Larmo63 Samba Member
Posted: Sun Sep 02, 2018 11:02 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
Next was getting the hinges off of the door, which proved to be a hassle as another two stuck screws needed persuasion. All screws out, door panel off, cleaned up the door for new rubber weather strip.
_________________ Lawrence
‘61 Mango Green Single Cab
'62 Pearl White Ragtop sedan
'66 Ruby Red Cabriolet
'86 Porsche 911 Carrera |
Posted: Sun Sep 02, 2018 11:03 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
The old lower hinge is trash. I doubt it can be repaired or rebuilt. The upper looked salvageable.
Posted: Sun Sep 02, 2018 11:05 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
Hinges on, screws tightened, door panel and door seals glued in place, let's throw that sixty pound door back on....
Posted: Sun Sep 02, 2018 11:08 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
All's well that end's well, I'll fiddle with the striker adjustment some more, but my baby is back together in much better shape. I forgot to mention I did do a new door catch/roller kit in this door too, and I'll do the passenger door next along with new seals.
Posted: Sun Sep 02, 2018 11:20 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
I forgot to ask, how does the door seal attach at the upper corner where the hole is?
Anybody? Can someone explain? Pics? _________________ Lawrence
Posted: Tue Sep 04, 2018 10:44 am Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
Can someone post an up close picture of how the rubber door seal attaches to the top of the door above the latch?
There is a hole there, is there supposed to be a screw or some sort of fastener?
Thanks in advance. _________________ Lawrence
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Tue Sep 04, 2018 3:40 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
No fastener at that top hole. The door seal has a rubber "ball" at the top end. You lube up that ball, then fully push it into the hole. Apply contact cement to the seal from the ball downwards so that it stays in place on the door. |
Posted: Tue Sep 18, 2018 12:11 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
I have a couple of originality questions:
Are these the correct color heat control knobs for a '66?
Was there a Karmann Ghia specific e-brake boot for KG or do I just have the wrong year boot pictured here? The original on my car has the screw holes worn into it, I bought a solid used replacement, but the "snout" of it is shorter.
I know these are small details, but does anybody here know?
Rome Samba Member
Posted: Tue Sep 18, 2018 3:17 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
Lawrence, the two heater knobs are correct for a '66 Type 1 Ghia and Beetle. The e-brake boot is also correct. I just checked my photos of a very original '66 Ghia Coupe that was at the Aircooled Gathering, NJ in 9/2013, with 43,000 miles. It has the same boot and knobs as your photo below. I "think" the e-boot front snout section was eliminated as of the '67 model year. |
Posted: Tue Sep 18, 2018 6:25 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
I didn't notice the difference until I went to install it. _________________ Lawrence
Posted: Tue Sep 18, 2018 6:27 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
Thank you for the reply.
I guess I keep looking for the right part. Also, who makes rubber floor mats for our cars?
Anybody? I haven't been able to find anything new or used, I'm mainly looking for a good used driver's side....... _________________ Lawrence
c21darrel Samba Member
Posted: Tue Sep 25, 2018 3:26 pm Post subject: Re: My Third Karmann Ghia and New Guy Introduction |
Okay, so I did find a good driver's side floor mat, it came and is more black that the dark gray/greenish original mats. Anybody need a good driver's side mat?
Also, do Karmann Ghia doors have pre-nutted doors for side view mirrors like my Karmann built 914s do?
Anything inside the door from the factory? _________________ Lawrence
