They also look more like the Watanabe wheels which I like.
my tire size is 185/65/r15 and ride height is stock
also if you plan on buying these wheels, the included Enkei center caps didn't fit over the threaded part of the rear hub (where the axle nut goes). I fixed it buy getting these deeper caps from mamotorworks. _________________ 71 Super Beetle
74 Standerd Beetle |
carlos_magnum Samba Member
Posted: Thu Nov 22, 2018 12:00 am Post subject: Re: Enkei Compe |
Nice wheels! I like their modern style with a touch of classic. |
Dugout5 Samba Member
Posted: Mon Dec 17, 2018 9:57 am Post subject: Re: Enkei Compe |
JDMbeetle wrote: |
also if you plan on buying these wheels, the included Enkei center caps didn't fit over the threaded part of the rear hub (where the axle nut goes). I fixed it buy getting these deeper caps from mamotorworks. |
I would like to put the white version of these on my 70 Bug. Did you have any issues with offset? |
Jude-steffen Samba Member
Posted: Fri Jan 18, 2019 9:51 pm Post subject: Re: Enkei Compe |
Dugout5 wrote: |
JDMbeetle wrote: |
I bought these wheels the other day and was wondering if the 185/65 tires look like they would fit if your bug was lowered 2.5 inches in the front and 1ish inch in the rear, thanks |
Posted: Fri Sep 20, 2019 2:16 pm Post subject: Re: Enkei Compe |
Hello, everyone!
I apologize for not replying sooner but I will try to answer your questions to the best of my ability.
I have not had any problems with offset, I don't remember exactly but I believe the wheels have a slight positive offset but it doesn't hurt the car in any way.
If you are going to lower your car I would recommend going with a tire with a shorter sidewall like what the person with the Ghia has. I remember having about 2 - 2 1/2 inches between the tire and inner rim when the front wheels were turned fully to the left or right.
I hoped I answered everyone's questions, I am planning on installing a front disk brake kit at some point so when I do I will update this thread. _________________ 71 Super Beetle
AdamNuggets Samba Member
Joined: March 09, 2017 Posts: 7 Location: Kalamazoo, MI
Posted: Sat Jun 27, 2020 4:13 pm Post subject: Re: Enkei Compe |
would these wheels have offset issues on a late type 3? _________________ 1971 Fastback |
