rodeking Samba Member
Joined: October 09, 2017 Posts: 369 Location: near Buffalo NY
Posted: Tue Oct 16, 2018 9:18 am Post subject: CB Maxi 26 pump |
As seen below. You can see the cover is designed to block off the discharge port and send the oil to the filter. The discharge port in the pump body is not plugged and I did not plug the discharge port in the case. But now I'm thinking maybe I should plug the port in the pump body to prevent any possible bypassing around the filter. This pump has .0045 between the drive gear and the cover. Run it as is or plug it? My instinct is to plug it.
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Tue Oct 16, 2018 10:08 am Post subject: Re: CB Maxi 26 pump |
Looks to me like the pump cover blocks off the outlet oil way. The gasket may have a hole in it matching the connection to the 'output' oil gallery in the engine block, but the gallery will be sealed shut by that gasket, blanked off by the cover.
Same pump body, different pump cover with an in and out and you have a model that needs no case drilling and tapping. E.g. a Maxi 3 like mine.
Now for the messing around with the CB socket head bolts instead of studs - either too long and they bottom out or too short and they strip the thread in the block by the time you have the cover tight enough.
On the Maxi 3 you can still use studs and nuts for the two right hand holes in the pump cover. On the left you will need the lower profile of the socket head bolts to miss the tinware. _________________ Ancient vehicles and vessels
Posted: Tue Oct 16, 2018 11:12 am Post subject: Re: CB Maxi 26 pump |
The gasket doesn't block off the port so I just drilled the port to 27/64 and made a plug and pressed it in. There was a reason I didn't go with the Maxi 3 but I can't remember why, maybe the size of the fittings or something. I'll have to see what to do with the screws, probably just buy some longer ones.
Thanks.
mark tucker Samba Member
Posted: Tue Oct 16, 2018 12:16 pm Post subject: Re: CB Maxi 26 pump |
I usualy use a push in oil gally plug and plug them.I dont tap them like most do, your way will be fine as frogs hair. |
Posted: Tue Oct 16, 2018 2:30 pm Post subject: Re: CB Maxi 26 pump |
Just realized this plug method could make it a real PITA to pull the pump out if necessary since there is no way to hook a puller on to the outlet port. Looks like a plug on the OD of the body will cause the same problem. So how do you get these out with the outlet plugged? I think I can put a couple jack screw holes in the flange next to the existing holes. |
allamaabroad Samba Member
Joined: September 22, 2016 Posts: 560 Location: South Jordan, Utah
Posted: Tue Oct 16, 2018 6:54 pm Post subject: Re: CB Maxi 26 pump |
Blind hole puller and a slide hammer. Pull the drive gear, find the puller that fits best in the shaft bore, then slide hammer it out _________________ Dennis - 1973 Super Beetle ('16-'21)
Debbie- 1970 Baywindow Bus ('21 - Present)
Tin top camper/adventure bus
2180 TW: CNC Panchitos, Beehives Done Right, Web 163, Ultralight Lifters, 1.3 Rockers, CSP Python, Custom Speeduino EFI Conversion with 40mm Throttle Bodies
Distributors are lame
I have a really hard time leaving things alone...
Innovative and affordable engine management systems and EFI conversions for your Vintage VW
Visit https://debbiesaircooled.com/ |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Tue Oct 16, 2018 7:26 pm Post subject: Re: CB Maxi 26 pump |
If you actually look at this pump and understand flow, you will realize it is fine as it is. It will be a regular f/f pump with the cover that comes with it, nothing is needed. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Tue Oct 16, 2018 7:57 pm Post subject: Re: CB Maxi 26 pump |
I would ditch that set-up altogether... For sure use a deep sump / extra oil capacity if you are going to rev it.
I use a drysump on my really hot engines.
Most projects I do use a 26-30mm pump... I usually buy 6 at a time and return 3-4 of the crappy ones.
Then I use a Gene berg nodular iron pump cover. _________________ If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here. |
Posted: Wed Oct 17, 2018 4:43 am Post subject: Re: CB Maxi 26 pump |
I decided to just leave it as is. If the pump has to be pulled for something more serious than a leak then the case usually has to be split anyway. I used a little 518 on the flange so that should take care of any leaks between the body and the case.
I understand how it works. But with the outlet port left open in the pump body and .004 clearance between the drive gear and cover then a .003 piece of whatever could possibly get into the oil galley thru the outlet port. The plug makes sure that won't happen.
This is on a little 1679 double cab that will get driven to cruise nights and to the local DQ for ice cream, it doesn't need a deep sump.
If someone did want to make it easy to remove the pump then I think two M6 x 1.0 holes in the flange would do it. Pull the cover, thread two long cap screws into the holes and jack it out. |
Posted: Wed Oct 17, 2018 8:49 am Post subject: Re: CB Maxi 26 pump |
The pump is fine. They do this so they can use the same pump with different pump COVERS to address different needs. One with full flow, and one without it. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
