dstimm Samba Member
Joined: June 29, 2018 Posts: 153 Location: Encinitas, CA
Posted: Thu Sep 20, 2018 7:49 am Post subject: Allen oil drain plug stripped |
I went to do my first oil change on my (new to me) 1979 Bus. However when I attempted to remove the 6mm Allen drain plug, I noticed it was stripped and the PO probably removed it in the past with vice grips.
I want to replace this with a proper nut. Will this one work for the bus?
http://www.busdepot.com/n0297012
thanks! _________________ 1979 Sage Green California Westy. |
Posted: Thu Sep 20, 2018 9:00 am Post subject: Re: Allen oil drain plug stripped |
It says '72-79, so yes. |
Randy in Maine Samba Member
Posted: Thu Sep 20, 2018 9:47 am Post subject: Re: Allen oil drain plug stripped |
Buy some spare copper washers while you are at it, like 10. |
dstimm Samba Member
Posted: Thu Sep 20, 2018 10:39 am Post subject: Re: Allen oil drain plug stripped |
Randy in Maine wrote: |
haha, I actually ordered exactly 10. Now I have the challenge of removing this stripped plug, hopefully I can use the vice grips. No use trying until I receive the new plug. _________________ 1979 Sage Green California Westy. |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Thu Sep 20, 2018 6:38 pm Post subject: Re: Allen oil drain plug stripped |
Maybe try spraying the Allen with pb-blast to get all the grime out. Then maybe see if the Allen wrench will go a little deeper?
Last resort, go one Allen size bigger, LIGHTY tap with hammer to create “new” spot for it to grab onto? See if you can make any progress getting it out. _________________ 77 Westy - Cape Cod Sage
LLAP |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Fri Sep 21, 2018 8:22 am Post subject: Re: Allen oil drain plug stripped |
There is plenty of meat on that internal hex to screw it out.
Make sure you are using a real tool of hard steel, no Harbor Freight, Lowes , or cheap crap.
If you cried when you bought it, it will work _________________ .ssS! |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Fri Sep 21, 2018 5:08 pm Post subject: Re: Allen oil drain plug stripped |
The two comments above are a great starting point.
I will add that using US allen socket might be an in between size that fits the oversized hex. Get it scrubbed clean.
Another option is pull the plate, clean the strainer, and put it back with new gaskets and then new oil. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
timvw7476 Samba Member
Posted: Fri Sep 21, 2018 7:55 pm Post subject: Re: Allen oil drain plug stripped |
Take your time, find an allen that fits tight if you don't get a decent fit,
popping the strainer is a perfect work around, there'a a 'kit' consisting of
two gaskets & one copper crush washer for the strainer plate retaining nut.
The trick is to put the crush washer on seam side out,snug it down till it
yields just a touch,then make sure that nut is run down to 9 foot pounds.
The cross bolt that holds the oil pickup in the case cannot take more than
9 FOOT POUNDS. When you snug the strainer nut, it is pulling on that single
case bolt & threaded boss in the engine case. Quite fragile. |
dstimm Samba Member
Posted: Thu Sep 27, 2018 5:00 pm Post subject: Re: Allen oil drain plug stripped |
It's out! Thanks aeromech! _________________ 1979 Sage Green California Westy. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Fri Sep 28, 2018 12:23 pm Post subject: Re: Allen oil drain plug stripped |
Air hammers are great
New drain plug
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
