KhakiMan Samba Member
Posted: Sat Sep 22, 2018 4:58 pm Post subject: Bosch Voltage Regulator question |
Just had a new Bosch VW Voltage Regulator (12 Volt for GR15,16 & 17 Generators) installed in my 69 coupe to fix a voltage issue. In looking at the work order from the mechanic, his not says that a digital voltage regulator requires the car to be driven/started every day.
Is that true? Would a 'digital' regulator drain a battery that much?
Thanks _________________ -----
'69 Coupe |
jason_hamilton Samba Member
Joined: February 07, 2003 Posts: 1118 Location: Abbotsford, BC
Posted: Sat Sep 22, 2018 5:31 pm Post subject: Re: Bosch Voltage Regulator question |
I've never heard that.
Back in the mid 90's I had a solid state Bosch regulator out of a Mercedes in my engine bay and never had a problem. _________________ Jason Hamilton
1969 Karmann Ghia coupe
@MiddleAgedHoon |
Posted: Sat Sep 22, 2018 5:37 pm Post subject: Re: Bosch Voltage Regulator question |
I've never heard of that either. Battery is relatively new, so I won't worry about it until it won't start, but I suspect I won't have a problem.
'69 Coupe |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
xzener Samba Member
Posted: Sat Sep 22, 2018 6:14 pm Post subject: Re: Bosch Voltage Regulator question |
Would that be 400 millionths? I don't think there is anything to worry about. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sun Sep 23, 2018 5:55 am Post subject: Re: Bosch Voltage Regulator question |
Quote: |
I measured 0.00000004 amps. |
Really? The resistance in the wire of the meter leads would have that much of a current draw. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
