Tizian Samba Member
Joined: February 18, 2015 Posts: 383 Location: Hamburg, Germany
Posted: Thu Sep 06, 2018 11:53 pm Post subject: Correct Headliner for 1967 Samba |
Hi Bullis,
this is my frist thread at the Samba although I have been reading for years now! So high time to contribute a little.
I am about to do some testing with digital printing on vinyl and this is what I am planning to do:
Get some correct headliner material in wolkenweiß (which should be cloud white in English) and correct texture, or at least try to match best.
Create a digital dot pattern.
Make some testing in printing and veryfication on dots and color and durability.
Printing method is already developed and applied on various products. So the testing will be mostly limited to the specific headliner material if the print is durable or not.
Get some of the vinyl printed and the rest perforated.
Take all the material to my headliner specialist who has the correct sewing patterns as per original.
Get it installed.
Now sounds like a plan but surely will be a demanding one.
Unfortunately my original headliner got scrapped. So I have to recall which portions were printed an which were perforated. I remember the sunroof headliner to be printed. The ones which were glued to the body and panels were printed. How about the rest? Above drivers seat to the air channel and rear part. Were theese the only ones to be perforated? I can’t remember. Or was the whole headliner printed for the 67 samba? Does anyone have images of the original?
I’ll keep you updated on my testing results...
Grüße
Olli
Tizian Samba Member
Posted: Fri Sep 07, 2018 1:07 am Post subject: Re: Correct Headliner for 1967 Samba |
These are some images of the original before it got torn out:
None of those look perforated to me...
Olli |
Tizian Samba Member
Posted: Fri Sep 07, 2018 7:05 am Post subject: Re: Correct Headliner for 1967 Samba |
Here is the correct pattern.
I got confirmation that the headliner was all printed... Does everyone agree on that?
I meassured the pattern on one of my ragtop bows. These strips of liner are glued on the bows for protective purpose only and the pattern's orientation is rotated by 90 degrees in comparison to the actual liner in the car.
So point to point distance transversal is 15mm and longitudinal 10mm.
Point diameter is 1.2mm
ozinbc Samba Member
Posted: Fri Sep 07, 2018 7:33 pm Post subject: Re: Correct Headliner for 1967 Samba |
good luck with the project- lots of interest in the non perforated lining. The perforated head lining began at the rear of the sunroof to the rear hatch. Presumably condensation towards the rear explains why?
Everything towards the front was black dot only. _________________ the invisible and the non existent look very much alike |
Tizian Samba Member
Posted: Mon Sep 10, 2018 2:14 am Post subject: Re: Correct Headliner for 1967 Samba |
Thanks!
I heard that there also was an all printed version. Can anybody confirm? |
Tizian Samba Member
Posted: Mon Sep 10, 2018 8:00 am Post subject: Re: Correct Headliner for 1967 Samba |
Here comes the digital repro...
Let’s see how the print turns out...
Olli. |
ted698 Samba Member
Joined: June 17, 2016 Posts: 104 Location: Shropshire, UK
Posted: Thu Sep 13, 2018 2:47 am Post subject: Re: Correct Headliner for 1967 Samba |
OK - not a Samba - but I have a 1967 11w non sunroof and everything in the bus is printed dot pattern except the last panel in the headlining, which starts at the rear of the last window to rear hatch, and that is fully perforated.
It took me years to realise this, and in fact someone pointing it out to me on a forum and I didn't believe them until I saw it with my own eyes!
I've never known why just one panel is perforated and all others are dot printed |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Thu Sep 13, 2018 11:05 am Post subject: Re: Correct Headliner for 1967 Samba |
This has been my take on it but only my opinion. The painted dot areas were where either wind from the sunroof or moisture condensation could drip onto a passenger. The perforated area was to provide ventilation to dry the condensation. The painted dot areas where glue is don't let the glue seep out the holes. I think different years had mixed perforated and painted areas. |
Tizian Samba Member
Posted: Fri Sep 14, 2018 6:28 am Post subject: Re: Correct Headliner for 1967 Samba |
BarryL wrote: |
Yes, convincingly! I got one more confirmation from another member with OG headliner installed. So I am going for this version.
My headliner maker gave me some raw material without perforation he uses for the bus headliners and a sample with perforation.
Unfortunately the texture doesent really match the original as all repros. The original had a more regular bumpy pattern whereas the modern repros are more like leather imitations.
But for the proof of concept I'll go with this one in the first step.
Maybe someone has a source for a better matching raw material?
Here the repro Material:
The digital repro:
And maybe we can even print solid colors:
Tizian Samba Member
Posted: Sat Sep 22, 2018 1:08 am Post subject: Re: Correct Headliner for 1967 Samba |
Printing tests are done...
Dot print vs perforation
Solid color
The print turns out a bit glossy
Did some cleaning tests.
1. Water and soap: No problems at all
2. Cleaning solvent based on petrol: If not rubbed firmly the print withstands even that and dries up leaving no traces!
3. Alcohol: like 2.
All in all not too bad in my opinion!
BarryL Samba Member
Posted: Sat Sep 22, 2018 12:00 pm Post subject: Re: Correct Headliner for 1967 Samba |
Wow great effort producing that product. Do you know how the original dots were applied? Where they done with a pressure or with a spray? How are yours applied if you are allowed to divulge? What is the black (or color) made out of? |
Tizian Samba Member
Posted: Sun Sep 23, 2018 5:09 am Post subject: Re: Correct Headliner for 1967 Samba |
BarryL wrote: |
Thanks!
I believe that they must have used a rotary offset printing method, since they were producing tons of this material in earlier days. The manufacturer was Benecke which still exists today.
I found a printing shop who specializes in digital printing on leatherlike materials. She uses plotters and flatbed printers. In this case we chose the plotter and I believe those inks must be of some kind of special textile sort. But that is her wellkept secret...
But anyhow this method seems very promising and you can produce very small batches up from 1m. That‘s the good news. And if we could find an exact match of the raw material texture it could be perfect.
Cheers!
Olli
ozinbc Samba Member
Posted: Mon Sep 24, 2018 1:59 am Post subject: Re: Correct Headliner for 1967 Samba |
Can I second what a great effort this is. I have a complete NOS headliner for the later split bus- black dot used on all areas where glue was used. The perforated section was only to the rear of the sunroof- I have a 21 window, and was the roof section only. The sliding roof liner is black dot.
When I get it out I will take a pic of all the bits unmolested. It will soon no longer be NOS. _________________ the invisible and the non existent look very much alike |
Pau Samba Member
Joined: April 09, 2002 Posts: 341 Location: Euskal Herria
Posted: Mon Sep 24, 2018 4:40 am Post subject: Re: Correct Headliner for 1967 Samba |
yesterday I saw with my eyes that dots are printed. Only last panel has holes (have a 1967 21window as well)
Thank you for teaching! Keep on your progress, maybe one day I will need your headline due to mice nesting...
Vielen dank! _________________ Freedom for the Catalan Countries
Si ens destrossen les contrades alçarem les barricades !!*!! |
Tizian Samba Member
Posted: Mon Sep 24, 2018 6:56 am Post subject: Re: Correct Headliner for 1967 Samba |
Thanks everyone! This is great help!
And just for the sake of completeness: The direction of the front part (front edge of sliding roof forward until sunvisors) is rotated by 90 degrees compared to the other bits. So here we have the smaller dot spacing going in direction of the cars width vs. the rest is orientated longitudinal. Not nice but original.
Grüße |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Mon Sep 24, 2018 6:09 pm Post subject: Re: Correct Headliner for 1967 Samba |
FWIW, my 65 standard transitions at the back of the front most popout.
ozinbc Samba Member
Posted: Tue Sep 25, 2018 6:42 am Post subject: Re: Correct Headliner for 1967 Samba |
Hi zozo - does your bus have 6 pop outs? I thought standards had pop outs at the level of the rear seat only? _________________ the invisible and the non existent look very much alike |
zozo Samba Member
Posted: Tue Sep 25, 2018 7:45 am Post subject: Re: Correct Headliner for 1967 Samba |
ozinbc wrote: |
Hi zozo - does your bus have 6 pop outs? I thought standards had pop outs at the level of the rear seat only? |
Yes, six. There seem to be various configurations from the factory. I've seen them with 2, 4, and 6. |
Tizian Samba Member
Posted: Tue Sep 25, 2018 7:58 am Post subject: Re: Correct Headliner for 1967 Samba |
zozo wrote: |
zozo, you are telling me the perforated part starts approx. after the middle seat? Correct? That’s interesting... |
zozo Samba Member
Posted: Tue Sep 25, 2018 11:00 am Post subject: Re: Correct Headliner for 1967 Samba |
Just in front of the middle seat. That window you see in the pic is the first popout, just behind the bulkhead.
Just above my dogs tail.
