Quintanamobay Samba Member
Posted: Sat Oct 13, 2018 9:51 pm Post subject: Chewed up spider-wire from passenger side of bus |
I have a chewed up spider-wire coming from the passenger side of my bus. I recently had a visit from Collin and if I remember correctly he said this was the sending wire for my fuel sending unit.
I tried clipping together the brown wire shown in this picture to the chewed up wire coming from the bottom of my bus. Is this correct? If i ground this brown wire it will cause my fuel gauge to move to the full position, but I kill the ignition before it his the full mark.
Is there a way to repair this wire without dropping the engine?
Thanks |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Sun Oct 14, 2018 8:09 am Post subject: Re: Chewed up spider-wire from passenger side of bus |
Spider wire? Spider wire is fishing line. I'd be careful just hooking up wires without knowing what they are for. There's a good chance you don't need to drop the engine to fix this. |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun Oct 14, 2018 8:28 am Post subject: Re: Chewed up spider-wire from passenger side of bus |
I’m also confused by the spider-wire term. What year is your bus? And please be careful as Dan said. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
SGKent Samba Member
Posted: Sun Oct 14, 2018 8:34 am Post subject: Re: Chewed up spider-wire from passenger side of bus |
what color(s) is it? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Oct 14, 2018 10:58 am Post subject: Re: Chewed up spider-wire from passenger side of bus |
It’s a 78 bus. I couldn’t tell you the color of the wire coming from what looks like the gas tank. It looks like it has been painted over. The reason I called it spider wire is because it’s a braided cable. The chewed up cable is coming from behind the firewall above the rear passenger side tire. |
Posted: Sun Oct 14, 2018 12:45 pm Post subject: Re: Chewed up spider-wire from passenger side of bus |
A "braided" cable would not be stock. Maybe something to do with an added thermocouple or other gauge of some sort. |
SGKent Samba Member
Posted: Sun Oct 14, 2018 1:51 pm Post subject: Re: Chewed up spider-wire from passenger side of bus |
do you mean braided or multi-stranded? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
busdaddy Samba Member
Posted: Sun Oct 14, 2018 4:08 pm Post subject: Re: Chewed up spider-wire from passenger side of bus |
Well VW only put one wire through that hole, it was brown with a stripe (usually white), has some sort of woodland critter eaten all the insulation off of it? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Oct 15, 2018 10:16 am Post subject: Re: Chewed up spider-wire from passenger side of bus |
busdaddy wrote: |
Well VW only put one wire through that hole, it was brown with a stripe (usually white), has some sort of woodland critter eaten all the insulation off of it? |
Its very possible and looks that way. What was the wire that VW ran through that hole for? |
SGKent Samba Member
Posted: Mon Oct 15, 2018 10:42 am Post subject: Re: Chewed up spider-wire from passenger side of bus |
Quintanamobay wrote: |
busdaddy wrote: |
gas gauge sender. Pull the tank firewall to see where it goes. Just a few screws and two underneath. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
