bruceduykers Samba Member
Joined: August 30, 2018 Posts: 12 Location: Sandpoint
Posted: Tue Sep 18, 2018 3:05 pm Post subject: Troubles with rebuilt MOFOCO ENG. HELP!! |
I fell in love with a beautiful restrored66, very little rust...thoight it drove well,shifted well, power..however before road test was over it bulked a little...the owners said they hardly drove it much..just gave it anything it might need. Well I bought it ,this was very orig. great finsh, new everything. Yep you guesssd it...mofoco rebuilt engine failed today after three weeks of ownership. And 1800 miles on it.....warrantee over of course.my mechanic..put engine in 3 yearsago...was tooo loud...drove very well tho. Talked to MoFoCo..and he said never have built a bad engine where CAM WAS BAD. MY MECHANIC SAID THAT WAS THE PROBLEM..NO COMPRESSION NO NOTHING., Now .
IT GETS SHIPPED BACK..Owner of FoMoCo said he’ll fix it on his dollar, Ill pay shipping. What a disappoint,,If it still isn’t right. What would you guysdo?. Price was great for this 66 bug...it looks brand new from dealership...but now is waiting for rebuilt to be Rebuilt....bruce |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13584 Location: Tejas!
Posted: Tue Sep 18, 2018 3:14 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
Roy is well known here, If he says he'll fix it, he'll fix it
you probably need to learn how to work on your VW, a mechanic is going to cost you a lot of money _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Emeraldlion Samba Member
Joined: April 13, 2005 Posts: 754 Location: Texarkana, TX
Posted: Tue Sep 18, 2018 3:31 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
| I agree with above. If he said he will check it out and fix then he is doing his part for his product. Roy is a very active member and their company has a long history with vw. Let him see it through for you and he will hopefully have some feedback on what may have happened so you can avoid any further issues in future. |
Joined: August 31, 2013 Posts: 13354 Location: North Carolina
Posted: Tue Sep 18, 2018 3:45 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
WOW, why are you getting bent out of shape? Most companies would say that the warranty was null & void since you weren't the original purchaser of the engine much less the fact that the warranty expired time wise. The very fact that he is willing to even contemplate warrantying it says a lot about MOFOCO. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Tue Sep 18, 2018 4:11 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
No compression, and it's a bad cam? Get a new mechanic.
I'm not sure why your bent here. Roy didn't build that engine for you. The PO could have slapped Roy's heads on a crappy short block to CLAIM the engine was built by them.
The fact that Roy said he would look at it is a favor to you. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80325 Location: Sneaking up behind you
Posted: Tue Sep 18, 2018 4:15 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
I recommend you post this in his feedback topic. That way others will see it when they look for feedback.
But... only after you've exhausted any private discussion. Because once you go public, there's no going back.
And most "high performance" engines have a driveway warranty... once they leave the driveway the warranty is over. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Tue Sep 18, 2018 4:19 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
| Glenn wrote: |
And most "high performance" engines have a driveway warranty... once they leave the driveway the warranty is over. |
The only feedback the OP could provide is that he bought a car with a possible MOFOCO engine, it broke, and Roy said he'd look at it for free. |
Glenn  Mr. 010
Posted: Tue Sep 18, 2018 4:25 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
| Pruneman99 wrote: |
Agreed... seems like good feedback to me.
Roy owes the OP nothing and is gong above to try to help.
BTW... i've seen a number of "mechanics" that know diddly about VW engines.
Did the mechanic do a leakdown test?
If you have a flat cam, you'll have 2 opposite cylinders with the valves not opening and no compression.
Just a few weeks ago, I had someone say he was running on 3 cylinders. The engine was also a few years old with very low mileage. We noticed that the #2 intake valve was not closing all the way. After removing the carb and using a borescope we could see the valve seat came loose and got jammed between the head and the valve. The "builder" said the warranty was over and offered nothing. BTW... it was a EMPI head. _________________ Glenn
Member #1009
#BlueSquare
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13957 Location: White Mountains Arizona
Posted: Tue Sep 18, 2018 4:51 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
MoFoCo is a straight shooting company. What validation do you have that the engine only has 1800 miles? When a purchase is made on a used anything suspect the worst.
No compression, how was that verified. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Tue Sep 18, 2018 5:06 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
Good rule of thumb in life:
If someone is doing you a favor, don't make them regret it. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
cbeck Samba Member
Joined: January 14, 2014 Posts: 2587 Location: high ridge, mo
Posted: Tue Sep 18, 2018 5:25 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
Could also be wrong oil or break in. Could just need valves adjusted. How did mechanic check cam? Shiney stuff in oil? _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33419 Location: Hot Arizona
Posted: Tue Sep 18, 2018 5:29 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
| Erik G wrote: |
| Roy is well known here, If he says he'll fix it, he'll fix it |
| Emeraldlion wrote: |
I also would be suspicious that a camshaft could cause total lack of compression, unless the gear rivets or bolts gave way, and I've never heard of that.
Roy from MoFoCo has offered to investigate even though long out of warranty period, take him up on that.
I bought a rebuilt transmission from Roy/MoFoCo April 2018 and have been very satisfied with both the product and the dealings with Roy and MoFoCo. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn  Mr. 010
Posted: Tue Sep 18, 2018 5:35 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
Years ago had a guy with no compression on #1 and #3. We dropped the old strainer and found the cause....
His cam was flat.
Tore the engine down and the intake lobe for #1 and #3 was almost round and lifters were badly pitted. _________________ Glenn
Member #1009
#BlueSquare
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
If I was Roy and read your post, I would immediately stop work on your engine, box it up nicely and let you know where to have it picked up. It’s apparent from your initial post that you’ll be a pain in his ass even if he goes out of his way to help you when he has zero liability to do so. I wouldn’t touch anything you sent me with a 10’ pole.
Good luck.
Edit: would like to add a link to this thread. You stated it ran poorly towards the end of your test drive and then you started having additional issues after buying it. My guess is, something was wrong when you bought it and the PO sold you a screwed up car. Further guessing your mechanic doesn’t know his ass from his elbow when it comes to ACVWs. Why else would he have you coming here to ask for help?
https://www.thesamba.com/vw/forum/viewtopic.php?p=8869326&highlight=#8869326 _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
Glenn  Mr. 010
Posted: Tue Sep 18, 2018 5:44 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
I think Roy will want to know what went wrong.
If it's not a parts or assembly issues, he should charge the OP for parts and labor.
Once sold a guy a distributor. 6 months later he contacted me that he had a problem with it and has his mechanic try to fix it. He couldn't and sold him a Chinese 009 instead. I told him he should of contacted me first and i would of tested it and fixed it at no cost but since his mechanic messed with it, he should send it back and i'll give him a full refund. I had to change the springs since his mechanic damaged them, but i rebuilt it and sold it to someone else a few days later. I asked the new owner to let me know if he has any problems. i heard back that it worked fine.
I could afford to buy it back since the out of pocket was minimal. Roy can't do that and 3 years later is beyond trying to keep a customer happy. The OP is not HIS customer.
OP... if you want I can remove this topic, just PM me. I think you'll be better off dealing with Roy in private. _________________ Glenn
Member #1009
#BlueSquare
Keith Samba Member
Joined: August 15, 2005 Posts: 3632 Location: Brodheadsville, PA
Posted: Tue Sep 18, 2018 5:47 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
| Sharp64 wrote: |
Good luck. |
Exactly! How the hell could anyone still bitch about a company where they are CLEARLY going above and beyond?!! I would do the same thing you say and just tell him to stuff it.
Curious, did you mechanic remove the valve covers and make sure the rocker arm assemblies weren’t just laying in the valve cover on one of the heads? Seen that happen a few times now. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Tue Sep 18, 2018 5:52 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
| Pruneman99 wrote: |
| No compression, and it's a bad cam? Get a new mechanic. |
Let me clarify this statement because after reading it, I think it was misunderstood.
It shouldn't take a compression test to find out your cam is flat. Doing a compression test in car is kinda a PITA, especially if you have big hands.
But what is easy, and takes 8 seconds is to pop the valve covers and roll the engine over. Oh crap, my valves aren't (or barely) moving. I don't then proceeded to do a compression test. That's like discovering your gas tank is empty, and rebuilding the fuel pump.
And losing total compression all at once, in all the cylinders? Yeah right |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11497 Location: Oregon
Posted: Tue Sep 18, 2018 6:04 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
Although Roy and I have personality issues with one another.
I cannot find any fault in his kind offer to repair your engine. Free!
Read that again. FREE!
What more could you ask for on an out of warranty engine that was built for a previous owner.
The shipping will be way cheaper than paying a mechanic to rebuild any engine. Plus you get a rebuild by (what many say here) a quality shop.
Don't look a gift horse in the mouth!
Take the deal and be very happy with it.
BTW. Find a new mechanic. There's now way he can tell you have a bad cam. Unless he measured the rocker throw to determine that the cam has flat lobes. But as stated above. That would affect two opposing cylinders.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11807 Location: Redding, CA
Posted: Wed Sep 19, 2018 10:40 pm Post subject: Re: Troubles with rebuilt MOFOCO ENG. HELP!! |
So, Roy is going to fix the engine “on his dollar”, and you come to a VW site and complain—where thousands of VW owners will see your complaint?
He supposedly rebuilt the engine three years ago—for someone else—and now it failed. Not when the previous owner owned it, but a few weeks after you bought it. You doubt Roy’s integrity, but not the previous owner’s.
How odd.
I’d love to have a builder offer to fix without charge some other owner’s (the original owner’s) engine after I bought it.
I suppose you want Roy to pay the freight? Is that the reason why you’re complaining here? Did you think complaining on this site would put more pressure on Roy to pay the freight, too?
Maybe I’m being too hard on you, but it seems you’re putting the horse before the cart. You might have waited until Roy got a chance to check out your motor—for free—before raking him out in a public forum where a number of potential customers would read about your issue and come away with a bad feeling about the builder.
Regardless, send off the motor to Roy; that’s my advice. Let him try to help you. And consider yourself lucky that he didn’t just tell you the warranty was shot and you’re on your own.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
