73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Wed Sep 19, 2018 8:28 pm Post subject: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
I'm currently using sealed beam headlights on my VW. I'm using the "xtravision" headlights, but one of my headlights has developed a leak and is letting water in. These lights are 55/60W, and not the "basic" Sealed beams our cars came with. Are h4 bulbs a worthy upgrade, or are these sealed beams comparable?
Here is what I currently have:
https://shop.advanceautoparts.com/p/sylvania-h6024...7CL3*15644
I'm wondering if I should replace with the same, or try out the H4s _________________ Daily driven....Slowly. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Wed Sep 19, 2018 8:54 pm Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
Max Welton wrote: |
I have never regretted switching to H4s.
Max |
Which ones are you using? Looks like they are all over the map in price. Not sure if that means the quality varies as well _________________ Daily driven....Slowly. |
docdanracy Samba Member
Joined: June 26, 2012 Posts: 1118 Location: Auburn, CA
Posted: Wed Sep 19, 2018 9:17 pm Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
H4 headlights
H3 55w fogs
Sylvania Silverstar Headlights
H3 55W fogs
_________________ Doc
1970 Sunroof Bug Yukon Yellow (L19K)
Custom 6.5x15” 914 Sport Wheels wrapped in 185x65x15 Contis
Empi shifter, full compliment of gauges, 1679 with mild cam, stock induction
SOLD: 1974 Marina Blue Standard Beetle undergoing restoration/preservation
1679 with Kadrons and header/QP
914 sport wheels 5.5" ET40 wrapped in 195x65x15 Kumhos |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Thu Sep 20, 2018 4:36 am Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
I run these, and love them. Huge difference, and they even come with quality bulbs-
https://www.amazon.com/HELLA-002395801-Halogen-Conversion-Headlamp/dp/B001G72SKQ/
I had an original set of Cibie Z-beams on my 61 Baja, and ran 130/90w bulbs. It was like landing a jet on the freeway at night, without any glare to oncoming traffic, they rocked! I hear the reproduction ones are good, but different due to regulations? Not sure. I may try a set at some point.
I also run a pair of these-
http://www.eagleeyelights.com/catalog2/index.php?m...cts_id=101
I use them occasionally, and really like them. They are sold individually, not in pairs, however. I really wanted them for the "look" but use them on crappy roads or in light rain/fog.
Life's too short to blindly feel your way down the road at night _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Thu Sep 20, 2018 6:17 am Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
The DOT pattern is horrible. The European H4 pattern is far superior with one exception, it doesn't have that familiar warm glow of light directly in front of the vehicle. This can be a bit problematic on those wet dark roads, especially with oncoming traffic using modern HIDs. This is why the fog lights are a common theme. However, the H4s will illuminate ANYTHING that is reflective for a mile or so down the road. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
74 Thing Samba Member
Posted: Thu Sep 20, 2018 6:41 am Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
That is a good deal for the Cibie 2 headlight and bulb set up (not sure what kind of bulbs though.
Rallylights.com usually has plenty of bulbs to choose from.
Make sure you are getting a full 12-13V at the headlight connection. If not clean the connectors, check the grounds, and add one relay for the low beams and another for the high beams. |
mark tucker Samba Member
Posted: Thu Sep 20, 2018 8:13 am Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
I went to the hella h4 crap...it was great for 3 years or so, them not so good... then I went to projector beams with led bulbs. awesome!!!!and lower power consumption!!! and cheep too!!! about $13 for the led's on flebay and around $18 for the projector bulb housings. non fluted works best with leds. also leds are directional and have to be "clocked" properly witch a lot of people do not do and complain about the light.... |
Posted: Thu Sep 20, 2018 8:59 am Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
mark tucker wrote: |
I hear that! Mofo's driving every morning with aftermarket LEDs that blind the heck out of everyone! |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu Sep 20, 2018 10:12 am Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
These Hella H4s are sold here in India for about $3/lamp. Sometimes avail on amazon.in _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Posted: Thu Sep 20, 2018 12:05 pm Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
the hellas that were on mine turened brown inside, no mo reflective.....thats when I went to the led&projector beams they are 5x better than the helas with hallogen were when new. and now less power draw too. |
Chris333 Samba Member
Posted: Thu Sep 20, 2018 12:16 pm Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
Funny when I think of custom headlights I only care about the way they look on my car. I could care less if they are brighter or not. I have never used my "brights". In fact when I had a New Beetle the brights and the headlights took the same bulb. When a main light would burn out I'd just take one from the bright spot and leave it empty.
And I do the majority of my driving at night (work at night).
I bought a set of H4 light for my 1968 Beetle. They had a tri-bar built into them with a blue dot in the center. Have no idea how long they will last, but they were the same price as sealed beams.
Posted: Thu Sep 20, 2018 4:25 pm Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
Chris333 wrote: |
Funny when I think of custom headlights I only care about the way they look on my car. I could care less if they are brighter or not. I have never used my "brights". In fact when I had a New Beetle the brights and the headlights too the same bulb. When a main light would burn out I'd just take one from the bright spot and leave it empty. |
So you are all about form over function?
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Posted: Thu Sep 20, 2018 7:20 pm Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
Chris333 wrote: |
My bug is my daily. I drive a lot in inclement weather, in complete and utter darkness, in the woods. Great headlights are a must for me. I don't want to hit a deer in the middle of the night. Also, great lookimg car! _________________ Daily driven....Slowly. |
Posted: Thu Sep 20, 2018 7:22 pm Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
Lingwendil wrote: |
Life's too short to blindly feel your way down the road at night |
I like those fogs. Im thinking h4s plus fogs will be a great improvement _________________ Daily driven....Slowly. |
Posted: Thu Sep 20, 2018 8:22 pm Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
Most definitely! That’s what I run.
Posted: Fri Sep 21, 2018 1:05 am Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
I just like the way they look and can see fine with them. If they were some how brighter that might even bother me.
I would like to mount some amber fog lights once I get the bumpers on. Again just so I can see my car with fog lights not because I need more light.
In case it matters. Those lights I posted also have LED halo rings around them, but they are only at the top and bottom so when they light up the sides are very dim. I thought it looked like crap so I didn't wire them up. If I find cheap halos with LEDs all around I might try again. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Fri Sep 21, 2018 7:21 am Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
Aren't you still building this car? Or are you now driving it?
Chris333 wrote: |
_________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Fri Sep 21, 2018 9:07 am Post subject: Re: Are H4 headlights an upgrade over the "Bright" Sealed beams? |
Still building.
Based my comments on my daily Honda. A lot of people put the Honda headlights in an oven to separate them and then add projector lights inside. Put new rubber around the edges and pop back into the oven to re-seal it.
Just posted the VW pic because they are H4 bulbs. |
