Kustom1wherehouse ball joint puma beam adjustment ????
fifthcenturycheese Premium Member
fifthcenturycheese is offline
PostPosted: Tue Aug 14, 2018 7:33 pm    Post subject: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
I'm attempting to change out the beam on my 67 with a Kustom1wherehouse puma 50/50 adjustable beam that is also equipped with lowered spindles from CB Performance. It looks to me there is no adjustment left as the allen studs that are screwed into the torsion bars are bottomed out in the slots. The only way it can adjust is upward and it looks like it would take a lot of force to make it lift a little bit? Is something out of wack with this new beam? Just finished building a fresh engine that runs fantastic, don't know why I can't figure this out. Productive insight would really be appreciated, thanks again, Mike
kokanee
kokanee is offline
PostPosted: Tue Aug 14, 2018 9:25 pm    Post subject: Re: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
If you wanted to go up more take the shocks off then adjust the beam it should move free then
PostPosted: Tue Aug 14, 2018 9:39 pm    Post subject: Re: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
Kokanee, I will try that.
Thanks, Mike
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Tue Aug 14, 2018 10:34 pm    Post subject: Re: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
There should be a small grub screw where your center adjusting studs are now, those studs should then thread into another threaded hole in the lock collar 90* from where it is now.
TDCTDI wrote:
Driver side trailing arm grub screws are installed from top, passenger side trailing arm grub screws install from the bottom. Your problem is probably at the adjuster binding collar/clamp assembly (Yup, the tiny grub screw that probably got thrown away with the packaging.). The center binding grub screw should be facing forward & will be installed so that the short grub screw is tightened into the adjuster collar, then rotated downwards 90* so that the adjuster stud can be installed.
Your adjuster clamping mechanism will be different externally but the collar will be the same.
PostPosted: Wed Aug 15, 2018 12:04 pm    Post subject: Re: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
TDCTDI, the video you supplied demonstrates a different adjustment system than mine. But thank you. Mike
PostPosted: Wed Aug 15, 2018 12:10 pm    Post subject: Re: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
So, I disconnected the shocks and can still not move anything like its bound in place at the grub screw positions at the very lowest settings! What the hell is wrong with this thing? Pictures included for reference...
TDCTDI
TDCTDI is offline
PostPosted: Wed Aug 15, 2018 12:26 pm    Post subject: Re: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
As I stated in the post, THE ADJUSTER IS DIFFERENT but the internal collar SHOULD be the same.
With the shocks off, remove the center binding stud, then rotate the arms upwards 90*, this will cause the collars to rotate downwards. IF there is another threaded hole then this is where the binding stud should go. the hidden grub screw goes into the previous hole.
This is what your Avis adjuster should look like when not in the beam...
https://www.mooreparts.com/empi-16-9913-avis-weld-...WoQAvD_BwE
If you look at the inner collar, you will see that there are two threaded holes, one is for the hidden grub screw & the second is for the clamping stud.
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Wed Aug 15, 2018 12:58 pm    Post subject: Re: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
^ Agreed.... even though there are Avis "style" of adjusters on the market .... that use the factory VW center anchor with only ONE threaded hole... by looking at the latest pictures.. TDCTDI.. is spot on.. you got the lever bolt in the hidden grub screw threaded hole....
In this particular set up, there should be a second threaded hole in the centering collar..
If not.. it's wrong..
VOLKSWAGNUT wrote:
Not to scale or a perfectly accurate pictorial.. but you'll get the gist.. if not.. put the tools down and step away
First and foremost are you trying to raise or lower it?
Did you specify which position bias you wanted the adjusters installed in?
If so this beam is bias UP...
If you didn't assemble it... have you called Kustom1warehouse or the assembler yet ?? Anxious
Or.... do ya happen to have any spare parts from the assembly .. that resemble a large set screw??
People make mistakes all the time..
Short Grub Screw indicated within red circle
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
PostPosted: Fri Aug 17, 2018 9:50 pm    Post subject: Re: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
Got a hold of Stuart of Kustom1wherehouse and texted him the pictures from my previous posts. He said it all looked correct, I had it all the way dropped and needed to bring the adjusters higher without the spindles in place. After readjusting the grub screws and setting the adjustments higher, I reinstalled the spindles and everything seemed to work just fine. Used one shim on each lower side, car sits exactly where I want it. Happy! Thanks for the input, Mike Very Happy
Mr. Peabody
Mr. Peabody is offline
PostPosted: Sun Oct 07, 2018 8:47 pm    Post subject: Re: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
I see VOLKSWAGNUT that you said some AVIS ADJUSTERS use the single threaded hole on the inside collar. This is the setup that I have on my 74 Beetle. How do I adjust them? Everything that I have tried end with no Suspension Travel
TDCTDI
TDCTDI is offline
PostPosted: Mon Oct 08, 2018 7:58 am    Post subject: Re: Kustom1wherehouse ball joint puma beam adjustment ???? Reply with quote
If they aren't installed correctly then you might have to do a "cut-n-turn" to get the adjuster positioned so that range of adjustment is where you need it to be to get the ride height where you want it to be.
