2mAn Samba Member
Posted: Sun Sep 23, 2018 6:46 pm Post subject: How much power do you think this Type4 motor makes? |
Obviously this is very difficult to estimate, but Im hoping to get a decent ballpark figure from you guys.
Thanks
The spec list:
2165 cc Type 4 Porsche engine by Precision Motorwerks
Porsche 2.0L heads
JE pistons, 94mm
Scat forged crankshaft 78 x 2.0
Carillo Rods
Fat Performance stainless steel valves 44 x 38
Fat Performance FC443 Camshaft .507 lift, 290 dur
Fat Performance cam gear, followers, retainers
Fat Performance dual valve springs
Fat Performance cam followers
Weber 44idf Carburetors _________________ function follows form |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Mon Sep 24, 2018 8:02 am Post subject: Re: How much power do you think this Type4 motor makes? |
140hp _________________ Steve
Steve's 87 Syncro project |
2mAn Samba Member
Posted: Mon Sep 24, 2018 9:04 am Post subject: Re: How much power do you think this Type4 motor makes? |
Thanks Steve
Ive seen numbers anywhere from 120-160, but nothing concrete and those could all be variances in similar displacement, cam, carb changes...
overall it seems safe to say that a FAT motor is likely to be pretty quick and torquey, but Im not knowledgeable enough to guess based off spec'd parts. _________________ function follows form |
Posted: Mon Sep 24, 2018 10:06 am Post subject: Re: How much power do you think this Type4 motor makes? |
What exhaust system? _________________ Steve
2mAn Samba Member
Posted: Mon Sep 24, 2018 11:07 am Post subject: Re: How much power do you think this Type4 motor makes? |
Steve Arndt wrote: |
What exhaust system? |
Its not listed, but Im pretty sure the exhaust is a HUGE factor in the power output with aircooled motors, right? What would be an ideal setup for this setup? Its a car thats for sale that Im considering buying _________________ function follows form |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6032 Location: CONGERS, N.Y.
Posted: Mon Sep 24, 2018 11:16 am Post subject: Re: How much power do you think this Type4 motor makes? |
Can be between 140 and 160, but the real difference is the feeling of torque thru the entire range.
I have 115 to 120, 140 to 160 has got to be amazing.
But as I mentioned many times my engine was room a 914 that had a top speed of 127mph and my bug is a lot lighter. But after 90 mph the bug lifts and steering lightens. So for an average bug 0 to 90 is your playing field. My real power is shown between 50 and 90 _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Posted: Mon Sep 24, 2018 12:07 pm Post subject: Re: How much power do you think this Type4 motor makes? |
A1 Exhaust or Tangerine are the best exhausts. _________________ Steve
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
2mAn Samba Member
Posted: Mon Sep 24, 2018 1:34 pm Post subject: Re: How much power do you think this Type4 motor makes? |
I finally got a reply...
"Don't know manufacturer of the headers or the muffler that is on it for street use (taking the straight pipe off).
Approximate HP max at rear wheels just shy of 120 at 5750 rpm and approximate max torque 250 lbs ft torque at 4000 rpm."
I asked if the torque was a typo and he said it was confirmed on the dyno! _________________ function follows form |
2mAn Samba Member
Posted: Tue Sep 25, 2018 1:16 pm Post subject: Re: How much power do you think this Type4 motor makes? |
Ive seen many dyno plots but this one looks strange to me... am I freaking out for no reason???
