What did you do for your Bay recently?
Page: Previous  1, 2, 3 ... 425, 426, 427 ... 462, 463, 464  Next
stevespeirs
stevespeirs is offline
PostPosted: Wed Sep 12, 2018 10:08 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Peeled off all the crappy window tint film from the PO. Still a few sticky patches to clean off, but overall, looking much better!
1979 Microbus
ScottWally
ScottWally is offline
PostPosted: Wed Sep 12, 2018 11:43 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Filled holes after removing green emergency light from cab top.
Used plastic automotive plugs with rubber washers sealed with Gorilla Glue silicon adhesive.
Before:
After
udidwht
udidwht is offline
PostPosted: Wed Sep 19, 2018 7:16 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Replacing both intake manifold gaskets (HP gaskets from Aircooled.net)
Also remedied (2) hex bar sleeve bushings with the addition of a single Viton o-ring (each side) on the inboard side of the bushing and wrapped the bushing with several turns of PTFE tape. This effectively eliminated the slight bushing slop I had and should hold up very well given both items used are somewhat resistant to heat.
Now just waiting for parts to arrive for reinstall.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
Sven F
Sven F is offline
PostPosted: Thu Sep 20, 2018 1:30 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Got tired of losing plastic bolt caps on the bumper. Bought some stainless M8 bolts and washers, grinded the markings off and shaped the heads to a slight dome shape, then wetsanded and polished to a high shine.
Stainless is much cheaper than chrome and also won't chip and rust when you use tools, they just don't come shiny out of the box.
notchboy
notchboy is offline
PostPosted: Thu Sep 20, 2018 6:48 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Looks like you got tired of the later bumper too that the bolt caps and bolts go to? Think Laughing
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Sven F
Sven F is offline
PostPosted: Thu Sep 20, 2018 9:42 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I didn't drill holes in a early bay bumper if that's what it looks like. That's a late, late bumper from a Brasilian bay window. They also use bolts and caps, although not horizontally like that.
Gashog
Gashog is offline
PostPosted: Fri Oct 05, 2018 4:46 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Servicing the CV jernts on my sweet 72 deluxe. They're the originals, dated 71 and looking pretty good with 180K on them. Have yet to decide on them or a new set… Thank you Mr Tcash for all the informative links. Wouldn't be doing this without them… or my Bentley.
kevinj73us
kevinj73us is offline
PostPosted: Sat Oct 13, 2018 10:20 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Installed a new (reman) transmission from Mr. Gas.
So much quieter driving now instead of the 45 year old howler that I replaced. Looking forward to actually talking to people when they ride with me. Very Happy
kj
1973 Station Wagon
m-plate
Hikelite
Hikelite is offline
PostPosted: Mon Oct 15, 2018 9:43 am    Post subject: Re: What did you do to your Bay recently? Reply with quote
Sometimes I get my words mixed up, but here is my latest post for the "What did you do to your Bay recently?" thread.
My ignition switch had stopped springing the key back from the start position, so it's time to replace it. I'm ready to start the job.
I found the set screw!
The old switch came out easy enough, but I struggled a bit getting the new one back in. As I tried to move the turn signal wire bundle around, I realized my wiring was not offering much slack.
My fuse block had one of the mounting points broken off when I bought it in the 90's. Since that seems like an important part to have in working order, I got right on it and ordered a new one this week. Laughing
Knowing a new fuse block was coming, and following the age old wisdom, "If something aint broken, fix it anyway," I decided to go ahead and disconnect everything. Cool
This is how I left things last night. Every wire identified and labeled. Smile
New fuse box arrives on Wednesday.
~Kevin
My 1968 Campmobile
notchboy
notchboy is offline
PostPosted: Mon Oct 15, 2018 10:10 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Dahm, it took you longer to label then to disconnect Razz Laughing
I just took a pic - several of them for when I put mine back.
1964 1500 S
Hikelite
Hikelite is offline
PostPosted: Mon Oct 15, 2018 11:53 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I took several photos to reference as well. Wink
I couldn't get the dash cluster out without disconnecting wires from the back first. I used the photos to identify which ones went where after I removed the dash cluster. It did take a little time to label all the wires, but I feel it was worthwhile. After I clean up all the connectors, everything will go back together easily. Smile
I had other motivation as well. I am putting in an electric washer pump, so I needed to pull that switch as well.
While it's all apart I can also clean everything up. The switches looked a lot worse when I first pulled them out. I'll clean and lube everything before reinstalling. Cool
Of course while I am sitting there working on this, I keep eye balling that wiper assembly. It looks like it could use a little TLC as well. I have Colin's thread bookmarked already. Maybe while I'm under here I can also get a spray can of Pearl White and touch up some spots. Rolling Eyes
~Kevin
My 1968 Campmobile
stevespeirs
PostPosted: Sat Oct 20, 2018 10:03 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Waiting on some bits and pieces to be delivered. Might as well install the VDO Quartz clock I snagged on the classifieds.
1979 Microbus
HoboBus
HoboBus is offline
PostPosted: Sat Oct 20, 2018 6:38 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Passed yearly inspection today, got my new inspection sticker, and took my girl out for BBQ tonight in the Bus!!
Was a good day. Smile
Hobobus.
Salt air it ain't thin, it'll stick right to your skin,
it'll make you feel fine. Makes you feel fine.
And I wanna be there. -- Jimmy Buffett
Just a beach-oriented camping Hobo with a bus.
Angus II
Angus II is offline
PostPosted: Sun Oct 21, 2018 10:35 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Hello,
I put the luggage rack and pop top back on the bus. By myself, where's all the help when you need it?.
Now, Gus the bus looks like a real campmobile not a tin top...
I may have to go for a fall colors drive today. It's so nice up here this time of year, with all the colors changing. Also, the lack of tourist...
Too bad, Gus has to get put away for the winter soon.
Long-roofs
Long-roofs is offline
PostPosted: Wed Oct 24, 2018 8:47 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Truck Army working. Helping me paint the house.
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
Spike0180
Spike0180 is offline
PostPosted: Fri Oct 26, 2018 7:20 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Hit a new max speed of 84MPH, didn't take picture proof... because that's dangerous. I had pedal left, I think ima go for 90. That'd be faster than my 97 ranger lol
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
Zambia
Zambia is offline
PostPosted: Sun Oct 28, 2018 5:37 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Did a generator to alternator conversion on my 69 deluxe bus. Overall easy. Had some issues with alternator not sitting all the way back on the alternator stand. Pulled out my grinder and fixed that problem. Didn't know that you had to run your motor to over 1000rpm to get the generator light to go off. I checked my wiring twice until a buddy let me in on that little secret!
stevespeirs
PostPosted: Tue Oct 30, 2018 4:00 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Fitted a rather nice glovebox from Wolfsburg West. Much prefer the fiberboard material to the more readily available black plastic.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211857101A
Also installed a silver socket just below the glove box. Read all about it @ http://www.ratwell.com/technical/SilverSocket.html
1979 Microbus
stevespeirs
PostPosted: Mon Nov 12, 2018 5:28 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
As part of the sliding door hinge refresh, replaced the crusty old beading from behind the sliding door rail cover. Turned out pretty good.
Part # 281 843 799 from BusDepot.com
http://www.busdepot.com/281843799
1979 Microbus
stevespeirs
PostPosted: Mon Nov 12, 2018 5:39 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Door is sliding along nicely too!
1979 Microbus
Page 426 of 464
