pushkick Samba Member
Posted: Sun Sep 23, 2018 5:08 pm Post subject: gw new ecu efi |
does this new system allow flex fuel options? will it run on ethanol? propane etc? _________________ i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Sun Sep 23, 2018 5:23 pm Post subject: Re: gw new ecu efi |
Sounds like a question for GoWesty... _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Sun Sep 23, 2018 8:01 pm Post subject: Re: gw new ecu efi |
Pushkick, have you tried E85 in your Van?
I've used E85 very, very close to 100% in my 89. It had been sitting for about 18 months and would not start when I purchased it. I got it running but with a lot of rough idle, even after replacing sensors, plugs, etc. So, I decided to dump in some fuel additives. After looking at price, contents, snake oil syndrome, etc., I thought well, maybe a dose or two of E85 would do just as good. The engine did improve performance. However, the richer blend knocked off MPGs and power. But, today, it starts and idles just fine.
I'm sure the Digifant system was doing some adjusting to deal with the swing in variables that the E85 brought on. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon Sep 24, 2018 8:13 am Post subject: Re: gw new ecu efi |
Yes check with GW. Some standalone systems have a sensor to determine the E85 mix ratio and can adjust. GW can advise you if their system has that capability.
Otherwise as a rule, you could run E85 with a stock VW system, but I would expect you'd need to increase the fuel pressure with an adjustable regulator, or larger injectors to get similar power, which should lessen the mpg some. _________________ ☮️ |
