narrowfarm Samba Member
Posted: Sun Sep 23, 2018 3:23 am Post subject: 1300cc single port manifold |
Hello, I just received an EMPI engine gasket kit for the 1300cc-1600cc, 1963 to 1979 kit , type 1 2 and 3 .
I was installing the new intake manifold copper ring to the cylinder head. The copper ring measures 1.5 inches diameter with my calipers. The copper ring seems just a little bit to big as it doesn't sit in the cylinder head real nice like I expected it to.
Does anyone know if this is the correct size for the 1300cc engine? Does the ring compress as I tighten?? I do believe they do compress that is why you don't reuse them to avoid air leaks. I don't have the old copper rings to compare to. Just thought it would fit better in the cylinder head..... |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Sun Sep 23, 2018 5:24 am Post subject: Re: 1300cc single port manifold |
A full gasket kit has several different size O rings. They should pretty much drop down into the hole in the head. Getting a single port to seal well is not always trivial and the last thing you want it the manifold not sitting in the hole propely. Never ran into your problem, but I have always bough Ehrling gasket sets. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Sep 23, 2018 12:48 pm Post subject: Re: 1300cc single port manifold |
Well my gasket kit looks like it was shorted the copper rings for my intake manifold..... The picture in his ebay add shows different sizes of copper rings and I just got two larger ones. The person who sold me the kit has not responded to me yet..... |
mukluk Samba Member
Joined: October 18, 2012 Posts: 6985 Location: Clyde, TX
Posted: Sun Sep 23, 2018 1:26 pm Post subject: Re: 1300cc single port manifold |
Measuring several brand new single port seals I have on hand show them all to be right at an inch and a half diameter when measured on the outside, so it sounds like you have the correct seals. Installing the seals in the head is a bit of a tight fit and may require a slight amount of finagling to get the seal to seat down in the groove all the way 'round, but first you should ensure that you don't still have an old seal installed and that the groove is cleaned out. The seal groove should have a squared profile and no noticeable seam or line running parallel to the intake port -- presence of a lip or line and a beveled or rounded profile indicates at least one old seal is still residing in the groove.
Seal groove without seal installed:
Seal groove with new seal installed:
_________________ 1960 Ragtop w/Semaphores "Inga" |
mukluk Samba Member
Posted: Sun Sep 23, 2018 1:57 pm Post subject: Re: 1300cc single port manifold |
Found a picture in the gallery where an old seal is still installed. It's very easy to see in this pic since the old seal is copper, but many seals were silver like the ones I have and easily blend in with the colour of the head.
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 469 Location: Illinois
Posted: Sun Sep 23, 2018 5:35 pm Post subject: Re: 1300cc single port manifold |
I have some extras I would be happy to mail to you at no cost. PM me if interested. Casey _________________ 1966 Java Greens |
Posted: Fri Sep 28, 2018 7:15 pm Post subject: Re: 1300cc single port manifold |
Thanks for the photos mukluk! just what I was looking for. I see that there was still in my cylinder head an old copper gasket. I noticed it right before I went to work tonight. I have to get them out and install the new ones! Also thanks to diablosandwich , I will keep that in mind your offer to keep my VW going!!! Thanks again everyone for your help!!! |
estilholliday Samba Member
Joined: November 07, 2013 Posts: 54 Location: Delaware
Posted: Thu Nov 08, 2018 5:49 pm Post subject: Re: 1300cc single port manifold |
diablosandwich wrote: |
I have some extras I would be happy to mail to you at no cost. PM me if interested. Casey |
does that offer extend to others? got a gasket kit with no intake seals included... |
