Engine cuts out when pressing gas pedal - when cool
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Oct 14, 2018 11:48 am    Post subject: Engine cuts out when pressing gas pedal - when cool Reply with quote
Hey All, it's been a while. Wink
Since I don't daily drive my bus any more, I don't have a ton of issues, but I'm having a recurring one lately.
Here goes...
The bus starts up ok, same as always. However, if I hit the gas pedal while the engine is idling, but still cool, it cuts out and sometimes cuts off completely. Once it warms up, everything is fine.
Fuel delivery issue, or something else?
My bus is a 77 Westy, with original 2.0L Type IV, with fuel injection. 262,000 original miles.
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
busdaddy
busdaddy is offline
PostPosted: Sun Oct 14, 2018 12:41 pm    Post subject: Re: Engine cuts out when pressing gas pedal - when cool Reply with quote
Hi Eric, long time no see.
I'd start with a fuel pressure test and watch what it does when you open the throttle. What's the idling pressure?, does it jump when you step on the gas?
Слава Україні!
SGKent Premium Member
SGKent is offline
PostPosted: Sun Oct 14, 2018 1:56 pm    Post subject: Re: Engine cuts out when pressing gas pedal - when cool Reply with quote
since you say you don't drive it much - how old is the fuel?
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Oct 14, 2018 2:29 pm    Post subject: Re: Engine cuts out when pressing gas pedal - when cool Reply with quote
I cycled through two full tanks in June when I took it to California. The problem has been happening for about the last year.
Eric
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Oct 14, 2018 4:07 pm    Post subject: Re: Engine cuts out when pressing gas pedal - when cool Reply with quote
I should probably add that I have a Pertronix II installed. Forgot I did that a while back.
Eric
Wildthings
Wildthings is offline
PostPosted: Sun Oct 14, 2018 4:24 pm    Post subject: Re: Engine cuts out when pressing gas pedal - when cool Reply with quote
Maybe spray some choke cleaner down around the flap in the AFM followed by some kind of lube.
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Oct 14, 2018 8:10 pm    Post subject: Re: Engine cuts out when pressing gas pedal - when cool Reply with quote
A quick video, gives you the gist of the issue.
Eric
SGKent is offline
PostPosted: Sun Oct 14, 2018 9:45 pm    Post subject: Re: Engine cuts out when pressing gas pedal - when cool Reply with quote
have you done a smoke test for vacuum leaks, and also tested the booster to be sure it isn't leaking? Check the TSII to be sure the threads are clean and that the wire is in place.
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Oct 14, 2018 9:47 pm    Post subject: Re: Engine cuts out when pressing gas pedal - when cool Reply with quote
It's been a while since I've had to test anything on this bus. I'll dive in tomorrow and report back.
Eric
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Sun Oct 14, 2018 10:36 pm    Post subject: Re: Engine cuts out when pressing gas pedal - when cool Reply with quote
Maybe your AAR is leaning things out too much. Maybe not. Just a shot in the dark, but TS2s aren't usually bad at just one temp, ignition systems don't normally cut out at just one temp, fuel pressure isn't bad at just one temp.
But if your AAR is out of whack it will fuck you up when cold.
Just thinking is all. I've been told I'm not good at it, though, so fair warning. Wink
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
