malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Thu Oct 11, 2018 6:35 pm Post subject: 72 front bumper connection |
There are 4 captured nuts (2 on each side)under the cab door threshold that the bumper bolts thread into. When I removed my front bumper one nut broke loose. They are attached, welded i assume, inside the cavity. How on the hell do i fix this?
Window seals allowed water in. It rusted thru the bottom of the door and then the threshold. Filled the cavity and rusted the nuts. My take on this ugliness.
_________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
70Crew Samba Member
Joined: June 12, 2006 Posts: 776 Location: Grand Rapids, MI
Posted: Thu Oct 11, 2018 6:42 pm Post subject: Re: 72 front bumper connection |
I had to do a similar repair. Google “rivnut”. _________________ 1970 Crew Cab |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Oct 11, 2018 6:43 pm Post subject: Re: 72 front bumper connection |
If you don't want to open up the dog leg or inner skin you can hole saw that out, weld a new nut on the part you cut out (or a new piece) and weld the "hole" back in.
Or put a Riv-nut in there, not nearly as good a repair but I don't know your personal level of "good enough". _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Oct 11, 2018 6:48 pm Post subject: Re: 72 front bumper connection |
My 1st thought to cut it out. That way i could get a tiny look at the inside rust and cleaning and coverting and coating in there.
I was thinking cutting the side, but i like the hole saw idea. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Oct 12, 2018 6:35 am Post subject: Re: 72 front bumper connection |
I've installed a lot of rivnuts but I don't think they are the right way to go for mounting a bumper. They rely on the body being squeezed and when you put a lot of torque on them they can spin. A bumper is too heavy and hanging out on the end of an arm. I think you'll need a weld repair to do this right. Pictured is the tool and 6mm rivnuts. You'd need 10mm rivnuts I think and most likely a different tool because hand squeezing a big rivnut takes a lot of force
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Oct 12, 2018 6:41 am Post subject: Re: 72 front bumper connection |
That looks like the side step mount to me from here, so 8mm bolts. But if you are set up for welding already it's best to cut it open and replace the nut. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Oct 12, 2018 8:27 am Post subject: Re: 72 front bumper connection |
busdaddy wrote: |
That looks like the side step mount to me from here, so 8mm bolts. But if you are set up for welding already it's best to cut it open and replace the nut. |
Yes, I am set up to weld. And you are correct, it would hold the step. And it is the nut on the end of the bumper tip, so there is nothing else out there to help hold it all up.
Not the best welder and I do hate welding up or upside down. But I can give it a go.
I have some hole saws, but they are probably best used on wood. So I probably need to get a tuffer one. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Fri Oct 12, 2018 8:46 am Post subject: Re: 72 front bumper connection |
Lots of 5 star reviews on this one. Many from Car People. Looks like you can apply much more force with the longer handles. I will read up on it. Truthfully, I could do this 1st. If it ever failed, I could go the welding route.
https://www.amazon.com/dp/B073VK3B7S/ref=pd_luc_rh...merReviews _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Fri Oct 12, 2018 8:54 am Post subject: Re: 72 front bumper connection |
Yes, much better. Since it's only the 8mm bumper side support bolts I think the rivnut would work. The weight of the bumper itself is not supported by these so I'd give it a try.
The greatest majority of the rivnuts I install are for the pedal pan so you might want to use it there too. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Oct 12, 2018 12:34 pm Post subject: Re: 72 front bumper connection |
maybe I'll buy that rig but add the $20 set of SS nuts. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
mikewire Samba Member
Joined: March 22, 2010 Posts: 805 Location: San Antonio, TX
Posted: Fri Oct 12, 2018 12:57 pm Post subject: Re: 72 front bumper connection |
Interesting timing on this post...I'm about to mount my rear bumper (and hitch) with the same issue - the captive nuts in the frame gave way and there's no way to mount the right (passenger) side into the frame, short of opening the frame up. My Bus is also a 1972.
I'll be using that exact rivnut tool from Amazon, but with stainless steel rivnuts, (M10 x 1.5) with bolts, and lock washers.
I have most of it layed out, ready to go...and I am going to produce some content on this bit of work for a YouTube channel I've created for documenting working progress on my Bus.
Please post up your progress, and when I have mine done, I'd be glad to share it with you and the group here.
BTW, on the regards of safety and rivnuts...I'm not planning on towing anything with my hitch setup, and if anyone were to hit the bumper with any modern vehicle at a moderate rate of speed, it's not going to help much. As far as I'm concerned, this is pretty much just a cosmetic appearance repair. I'm interested in hearing others thoughts (and other possible solutions) too. _________________ -Mike
@countdowngarage
@bigskyeuro
1972 VW Kombi 9 Passenger Deluxe w/ 2.0L F.I. VWAC swap
1965 VW Beetle Deluxe Bahama Blue |
Posted: Sat Oct 13, 2018 3:44 pm Post subject: Re: 72 front bumper connection |
A bit of an update. As much as I liked the idea of using a hole saw to cut the hole out, weld the nut in then replace it.... I now see how they really beefed up the nut bracket. Not sure what the very best way would be to repair but it might include some cutting out from the top and actually welding the a fresh nut back in. Oh well, RivNut tool is on the way and I am doing it that way.
But here is some of my cutting today. Gives you a view inside. Truthfully the Riv nut wedged on the bracket and the dogleg should be a nice and tight sandwich.
Posted: Mon Oct 29, 2018 7:27 pm Post subject: Re: 72 front bumper connection |
Used a stainless steel one. Still need to do some top coat painting under the driver and in the wheel well, but I think this will do it.
