clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Thu Nov 16, 2017 9:54 pm Post subject: Re: Disc for the early bays |
I have the Bustang kit on my '70 Single Cab ... love it.
http://www.wagenswest.com/partstore/index.php/disc...stang.html _________________ Get ready for the injection
EverettB wrote: |
Make sure it is coherent. Rodney |
mharney wrote: |
I think Glenn has an EMPI crank in his engine. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Nov 19, 2017 4:36 am Post subject: Re: Disc for the early bays |
That's a bit steep for a guy on fixed income _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
lastchancevw Samba Member
Joined: August 26, 2008 Posts: 190 Location: Southeastern Mass
Posted: Mon Sep 17, 2018 7:11 pm Post subject: Re: Disc for the early bays |
So I guess this is as good a place on the Samba to hijack a thread.
I was also looking at those EMPI disk brake conversion kits that run about $900 or so. I may very well be the "guinea pig" that people were asking for, but I still haven't decided if that's the best route for me.
Long story short, here's my bus- Its a 1970 commercial kombi that was totalled in a passenger side front collision in 1973, and has been off the road since last fall, when I finally got around to welding in a replacement dogleg and trying to get the door pillars to line up. I managed to get everything ok, but it;s never going to be perfect.
i used my engine from my 71 westy, which I am retiring temporarily, and at this moment not pillaging for parts (i.e, I won't rob this car for it's disk brakes)
So, with the 70, I installed a new long brake line, rear tee and flexible lines in the back, and was surprised to find out that the original german master cylinder still worked.
but soon discovered that it leaks fluid, and the front cylinders leak, and one back cylinder leaks, and well, of course the brake shoes are at least 45 years old too.
So I'm in a position where it will cost several hundred to get all the parts left and right to make the drum setup work, or do i just spring the $900 for that EMPI kit? I've seen other kits like those Wilwood kits, but they don't come with a master cylinder so it seems like that Empi brake kit really gives me all I need, at which point I probably just would need one rear cylinder and I'll be well, way better off than what's going on now.
I know someone's gonna tell me to get a later front beam or whatever, but I want to keep my 70 fairly original,my axle beam is rust free, plus I'm in Mass so it's not like I can just pop over to a junk yard for one, and like i said, I don't want to pilfer my 71 for parts as I'm hoping to get back to it for a later restoration.. Plus, I also spent a bit of $ dismounting ant mounting the new in-2010 (and barely used) tires over from the 71 rims to some really nice original paint wide lug 70 rims, so it would be an additional cost to switch them back while at the same time incapacitating my 71 westy
There's one thing I can't figure out with the empi kits- they contain a new MC yes, but it seems like the reservoir and cap just go directly onto the MC. Are they kidding? How the hell am I supposed to check the fluid level? Can I use the two hose + brake reservoir in the car that the 70 has? I can't believe they expect you to get out of the car and climb under it to check your brake fluid level and somehow defy gravity just to top it off.
So yeah, I haven't bought the kit yet- here's a link to it.
https://www.jbugs.com/product/22-2940.html
When I compare it to sticking with drums and buying MC (pricey if I want the two brake switch setup) 2 front flex lines at least two front wheel cylinders/probably new shoes I know it's still cheaper to go drums, but the best I'll get it is still not as nice as disks...
Tara _________________ 1970 Commercial Kombi
1971 rusty Westfalia (retired for now)
1971 ghia (waiting)
1974 super beetle (2, maybe can be made into one)
1969 delta blue deluxe bus, half-camperized and being worked on |
airschooled Air-Schooled
Posted: Mon Sep 17, 2018 8:37 pm Post subject: Re: Disc for the early bays |
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Mon Sep 17, 2018 8:38 pm Post subject: Re: Disc for the early bays |
Oops, I forgot the switches. Add $40.
And the rubber lines, which you have to buy anyway since yours are not new.
Good luck, I’m on my second lap of the country this summer with my drums,
Posted: Mon Sep 17, 2018 10:21 pm Post subject: Re: Disc for the early bays |
Hmmm, when you itemize things out that way, it's almost as expensive as splurging for the disc kit...
however, you do make a compelling case that maybe I should give the drum system a chance, especially if at the very least, I spring for new shoes, pistons and an MC and front flex hoses. I think I have several spring kits and various other new and like-new brake bits and pieces like those adjustment wheels etc.
Why couldn't I re-use my old switches? Also, I see some places sell a 1970 master cylinder with provision for one switch, and it's a bit less expensive though you'll only be monitoring one circuit with the dash light.. Not recommended? or is that just a cheapo mc?
Seems like they still sell master cylinder rebuild kits but does anyone do that anymore? _________________ 1970 Commercial Kombi
1971 ghia (waiting)
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Mon Sep 17, 2018 11:21 pm Post subject: Re: Disc for the early bays |
lastchancevw wrote: |
... though you'll only be monitoring one circuit with the dash light.. |
No, the brake warning light is useless without two 3-terminal brake light switches. Keep in mind that most of the world
outside the U.S. did not think that two brake light switches or the brake warning light system were useful, and VW's sold there did not have them, except possibly as an option. _________________ '67 bug: seized by the authorities
