67ctbug Samba Member
Posted: Sun Jan 07, 2018 1:08 pm Post subject: Re: School me on the 1967 one year only stuff |
far rider wrote: |
VOLKSWAGNUT wrote: |
REDKAFER wrote: |
VOLKSWAGNUT, perhaps we have a morbid sense of humor, no? |
.. just reality...
Back on topic..
There are many things that can be upgraded for safety.. it's a choice how many things to add to a tin can to make one feel more safe..
Better 3 point seat belts and a collapsible steering shaft is a great start... I'm for high back seats... buy it they take some of the charm out of the classic.
Crash avoidance and defensive driving.. seems to be, even more in this day and age... the key to survival..
What years have the collapsible steering shaft? Is it a straight swap? |
1968+, and I believe not. I think you have to put a shim under the gas tank because the collapsible part hits the tank. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
REDKAFER Samba Member
Posted: Mon Jan 08, 2018 4:14 pm Post subject: Re: School me on the 1967 one year only stuff |
67ctbug wrote: |
1968+, and I believe not. I think you have to put a shim under the gas tank because the collapsible part hits the tank. |
I can confirm that. Just put a shiny new gas tank in and the year range is up to 67 with a different gas tank die for 68+, primarily because of that tunnel. Good news though, you can get a 12.5 gallon tank that works from 61 to (i believe) 77 (when they went to the filler door style). This way you can get more capacity and you dont need the shims. (i've always felt weird about shimming things.) |
swharris Samba Member
Joined: September 10, 2010 Posts: 496 Location: N. Orange County
Posted: Tue Jan 09, 2018 1:37 pm Post subject: Re: School me on the 1967 one year only stuff |
[quote="VOLKSWAGNUT"]
REDKAFER wrote: |
Back on topic..
I completely understand. I switched high back to low back seats in my '67 just to look correct and period. But had I upgraded the DC to 3 pts, she'd be walking today. She was wearing the belts and they were new and tight. I would never have imagined that they would fail the way they did.
I understand it is a personal choice, but we have lived for the past 12 years with the reality of a severe spinal cord injury and the fact I had not upgraded to belts that just might have saved her from her current nightmare. Still, the person who ran the red and my wife's ability to safely avoid a collision bear similar burdens of responsibility. Sadly, the other driver(uninjured) does not live the same hell for his part in this tragedy.
It is a decision we all must make as we enjoy our classic cars/busses in this modern world of distracted drivers. You are correct in stating that there is no way to make them completely safe. Safer though, might just be enough.
Believe me, it is not pleasant knowing something you love hurt someone you love. I just wanted to put some real-world perspective on the choices that we make. |
Art Augustensen Banned
Joined: December 30, 2017 Posts: 15 Location: Orleans mass
Posted: Sat Feb 03, 2018 2:51 pm Post subject: Re: School me on the 1967 one year only stuff |
I am new to the beetle and owner of a late dec/jan bug. It appears to be almost correct with only 40K but the intake manifold I was told is wrong as well as the distributor. Reaching out to other 67 owners or experts for your thoughts or anything else. Is the intake a one year only ?? Thanks Art
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9760 Location: Oregon
Posted: Sat Feb 03, 2018 3:29 pm Post subject: Re: School me on the 1967 one year only stuff |
The distributor is clocked incorrectly. The vacuum can should be to the rear of the car, not the front.
Is there a vacuum advance hose from the left side of the carb to the distributor?
The choke wire looks like it's touching the generator. But it could just be the angle of the pick.
You really should move the filter out of the engine compartment. The weight of the filter and fuel in the line can cause the brass nipple on the carb to wiggle out and the end result is not a pretty sight.
I haven't a clue what the fitting on the upper right side of the fan shroud is for. Or for that matter the hose on the intake manifold below the carb base.
Looks like you have all of the tins, seals and hoses in place. Always good to see on a 50yo engine. Well at least the external goodies are 50yo.
The generator is the original type with the push on connectors. All of the replacement ones have lugs with nuts that the wires attach to.
The oil pressure sensor wire appears to have a crack in it near the left fresh air outlet of the fan shroud. Not really a big deal as long as it does not short on the shroud and cause a false green light on the dash.
The engine cold stand a little cleaning. But it's other wise very stock looking to me.
Nice find.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Last edited by 67rustavenger on Sat Feb 03, 2018 5:02 pm; edited 1 time in total |
wcfvw69 Samba Purist
Posted: Sat Feb 03, 2018 4:58 pm Post subject: Re: School me on the 1967 one year only stuff |
Art Augustensen wrote: |
It's got a tall distributor cap on whatever distributor that is. The distributor incorrect. It should have a 113905205K distributor with a short cap. As mentioned, the distributor is not clocked correctly either. It has a Brazilian cheap version of the Pierburg square top fuel pump. The fan shroud has a nipple on the top right side for the charcoal canister on 1970 and later bugs. That's incorrect for a 67. Is it a doghouse fan shroud or it could be a 1970 version. The coils been replaced. It's a long one. The original was short.
The engine does look pretty original with the correct generator, pulley and tin. _________________ Contact me at [email protected]
The Samba member since 2004.
Herrbern Samba Member
Joined: May 04, 2008 Posts: 349 Location: Luxembourg, Europe
Posted: Sun Feb 04, 2018 4:12 am Post subject: Re: School me on the 1967 one year only stuff |
Clamp your fuel lines to prevent fuel leaks and fire. |
ty151 Samba Member
Joined: March 31, 2018 Posts: 165 Location: California
Posted: Mon Oct 08, 2018 5:39 pm Post subject: Re: School me on the 1967 one year only stuff |
After reading through this, I’ve learned so much about 67’s!
Just purchased a 67, with a production date looking like April 67.
The interior is mostly stripped (no headliner or carpet) and it was brought to my attention that the visor clip mounting holes looked odd. I researched the clip differences and it appears they were changed sometime in the middle of the 67 production year. So if I’m reading correctly, early 67’s use 66 visor clips and late 67’s have their own clips before changing again for 68’s?
Does anyone have a picture of a late model 67 with the visors and clips installed to compare to mine? Thanks |
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 280 Location: Richmond, VA
Posted: Mon Oct 08, 2018 6:02 pm Post subject: Re: School me on the 1967 one year only stuff |
ty151 wrote: |
...and it was brought to my attention that the visor clip mounting holes looked odd. I researched the clip differences and it appears they were changed sometime in the middle of the 67 production year. So if I’m reading correctly, early 67’s use 66 visor clips and late 67’s have their own clips before changing again for 68’s?
You are correct. Starting at chassis # 11740816 the visor clips looked like this (these are not OG but WW repops):
ty151 Samba Member
Posted: Mon Oct 08, 2018 8:19 pm Post subject: Re: School me on the 1967 one year only stuff |
Ok thanks you. This is what mine looks like, does it look to be late 67 only visor clip mounts?
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Tue Oct 09, 2018 9:36 am Post subject: Re: School me on the 1967 one year only stuff |
67rustavenger wrote: |
I haven't a clue what the fitting on the upper right side of the fan shroud is for. Or for that matter the hose on the intake manifold below the carb base. |
I'm late to the party with answers, just saw this one. It's got a later shroud on it, one with the nipple at the upper right. CHeck if it's a "doghouse" shroud and cooler... not original but a worthwhile upgrade from stock parts. The nipple on the intake manifold identifies it as a later unit also. The original probably had a plugged heat riser and this was the closest they found. |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Posted: Wed Oct 10, 2018 8:24 pm Post subject: Re: School me on the 1967 one year only stuff |
ty151 wrote: |
Are the assist straps on the B-pillars there? There are two different kinds for '67; over/under mounting screws, or side by side. The covers/coat hooks are dependent upon what the mounting bracket style is _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
ty151 Samba Member
Posted: Sat Oct 13, 2018 5:53 am Post subject: Re: School me on the 1967 one year only stuff |
No straps in the car currently. But it looks to have the over/under mounting holes. Here’s what it looks like
bluebus86 Banned
Posted: Sat Oct 13, 2018 9:09 am Post subject: Re: School me on the 1967 one year only stuff |
Herrbern wrote: |
See link at end of this post on engine fires and safety wires. My 67 Motor nearly burnt my car to the ground because of this issue. it caught fire, only quick use of an extinguisher saved the car from total loss.
and yes that fan shroud is from a later car with fuel evap recovery system.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Tue May 28, 2019 8:19 pm Post subject: |
Deck Lid Latch Plastic piece. The plastic piece on deck lid latch that goes on hook to keep dirt out of lock? Only used on 67.
Where might one find this piece? _________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
Posted: Tue May 28, 2019 9:11 pm Post subject: Re: School me on the 1967 one year only stuff |
You are missing the spring clips that attach the corrugated preheat tubes to the underside of the air cleaner snorkels.
Posted: Wed May 29, 2019 4:22 am Post subject: |
67 Florida Deluxe wrote: |
shakers73 wrote: |
Where might one find this piece? |
Y'mean this thing?
This one from Bill May's gallery has been in my stash for MANY years (thanks again, BIll
A SUPER hard part to find because most fell off. |
The piece I'm referring to fit under the latch in the center hole in attached photo
'74 Super Beetle
'67 Beetle
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Wed May 29, 2019 6:50 am Post subject: |
shakers73 wrote: |
The piece I'm referring to fit under the latch in the center hole in attached photo |
Apron Plug.. (not decklid)
Covered many pages ago
6Kabrio7 wrote: |
I bought mine from Wolfsburg West. All of the links you posted look correct though. |
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
