Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Sep 15, 2018 1:25 pm Post subject: Re: Oil Filler Tube Details |
pedro sainz wrote: |
OKType3Tim wrote: |
Here is my example of the wrong pipe on my T34.
I have to carefully "thread' the dipstick into the assembly due to the misalignment.
Can be bend in place
With your hand from the top little by little
Unless removed from case and bolt it on wood and bend it there
And fit it several time until lines up |
Or bend it by using a pipe that fits snugly inside. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
gregson1 Samba Member
Posted: Sun Sep 16, 2018 9:53 am Post subject: Re: Oil Filler Tube Details |
A couple of years ago I contacted Alex at ISP West and asked him if he had any Type 34 specific oil tubes available for sale. At the time, he wasn't aware of the differences and couldn't help me out. So, I mounted up my then empty engine case to the transmission with a spare oil tube securely mounted to the case with an old gasket. I mounted up the top tube into the body, then sighted down the inside and outsides of the tube to determine how it needed to be bent to fit. About 4 to 5 inches off towards the 5 'o clock position as viewed from the back of the car, if memory serves. I took the engine case out of the car and then inserted a big breaker bar into the mounted tube, then crouched on top of the case and gently pulled the top of the breaker bar towards the 11 'o clock position about 6 inches, then released pressure. I had some additional tweaking I did just to get perfection, but the gentle bending didn't break the tube or the welds. I then tested the tube with oil to make sure I didn't create a crack. I even heated it up really make sure. Then, I repeated the whole process on another powder coated tube, so I have a spare. I also checked to see that the gap between the top tube and bottom tube is appropriate for the rubber boot. Problem solved. |
pedro sainz Samba Member
Posted: Sun Sep 16, 2018 6:12 pm Post subject: Re: Oil Filler Tube Details |
This is ALL t34s. 3/8 away from the lip of the Shroud
This is ALL type 3s 1 1/4 away from the lip of the Shroud
You can easily see how much difference bend to the Right Side
Is NOT that much degree up and down
Is MORE left and right BEND
Long story Short
You can tell before installing the engine
On what model are you working ON
Thank You
😁 _________________ 68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There |
OKType3Tim Samba Member
Joined: April 30, 2011 Posts: 279 Location: Northeast Oklahoma
Posted: Sun May 17, 2020 6:56 pm Post subject: Re: Oil Filler Tube Details |
Perhaps the "K" stamp is for Karmann?
_________________ '69 Squareback restoration
'69 Fastback restoration
'66 Type34 |
