Cold engine - output drops so low for a brief period. Ideas?
IdahoDoug
IdahoDoug is offline
PostPosted: Mon Sep 24, 2018 4:24 pm    Post subject: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
In the last month or so, the van has been exhibiting a strange symptom. It's had a recent tune, fuel pump, filters and such and the oxygen sensor has been disconnected for over a year. It was also rebuilt a few thousand miles ago, so grounds have been cleaned, injectors cleaned, etc. It's been running like a top.
Here's what happens. Only when cold. I'll start the van and pull out of my driveway. About 15 seconds later, I arrive at a stop sign and the engine is very low RPM as if it wants to stall (automatic). Pressing the gas gives a slight change to the engine note but hardly any power. Flooring it doesn't change anything either. It will barely roll out away from the stop sign at about the same pace as if a couple buddies were pushing it away from the stop sign. Almost feels like it's flooded. Instantly putting it in neutral, it will barely rev with a lot of throttle when it should rev instantly. When it gets up to a couple thou RPMs it seems to clear its throat and I can rev it up and down as normal. Put it back in gear and it pulls strongly as normal.
Any thoughts? I'll be putting a new prefilter on it to replace the one that's been on it for the 3000 or so miles since the rebuild. More out of curiousity because I can see some sediment in it.
Thanks.
DanHoug
DanHoug is offline
PostPosted: Mon Sep 24, 2018 4:32 pm    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
my first guess is a mixture issue.. i'd really hook a good O2 sensor back up. but, barring that, you might want to play around with your AFM spring tension. mark where the clip is now with a dot of paint/white out then move the black disc one or two clicks counter clockwise. this will richen things up. drive it and if worse go 1 or 2 clockwise from base position.
i've found that during open loop running, when the engine is first started, that this adjustment is critical to acceleration off idle. once the O2 sensor heats up, it doesn't seem to make too much difference.
-dan
www.thefixitworkshop.com
Abscate
Abscate is offline
PostPosted: Mon Sep 24, 2018 5:45 pm    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
Possibility. If excess cold start fuel washes oil off the cylinder walls, you lose compression and will idle with no power. I don’t think it happens to boxer engines but it’s well documented in BMW and Audi.
Google lawn mower or holiday syndrome for more.
Wildthings
Wildthings is offline
PostPosted: Mon Sep 24, 2018 6:45 pm    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
I wouldn't think it would be O2 sensor related as the TSII sensor is likely not reporting that the engine is hot enough for the system to go closed loop.
danfromsyr
danfromsyr is offline
PostPosted: Mon Sep 24, 2018 6:52 pm    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
TS-II could be faulty and reporting a warm engine too soon.
measure values at cold.. then at the end of the block when it stalls.
I've been meaning to make a TS-II jumper pig tail for on the fly meter readings.
Abscate wrote:
These are the reasons we have words like β€œwanker”
IdahoDoug
PostPosted: Mon Sep 24, 2018 7:46 pm    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
FYI - O2 sensor has been disconnected for over a year and it's been running like a champ. Not sure if all of you saw that. Carry on.
DanHoug
DanHoug is offline
PostPosted: Tue Sep 25, 2018 4:37 am    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
since it was running great then changed rather quickly, i'm giong to withdraw my AFM suggestion... the spring tension doesn't change radically like that, tho it is always useful to tune it. the wiper arm might need a cleaning however.
i'm going with the TSII also, that just makes sense but also consider running some Techron thru your system in case the injectors are getting dodgy.
-dan
AZ Landshaper
AZ Landshaper is offline
PostPosted: Tue Sep 25, 2018 5:00 am    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
x2 vote for the fuel mixture.
any black smoke as you accelerate from the stop?
Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug.
dougass
dougass is offline
PostPosted: Tue Sep 25, 2018 6:38 am    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
I have very similar issues when cold. I have not done much exploration regarding wiring, however, I have replaced most of the components related to air-fuel mixture. Runs fine after a minute or so...
Was considering sending injectors out for a cleaning until I saw Marco's :high performance injectors". Will let you know if this resolves it.
'91 GL - 2.1 automatic named Klaus for weekend adventures.
#klausvan & @thisisklausvan
jlrftype7
jlrftype7 is offline
PostPosted: Tue Sep 25, 2018 6:55 am    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
I too want to know what the ECU is seeing out of the Temp Sensor- If the reading is good for the known engine/coolant temp, I'd try adding a 270 ohm resistor in line to the wiring of the Temp sensor, and if that didn't get rid of the hiccup, I'd remove it and try a 560 ohm resistor in its place.
β€˜84 Tin Top - Hilga....Auto
danfromsyr
PostPosted: Tue Sep 25, 2018 6:58 am    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
quick question re: the resistor, do you add it to the GND side or the ECU side of the sensor?
jberger
jberger is offline
PostPosted: Tue Sep 25, 2018 7:54 am    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
Why is your o2 sensor disconnected? I would suggest that the overly rich running that happens with the sensor unplugged is masking other issues. At your elevation I can't imagine it would run well at all without the Lambda feedback... all things being in good working order.
J
IdahoDoug
PostPosted: Tue Sep 25, 2018 8:14 am    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
Last summer we were up in Canada and the van was struggling climbing hills. Someone here recommended I just disconnect it and run rich. I don't have any test equipment other than a multitester, it worked great (immediate change) and I've just left it that way even though I'm getting 15mpg.
On the tailpipe cloud - I'll watch for it today. Also, my fuel injectors were professionally cleaned a few thousand miles ago.
Doug
Abscate
Abscate is offline
PostPosted: Tue Sep 25, 2018 8:38 am    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
If its just a resistance measurement it should not matter.
Series resistances just add, so where it is in the circuit doesn't matter as long as its between ground and the measure point (at the ECU)
Wildthings
PostPosted: Tue Sep 25, 2018 9:50 am    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
With the pedal to the floor the O2 sensor should not have any effect on how it runs, but it would at part throttle. I am thinking that you may have an out of spec TSII sensor and a bad TPS. Both would throw the mixture off when at full throttle climbing a hill and would throw the mixture off when you decelerate when cold while approaching a stop light or sign.
Disconnecting the O2 sensor would also mask a misfire. Since the misfire would likely be worse on a cold engine than a hot one this could also be your problem.
jlrftype7
PostPosted: Tue Sep 25, 2018 11:13 am    Post subject: Re: Cold engine - output drops so low for a brief period. Ideas? Reply with quote
Abscate cover it for you-
I worked at a Bosch Service Center for a short time before working at a BMW dealer. Bosch would often have 'little' fixes for their fuel systems that corrected weird warm-up or driveability issues.
They and BMW were having Techs install those two value resistors for both Cold Start issues or driving away right after start-up.
It will make your HOT engine value slightly elevated for what resistance the Temp Sensor would have normally had at fully warmed up, but somebody in Germany figured out that these low ohm resistors wouldn't create any new problems of their own.
The 270 was generally for smaller engines, and the 560ohm for larger ones, or whatever fixed the issue... Razz
If they don't help, they're easily removed and you go back to stock wiring and more diagnoses time
SAAB went a different route with their CIS temp reading on the 8 valves engines that had CIS and not L-Jet or LH.
A bit more involved, but basically the same effect, keeping the enrichment going a bit longer than stock to reverse driving issues when cold.
Back in the day, a lot of it was to combat carbon build-up on the intake valves that leaned out a cold engine with the carbon absorbing the fuel spray from the injectors instead of getting into the cylinder properly.
With the OP's recent parts and rebuild, I'd be surprised if there was any valve deposits on such a recent rebuild- should be 1 less thing to worry about.
